Is Anti-Gravity Possible with Anti-Gravitons?
In summary: But what about if the graviton does exist and has a positive mass? Would that make it an anti-graviton?There is no such thing as negative mass. You can have imaginary mass emerging when making the unitary infinite dimensional reps of the restricted Poincaré group,the so-called tachyonic reps,but that's something nonphysical.
KC9FVV
If gravitons do exist, will an anti-graviton repel matter(anti-gravity)? Also, can we, reasonably, assume that the graviton does actually exist?
Consider the yukawa interation, the force is always attractive no matter the nucleons
are particle or anti-particle.
EM interation is a special case, because particle and anti-particle has opposite electron charge.
But other charge is not the same, in your case, the anti-particle has positive mass, but not negative mass, so no anti-gravity.
This is a strange question, or better this question asks for a strange answer. Because an anti-graviton could only be an antigraviton if it has opposite energy. So negative mass/energy. This assuming it generates opposite gravitation.
But if the graviton does exist, will it still have a positive mass opposite particle? How would such a particle differ?
We cannot assume the graviton exists. If you really have to pick yes or no maybe yes would be smarter. But gravitons might not exist.
I would be interested in seeing someone with some real physics knowledge answering this question.
Without actually going into the details of the physics of gravitons and quantum gravity, there is already a flaw in your logic here. You are assuming that if there is a force carrier particle such as a gravitons, then automatically it implies that there will be an "anti-gravitons".
This is not true in every cases. A photon, which is the force carrier for EM interactions, is its own anti particle! This means that just because we have a particulate carrier, does not automatically imply that an "anti particle" of an opposite kind has to exist.
Zz.
There's a nice mathematical explanation to the existence of antiparticles.It involves involuted associative algebras.For example,the complex numbers form such an algebra and the complex scalar field,which is an element of such an algebra,describes,after quantization both particles & antiparticles.
See if the electromagnetic field [itex] A_{\mu}(x) [/itex] and the gravity field (well,either one of the 3 possible fields describing it) could form such an algebra.
Daniel.
But then could anti-gravity work through gravitons if you have negative mass(made of negative energy?). Opposite charges idea.
There's no such thing as negative mass.You can have imaginary mass emerging when making the unitary infinite dimensional reps of the restricted Poincaré group,the so-called tachyonic reps,but that's something nonphysical.
Daniel.
I know this is philosophy.
Related to Is Anti-Gravity Possible with Anti-Gravitons?
1. What is an anti-graviton?
An anti-graviton is a theoretical particle that is believed to be the antiparticle of a graviton, which is the hypothetical particle that carries the force of gravity.
2. How does an anti-graviton create anti-gravity?
Anti-gravitons, if they exist, would interact with gravitons in a way that would cancel out gravity. This would result in a repulsive force, or anti-gravity.
3. Is anti-gravity possible?
Currently, there is no scientific evidence to support the existence of anti-gravitons or the possibility of anti-gravity. It remains a topic of speculation and theoretical research.
4. What are the potential uses of anti-gravity?
If anti-gravity were to be achieved, it could have a wide range of applications, such as levitating objects, creating frictionless environments for transportation, and potentially even space travel.
5. Are there any experiments or research being done on anti-gravity?
There have been several experiments and studies conducted on the concept of anti-gravity, but so far, there has been no conclusive evidence or success in creating anti-gravity. Some scientists are still actively researching this topic, but it remains a highly theoretical and speculative concept.
  • High Energy, Nuclear, Particle Physics
  • Quantum Physics
  • Beyond the Standard Models
  • Astronomy and Astrophysics
