Does mixing glycerol into water effect electrolysis of water?
In summary: The dielectric permittivity of water is 1.0, while that of glycerol is about 0.6. So glycerol does slightly dissociate into water and acetone.
kevin_tee
80
I tried measuring ohm and the resistance of water is lower after mixing glycerol.
Then I experiment electrolysis of water, first I measure the resistance of DI water and it turns out that the resistant is about 0.63 mega ohm.
Then mix DI water and glycerol and the resistant went down to 0.6 mega ohm.
I mix sodium sulfate and glycerol into water to decrease the resistant then suddenly the gas is produce.
The gas that is produce seems to be 2:1 ratio (hydrogen:eek:xygen) but I can't analyse the gas so I'm not sure if the gas that is produce is hydrogen and oxygen or not.
Does glycerol change into new compound due to electrolysis? Thanks.:biggrin:
Chemistry news on Phys.org
Organic compounds in solution can be oxidized at the anode in electrolysis. Oxidation products of glycerol could be things like dihydroxyacetone or tartronic acid, or the oxidation could proceed all the way to water and carbon dioxide.
What water/glycerol ratio?
What is responsible for the conductivity of water solutions?
The water is 80 ml and glycerol is 5 ml. The electrode that used to measure the resistant of water is place roughly (but keeping the same distance)just to know that the resistivity change or not.
The conductivity of DI water could be the contaminant of the beaker, the conductivity of water is ion, an ion carry electrical charge + and -, the cation is discharge at the anode and anion is discharge at the cathode.
Thanks for the information hilbert2.
I have research a little bit and it seems that glycerol doesn't change into other chemical since it is not ionic compound (it is polyol) so it doesn't carry electric charge. Am I correct? Correct me if I am wrong.Thanks.
So any compound that conduct electricity does form new compound due to electrolysis?
Even non-ionic compounds can often be oxidized electrolytically. One just has to add in the solution some other compound that makes it conductive. For example, if you electrolyze a solution of sodium chloride in water-ethanol mixture (using platinum electrodes), you will soon find that the resulting solution contains several oxidation and chlorination products of ethanol, such as acetic acid, chloral hydrate and trichloroacetic acid.
Thanks for the answer, but why does it do that? Can't the electrolyte just ignore other compound and conduct electricity normally without oxidizing-reducing other compound? I though the conductivity of electrolyte is the movement of ion. How does movement of ion effect other compound?
hilbert2 said:
The electrical conductivities of glycerol-water mixtures can be found here on page 23: http://www.aciscience.org/docs/physical_properties_of_glycerine_and_its_solutions.pdf .
There is a slight problem with the table - it assumes conductivity of pure water to be around 107 MΩ (that is assuming I read the exponent correctly), while it should be around 1.8×107 MΩ.
That's not to say it is completely wrong, but it is obviously a bit off.
Good.
Do you introduce any ions into the solution by adding glycerol?
It is not about what is happening in the bulk of the solution, where the ions are mostly migrating as inert charge carriers. But the charge has to somehow pass the phase boundary (solution/electrode), and that's where the reactions take place.
Borek said:
Good.
I have research a little and I found out that glycerol is miscible in water, so it does not introduce any ion, am I right?
Miscibility doesn't matter, dissociation does. Does the glycerol dissociate?
Alcohols should dissociate, slightly.
For example, ethanol is almost as strong acid as water - in aqueous solution.
The reactions
HOH=H++OH-
and
C2H5OH=H++C2H5O-
have very similar equilibrium constants - pKa is 15,7 for water and 16 for ethanol. If you dissolve alkali in ethanol, the reaction
NaOH+C2H5OH=C2H5ONa+H2O
is only slightly directed towards ethanol.
Glycerol is very slightly stronger acid than water, because while aliphatic chain of ethanol is electron donor, the other hydroxyl groups are electron withdrawing.
On the other hand, glycerol does have lower dielectric permittivity that water. At 25 degrees, I think 100 % water was 80 and glycerol was 41.
Lowering permittivity should weaken the dissociation of both water and glycerol.
1. What is glycerol and how does it affect electrolysis of water?
Glycerol is a colorless, odorless, syrupy liquid that is commonly used in various industries, including cosmetics and food production. When mixed with water, glycerol forms hydrogen bonds with water molecules, which can potentially affect the process of electrolysis.
2. Does glycerol increase or decrease the rate of electrolysis of water?
The addition of glycerol to water can actually decrease the rate of electrolysis, as the hydrogen bonds formed between glycerol and water molecules can hinder the flow of electricity. However, the exact effect will depend on the concentration of glycerol and other factors.
3. Can glycerol affect the products of electrolysis of water?
Yes, glycerol can affect the products of electrolysis of water. When glycerol is present, the products of electrolysis may include not only hydrogen and oxygen gas, but also additional compounds such as glyceric acid and formic acid.
4. Is the effect of glycerol on electrolysis of water reversible?
The effect of glycerol on electrolysis of water can be reversible, depending on the concentration of glycerol and other factors. In some cases, the addition of glycerol can inhibit electrolysis, but the process can return to its normal rate once the glycerol is removed.
5. Are there any other factors that may influence the effect of glycerol on electrolysis of water?
Yes, there are several other factors that may influence the effect of glycerol on electrolysis of water. These include the concentration of glycerol, the temperature of the water, and the type of electrodes used. Additionally, impurities in the glycerol or water may also impact the process.
  • Chemistry
9K
  • Materials and Chemical Engineering
  • Biology and Chemistry Homework Help
  • Classical Physics
  • Chemistry
