I want to understand intuitively why LCM(a,b)=ab/GCF(a,b)
  • Thread starter Juwane
SOMETIMES...memorizing is good, but only as a temporary measure until one understands. With that said, try to understand Matticus' explanation. It's quite good.
Juwane
87
I want an intuitive understanding of why the lowest common multiple of two numbers is equal to the two numbers multiplied together, divided by the greatest common factor of the two numbers, i.e.,
LCM(a,b)=(a*b)/GCF(a,b)
I wish to know how this formula gives us the LCM of the two numbers.
Mathematics news on Phys.org
Focus on individual primes.
Consider a specific example (this is a good way to look at the "why" of a formula like this; once you see the workings in a particular case, you get a feel for the general case).
I'll use a = 84, b = 96. The prime factorizations of these are
[tex]
\begin{align*}
a & = 2^2 \cdot 3\cdot 7 \\
b & = 2^5 \cdot 3
\end{align*}
[/tex]
It's easy to see that the LCM of these numbers is [tex] 2^5 \cdot 3 \cdot 7 [/tex] and, further, that the GCF is [tex] 2^2 \cdot 3 [/tex]. Now
[tex]
LCM(a,b) \times GCF(a,b) = \big(2^5 \cdot 3 \cdot 7\big) \times \big(2^2 \cdot 3\big) = \big(2^2 \cdot 3 \cdot 7\big) \times \big(2^5 \cdot 3\big) = a \times b
[/tex]
or, to summarize
[tex]
LCM(84,96) \times GCF(84,96) = 84 \times 96 \Rightarrow LCM(84,96) = \frac{84 \times 96}{GCF(84,96)}
[/tex]
which gives your formula for this pair. If you are careful with your notation when you look
at prime factorizations for arbitrary choices, the same thing happens.
[tex]
\begin{align*}
b & = 2^5 \cdot 3
\end{align*}
[/tex]
Somehow it is not easy for me to see why the LCM of the two numbers is [tex] 2^5 \cdot 3 \cdot 7 [/tex].
Can you please tell me how you can tell the LCM from the prime factors of the numbers?
Sorry for asking silly questions.
I really don't understand why [tex]LCM(a,b) \times GCF(a,b) = a \times b[/tex]. I know it has to do with the defintion of LCM and GCF, and I understand what an LCM and GCF is, but somehow I can't see why their product should be equal to the product of the numbers they are the LCM and GCF of.
As people have said before consider primes and prime factorizations. For instance for a prime p and integers c,d what is [tex]\text{lcm}(p^c,p^d)[/tex] and [tex]\gcd(p^c,p^d)[/tex]. Can you generalize the formula to prime factorizations? (statdad's example should give you a hint that the answer is yes, and what it looks like).
Here is an example from me:
Consider numbers 12 and 18.
Multiples of 12 are: 12, 24, 36, 48...
Multiples of 18 are: 18, 36, 54...
Clearly, the least common multiple is 36.
The factors of 12 are: 1, 2, 3, 4, 6, 12
The factors of 18 are: 1, 2, 3, 6, 9, 18
Clearly, the greatest common factor is 6.
What I want to ask is why [tex]LCM(12,18) \times GCF(12,18) = 36 \times 6 = 12 \times 18[/tex]
To get the LCM
* Write down each prime factor to the HIGHEST power it has in either factorization
To get the GCF
* Write down each prime factor to the LOWEST power it has in either factorization
in your example you have completely ignored prime factorization.
suppose we write a number as a list of exponents n=(e1,e2,e3,...) where only finitely many ei's are non-zero, and so that e1 is the exponent of 2, e2 is the exponent of 3, and en is the exponent of the nth prime.
in your example 12 = 2^2*3^1= (2,1,0,0,...) and 18 = 2^1*3^2= (1,2,0,0,...)
Now, to find the lcm we compare each position and choose the larger (or equal) exponent.
lcm(12,18) = (2,2,0,0,...) = 36
Similarly, to find the gcd we compare each position and choose the smaller (or equal) exponent.
gcd(12,18) = (1,1,0,0,...)= 6
Now 12*18 = (2,1,0,0,...)*(1,2,0,0,...)=(2+1,1+2,0,0,...)
When we multiply the lcm*gcd, we are still going to add the same exponents at the same position, the only difference could possibly be the order which they are added depending on which is larger. Since addition of integers is commutative, this does not matter.
Another example for clarification:
28 = 2^2*7^1 (2,0,0,1,0,0,...)
20 = 2^2*5^1 (2,0,1,0,0,...)
lcm(28,20) = (2,0,1,1,0,0,...)
gcd(28,20) = (2,0,0,0,...)
So each exponent from all primes in both numbers have been accounted for exactly once so the product lcm*gcd is the same as 28*20.
Matticus, thank you for your explanation, but I'm looking for an easier explanation, one without prime factorization if possible.
I think LCM and GCF are exact opposites of each other--
smallest common multiple
--except that they both have to do with commonness. If this is true, then I want to understand in the light of this fact.
I'm not sure if this explanation is easier, but it doesn't use prime factorization which you want to avoid for some reason.
If a' and b' are relatively prime then GCF(a',b') = 1 and LCM(a',b') = a'b'. To see the latter just note that otherwise LCM(a',b') = a'b'/k for some integer k, but then k is a common factor of a' and b'.
Also GCF(a'g,b'g)=g * GCF(a',b') and LCM(a'g,b'g) = g * LCM(a',b').
Now let g=GCF(a,b), then we can write a and b as:
a = a'g
b = b'g
for relatively prime integers a', b'. Then we have:
GCF(a,b)LCM(a,b) = GCF(a'g,b'g)LCM(a'g,b'g) = g^2 GCF(a',b')LCM(a',b') = a'b'g^2 = ab
I guess I'll just memorize that [tex]LCM(a,b) \times GCF(a,b) = a \times b[/tex]
Memorization of formulae won't get you far. You've had several very good explanations about why this relationship holds - and I submitted an explanation as well. Understanding the reasons things work as they do is entirely different than memorizing results, and without understanding you run the risk of applying results when they shouldn't be.
In short, sometimes 'understanding' requires some work on your part.
Reading rasmhop's explanation, I now understand why [tex]LCM(a,b) \times GCF(a,b) = a \times b[/tex] is true for relatively prime integers, but I still don't understand why it is true for integers with common factors and/or common multiples.
1. What does LCM and GCF mean in this equation?
LCM stands for "lowest common multiple" and GCF stands for "greatest common factor." In this equation, LCM refers to the smallest number that is a multiple of both a and b, while GCF refers to the largest number that divides both a and b evenly.
2. Why is the LCM of two numbers equal to their product divided by their GCF?
This can be explained by the fundamental theorem of arithmetic, which states that every positive integer can be expressed as a unique combination of prime numbers. The LCM is the product of all the prime numbers in the two numbers, while the GCF is the product of only the common prime numbers. Therefore, dividing the product of the two numbers by their common prime numbers results in the LCM.
3. How can I use the LCM and GCF to simplify fractions?
The LCM and GCF can be used to simplify fractions by dividing both the numerator and denominator by their GCF. This will result in a simplified fraction that is equivalent to the original fraction.
4. Can the LCM and GCF be used with more than two numbers?
Yes, the LCM and GCF can be used with any number of numbers. To find the LCM, simply find the LCM of the first two numbers and then find the LCM of that result and the next number, and so on. To find the GCF, find the GCF of the first two numbers and then find the GCF of that result and the next number, and so on.
5. Are there any real-life applications of understanding the relationship between LCM and GCF?
Yes, understanding this relationship is useful in many areas such as simplifying fractions, finding common denominators, and solving problems involving proportions and ratios. It is also used in fields such as computer science and engineering for finding the most efficient way to allocate resources or schedule tasks.
  • General Math
  • General Math
  • General Math
  • General Math
  • STEM Educators and Teaching
12K
