Did Bell's Theory Contain a Mathematical Flaw?
In summary, the conversation mainly discusses mathematical questions surrounding Bell's paper on quantum physics. Questions are raised about the use of probability functions and the variables λ in Bell's equations. The expert summarizer provides answers and clarifications to these questions, and also mentions the difficulty in finding a clear explanation from Bell himself.
  • #36
JesseM said:
Most of this looks good to me, my only question is about why you made it a sum only over identical values of lambda, rather than a double sum over all possible combinations of values. I would guess this is because you want to include the condition that identical detector settings always imply identical results G and G'? This requires that lambda contain no additional information beyond a set of results for every possible measurement setting--if there were two different values of lambda, say i=12 and i=17, that both implied exactly the same set of results for every possible measurement setting, then it could be that the source would occasionally send out a pair with these different values and it wouldn't conflict with the observation that same settings always give same results. But as long as lambda is defined in a minimal way so that different values of lambda always imply different measurement results for some possible pair of detector settings, then it is safe to assume that the source must always send out pairs that both have the same value of lambda, so a single sum like the one you wrote is fine.
OK - thank you -- you just beat me to lodging this refinement -- an old notation of mine that sits better with the use of subscripts yet to come. I found it hard to continue clearly with identical but unrelated subscripts:
[tex]
P''(G, G'|H, a, b') = \sum_{i=1}^N P_3(\lambda_{i}, \lambda'_{i})*P(G|H, a, \lambda_{i})*P'(G'|H, b', \lambda'_{i}).
[/tex]
Trust that's OK.
We next come to defining EPR elements of physical reality.
I will try to get it done during this busy weekend.
Your detailed replies are much appreciated.
JenniT
  • #37
[tex]
[/tex]
Trust that's OK.
Yes, with the conditions I mentioned it's fine.
JenniT
Take your time, it turns out I'll be taking a trip tomorrow and won't be back until Monday anyway.
  • #38
fyi, David Bohm (1951, Quantum Theory) discusses the Einstein, Rosen, Podolsky view. Here is summary of ERP argument as understood by Bohm:
1. Every element of physical reality must have a counterpart.
2. If, before measurement the value of a physical quantity can be predicted, then there exists an element of physical reality corresponding to this physical quantity.
These two criteria rest on two assumptions:
3. The universe can be correctly analyzed in terms of distinct and separate "elements of reality"
4. Every element of physical reality must have a counterpart of a precisely defined mathematical quantity.
Does this summary by Bohm match your understanding of ERP ?
  • #39
This is not correct. According to EPR, (1) is a condition to be applied to a complete theory, without any implications for the meaning of "elements of reality". You may have confused the fact that the main focus of EPR was to argue that QM is not complete rather than to define in an exhaustive manner what "reality" means. So the definition they gave which is your (2) above, is an operational definition in the context of trying to prove that QM is not complete. Therefore your claims (1), (3), (4) are not accurate representations of what EPR defined as "reality", only (2) is correct.
  • #40
Dear Salman2,
This is a short quick post to thank you very much for posting these important details.
To put your mind at ease, my short answer is YES, certainly ... BUT ...
1. Thank you for using Bohm's funny ERP!
2. Please see Bill's very important post above.
From my first reading of what Bill writes there, he puts my position exactly and very nicely.
I may need a BUT there too, when I've studied it, but please be clear about the EPR paper.
It is a beauty!
My elements of physical reality are, in my terms, binding spin trajectories associated with the perfect rotational symmetries attaching to fundamental particles.
But I am not a physicist so, if you are, please be very critical of my terminology so that I can improve it.
EDIT: I hope this is not too silly by me but I see some discussion by you on spin: I see fundamental particles as magic gyroscopes subject to binding spin trajectories when disturbed -- elements of physical reality -- the consequence of perfect rotational symmetries. Also this: Their polarizers burn off any extrinsic spin (spin = short term for angular momentum) and re-orient the intrinsic spin. Clarity here would help physicists better understand my theory -- or me correct its terms. Maybe needs separate thread -- for words and diagrams -- this one for mathematics? Thank you again.
Thank you again,
JenniT
  • #41
Dear billschnieder,
This is very helpful to me and I thank you very much for it.
I believe the EPR paper to be very important --- AND well deserving of our deep respect -- plus care in its reading.
I think I cannot better the points that you make ... just maybe add a smiley ... a small feminine touch.
But I am so pleased to see someone reading as closely as I try to do -- BUT writing better and more clearly.
Please: If you are a quantum physicist or physicist of any sort, please be very critical of my words and terminology.
1. I am sure my mathematics can take care of themselves.
2. I am also sure that my seeming direct engagement with elements of physical reality -- when coupled with my somewhat bumbling terminology -- puts most physicists off.
3. So they don't bother with the mathematics -- which I will try to put some up to day.
4. My theory stands or falls solely on the basis of my use of mathematics and probability theory, so if you will look closely at them -- that I would love.
They are not difficult -- in my opinion, sincerely.
Sorry for quick reply -- many thanks -- more soon
JenniT
  • #42
Does this summary by Bohm match your understanding of EPR ?
Despite what billschnieder says (since I disagree with almost everything he says anyway), I think this is a good quote. It covers several important lines of thought from EPR. E.g. realism and completeness.
  • #43
JenniT said:
Dear billschnieder,
JenniT
You are welcome Jenni, I am definitely following this thread closely -- not that I think you need any help with the maths or probability . :wink: Happy 4th.
  • #44
LATE EDIT: THIS POST RE-SUBMITTED AS POST # 49 TO BY-PASS SERVER/TEX CLASH OVER \VBAR. \UPARROW SUBSTITUTED.
Plus some minor clarifications.
Dear Jesse, Thank you for this very thoughtful note. Welcome back:
--------------------------------------------------A study based on Mermin, Spooky actions at a distance: Mysteries of the quantum theory. Encyclopedia Britannica, Chicago - The Great Ideas Today 1988.
NB: The singlet state (used in most EPRB-Bell tests) is invariant under rotations, not just about the line-of-flight axis.
--------------------------------------------------(1) Local realism defined:
[tex]P''(G, G'\vbarH, a, b', \lambda_{k}, \lambda'_{k}) = P(G\vbarH, a, \lambda_{k})*P'(G'\vbarH, b', \lambda'_{k}).[/tex]
(2) Expectation defined:
[tex]P''(G, G'\vbarH, a, b') = \sum_{k=1}^N P_3(\lambda_{k}, \lambda'_{k})*P(G\vbarH, a, \lambda_{k})*P'(G'\vbarH, b', \lambda'_{k}).[/tex]
Scene 1: Alice and Bob -- far far apart -- happily await the arrival of N twins: pairwise correlated photons -- one twin at a time to each, respectively bearing the properties [tex]\lambda_{k}[/tex] and [tex]\lambda'_{k}[/tex]; k = 1 - N.
Alice has a dichotomic polarizer-analyzer [a/ai] which respectively signals G or R as tested photons enter the related output channel. Bob likewise has [b'/bi'] signaling respectively G' or R'. In this experiment, a is an orientation orthogonal to the line-of-flight axis, ai is orthogonal to both a and the line-of-flight axis; primes (') denote elements of reality in Bob's locale; etc.
Alice, with her elegant simplicity, supposes fundamental particles to be magic gyroscopes with perfect rotational symmetries and related binding spin trajectories. She supposes their polarizers to be devices which burn off extrinsic spin and re-orient the intrinsic spin.
Alice supposes that [tex]\lambda_{k}[/tex] and [tex]\lambda'_{k}[/tex] are spin vectors, unconstrained as to length and orientation -- but pairwise correlated by the relevant conservation laws attending their birth. That is, for this experiment, they are pairwise equal and not otherwise.
Recognizing the rotational symmetry of the cosine function, Alice supposes the lambdas to be such that, if only she knew more about them: Without in any way disturbing a photon, she could predict with certainty the positive outcome of any spin-test upon it. Alice writes:
(3)
[tex]P(G\vbarH, a, \lambda_{k}) = (cos^2 (a, \lambda_{k})\vbar H, a, \lambda_{k}) = 0\oplus1 = 0 xor 1.[/tex]
Alice, supposing that elements of physical reality mediate all her assured (certain) positive outcomes, writes:
(4)
[tex]P(G\vbarH, a, \lambda_{k}\hookrightarrow \lambda_{a}) = (cos^2 (a, \lambda_{k})\vbar H, a, \lambda_{k} \hookrightarrow \lambda_{a}) = cos^2 (a, \lambda_{a}) = 1.[/tex]
(5)
[tex]P(R\vbarH, ai, \lambda_{k}\hookrightarrow \lambda_{ai}) = (cos^2 (ai, \lambda_{k})\vbar H, ai, \lambda_{k} \hookrightarrow \lambda_{ai}) = cos^2 (ai, \lambda_{ai}) = 1.[/tex]
In set notation, Alice defines elements of physical reality as CFCs (counterfactual conditionals) -- binding spin trajectories associated with the perfect rotational symmetries of pristine fundamental particles:
(6)
[tex]\{\lambda_{k} \hookrightarrow \lambda_{a}\vbar \,If \,\lambda_{k} \rightarrow [a/ai] \,then \,\lambda_{k} \rightarrow \lambda_{a}\};[/tex]
(7)
[tex]\{\lambda_{k} \hookrightarrow \lambda_{ai}\vbar \,If \,\lambda_{k} \rightarrow [a/ai] \,then \,\lambda_{k} \rightarrow \lambda_{ai}\}.[/tex]So, in Alice's frame of reference:
(8)
(9)
[tex] P_3(\lambda_{k}, \lambda'_{k}) = (1/2)[(\lambda_{k} \hookrightarrow \lambda_{a}, \lambda'_{k} \hookrightarrow \lambda'_{a}) + (\lambda_{k} \hookrightarrow \lambda_{ai}, \lambda'_{k} \hookrightarrow \lambda'_{ai})].[/tex]
(10)
[tex]P''(G, G'\vbarH, a, b') = \sum_{k=1}^N (1/2)[(\lambda_{k} \hookrightarrow \lambda_{a}, \lambda'_{k} \hookrightarrow \lambda'_{a}) + (\lambda_{k} \hookrightarrow \lambda_{ai}, \lambda'_{k} \hookrightarrow \lambda'_{ai})] * (cos^2(a, \lambda_{k})\vbarH, a, \lambda_{k}) * (cos^2(b', \lambda'_{k})\vbarH, b', \lambda'_{k}) =[/tex]
(11)
[tex]\sum_{k=1}^N (1/2)[(cos^2(a, \lambda_{k})\vbarH, a, \lambda_{k} \hookrightarrow \lambda_{a}) * (cos^2(b', \lambda'_{k})\vbarH, b', \lambda'_{k} \hookrightarrow \lambda'_{a}) + cos^2 (a, \vbarH, a, \lambda_{k} \hookrightarrow \lambda_{ai})*(cos^2(b', \lambda'_{k})\vbarH, b', \lambda'_{k} \hookrightarrow \lambda'_{ai})] =[/tex]
(12)
[tex](1/2)cos^2(a', b') + 0.[/tex]
QED: A result in full accord with quantum theory, quantum experiments, and local-realism. (E & O. E.)--------------------------------------------------
In Bob's frame similarly -- detail removed due earlier server/Tex interaction:
(13)
[tex]P''(G, G'\vbarH, a, b') = \sum_{k=1}^N (1/2)[(\lambda'_{k} \hookrightarrow \lambda'_{b}, \lambda_{k} \hookrightarrow \lambda_{b}) + (\lambda'_{k} \hookrightarrow \lambda'_{bi}, \lambda_{k} \hookrightarrow \lambda_{bi})] * (cos^2(a, \lambda_{k})\vbarH, a, \lambda_{k}) * (cos^2(b', \lambda'_{k})\vbarH, b', \lambda'_{k}) = (1/2) cos^2 (a, b).[/tex]
In the frame of God and Albert -- detail removed due earlier server/Tex interaction -- but co-variant:
(14)
[tex]P''(G, G'\vbarH, a, b') = \sum_{k=1}^N (1/4)[(\lambda_{k} \hookrightarrow \lambda_{a}, \lambda'_{k} \hookrightarrow \lambda'_{a}) + (\lambda_{k} \hookrightarrow \lambda_{ai}, \lambda'_{k} \hookrightarrow \lambda'_{ai}) + (\lambda'_{k} \hookrightarrow \lambda'_{b}, \lambda_{k} \hookrightarrow \lambda_{b}) + (\lambda'_{k} \hookrightarrow \lambda'_{bi}, \lambda_{k} \hookrightarrow \lambda_{bi})] * (cos^2(a, \lambda_{k})\vbarH, a, \lambda_{k}) * (cos^2(b', \lambda'_{k})\vbarH, b', \lambda'_{k}) = (1/2) cos^2 (a, b').[/tex]
Edit 2: Alternative: For better TeX display:-
(15)
[tex] P''_3(\lambda_{k}, \lambda'_{k}) = (1/4)[(\lambda_{k} \hookrightarrow \lambda_{a}, \lambda'_{k} \hookrightarrow \lambda'_{a}) + (\lambda_{k} \hookrightarrow \lambda_{ai}, \lambda'_{k} \hookrightarrow \lambda'_{ai}) + (\lambda'_{k} \hookrightarrow \lambda'_{b}, \lambda_{k} \hookrightarrow \lambda_{b}) + (\lambda'_{k} \hookrightarrow \lambda'_{bi}, \lambda_{k} \hookrightarrow \lambda_{bi})].[/tex]
NB: Too-long line of TeX reduced by providing [tex]P''_3(\lambda_{k}, \lambda'_{k})[/tex] only. The reader can readily derive the conclusion as an exercise:
(16)
[tex]P''(G, G'\vbarH, a, b') = (1/2) cos^2 (a, b').[/tex]
PS:
Note that the co-variant derivation produces (correctly, with physical significance) the separated "Alice, Bob" elements of physical reality in the cosine argument. That is: (a, b').
The earlier cosine arguments are also rigorously correct and physically significant -- respectively (a', b') for Alice's frame, (a, b) for Bob's frame -- recalling that a, ai, b, bi are just orientations in 3-space.
With best regards,
JenniT
  • #45
Thank you Bill, and same to you.
And - do you have any suggestions about the physics' terminology?
All suggestions, etc. most welcome.
JenniT
  • #46
NOTE: Re Post 44 --
The server is responding intermittently and variously to my TeX coding.
History:
1. After many hours of frustration, I replaced all | with \vbar, and eliminated several long-lines of TeX code in equations.
2. The server delivered all that revised TeX incorrectly in PREVIEW -- but OK in the THREAD.
3. Checking one-hour later, the server omitted all the |-s (vbars).
4. Checking again, all the | (vbars) and their accompanying H ( - | H - as in the sample spaces of all the Probability Functions) were omitted.
5. As I write this SOME H-s are back but not the |-s (vbars) !
Any suggestions for a stable FIX, please?
Thank you,
Jenni T
EDIT -- see POST #49 for work-around using \uparrow.
  • #47
DrC,
I am not clear how HUP relates to Bell's work?
Does he ever mention it?
How do you bring it into the Bell-scene please?
And with what understanding as to Bell's mathematics, if any?
Thank you,
JenniT
  • #48
Dear DrC,
I agree with you that this is a very good quote contributed by Salman2.
May I suggest, that from now on:
We all HONOR David BOHM by describing all so-called "tests of Bell's theorem" [in my view, they are not -- please discuss -- plus there are other descriptors] that are spin-related as
EPR-Bohm-Bell testss?
OK: How about EPRB-Bell tests?
No BOHM = No Bell?
And Bohm was not wrong, was he? :wink: ON THIS SUBJECT, nb!
Love,
JenniT
  • #49
RE-SUBMISSION OF POST# 44 to minimize server/TeX clash re \vbars. \uparrow substituted.
Some small clarifications added
[tex]P''(G, G' \uparrow H, a, b', \lambda_{k}, \lambda'_{k}) = P(G \uparrow H, a, \lambda_{k})*P'(G' \uparrow H, b', \lambda'_{k}).[/tex]
[tex]P''(G, G' \uparrow H , a, b') = \sum_{k=1}^N P_3(\lambda_{k}, \lambda'_{k})*P(G \uparrow H , a, \lambda_{k})*P'(G' \uparrow H , b', \lambda'_{k}).[/tex]
Scene 1: Alice and Bob -- far far apart -- happily await the arrival of N twins: pairwise correlated photons -- one twin at a time to each, respectively bearing the properties [tex]\lambda_{k}[/tex] and [tex]\lambda'_{k}[/tex] with k = 1 - N. Note: k is a number; other subscripts -- such as a, ai, b, bi -- define spin-orientations in 3-space.
Alice has a dichotomic polarizer-analyzer [a/ai] which respectively signals G or R [often termed V or H] as tested photons enter the related output channel. Bob likewise has [b'/bi'] signaling respectively G' or R' [perhaps termed V' or H']. In this experiment, a is an orientation orthogonal to the line-of-flight axis, ai is orthogonal to both a and the line-of-flight axis; primes (') denote elements of reality in Bob's locale; etc.
(3)
[tex]P(G \uparrow H , a, \lambda_{k}) = (cos^2 (a, \lambda_{k}) \uparrow H, a, \lambda_{k}) = 0\oplus1 = 0 xor 1.[/tex]
(4)
[tex]P(G \uparrow H , a, \lambda_{k}\hookrightarrow \lambda_{a}) = (cos^2 (a, \lambda_{k}) \uparrow H, a, \lambda_{k} \hookrightarrow \lambda_{a}) = cos^2 (a, \lambda_{a}) = 1.[/tex]
(5)
[tex]P(R \uparrow H , ai, \lambda_{k}\hookrightarrow \lambda_{ai}) = (cos^2 (ai, \lambda_{k}) \uparrow H, ai, \lambda_{k} \hookrightarrow \lambda_{ai}) = cos^2 (ai, \lambda_{ai}) = 1.[/tex]
(6)
[tex]\{\lambda_{k} \hookrightarrow \lambda_{a} \uparrow \,If \,\lambda_{k} \rightarrow [a/ai] \,then \,\lambda_{k} \rightarrow \lambda_{a}\};[/tex]
(7)
[tex]\{\lambda_{k} \hookrightarrow \lambda_{ai} \uparrow \,If \,\lambda_{k} \rightarrow [a/ai] \,then \,\lambda_{k} \rightarrow \lambda_{ai}\}.[/tex]So, in Alice's frame of reference:
(8)
(9)
(10)
[tex]P''(G, G' \uparrow H , a, b') = \sum_{k=1}^N (1/2)[(\lambda_{k} \hookrightarrow \lambda_{a}, \lambda'_{k} \hookrightarrow \lambda'_{a}) + (\lambda_{k} \hookrightarrow \lambda_{ai}, \lambda'_{k} \hookrightarrow \lambda'_{ai})] * (cos^2(a, \lambda_{k}) \uparrow H , a, \lambda_{k}) * (cos^2(b', \lambda'_{k}) \uparrow H , b', \lambda'_{k}) =[/tex]
(11)
[tex]\sum_{k=1}^N (1/2)[(cos^2(a, \lambda_{k}) \uparrow H , a, \lambda_{k} \hookrightarrow \lambda_{a}) * (cos^2(b', \lambda'_{k}) \uparrow H , b', \lambda'_{k} \hookrightarrow \lambda'_{a}) + cos^2 (a, \lambda_{k} \uparrow H , a, \lambda_{k} \hookrightarrow \lambda_{ai})*(cos^2(b', \lambda'_{k}) \uparrow H , b', \lambda'_{k} \hookrightarrow \lambda'_{ai})] =[/tex]
(12)
(13)
[tex]P''(G, G' \uparrow H , a, b') = \sum_{k=1}^N (1/2)[(\lambda'_{k} \hookrightarrow \lambda'_{b}, \lambda_{k} \hookrightarrow \lambda_{b}) + (\lambda'_{k} \hookrightarrow \lambda'_{bi}, \lambda_{k} \hookrightarrow \lambda_{bi})] * (cos^2(a, \lambda_{k}) \uparrow H , a, \lambda_{k}) * (cos^2(b', \lambda'_{k}) \uparrow H , b', \lambda'_{k}) = (1/2) cos^2 (a, b).[/tex]
(14)
[tex]P''(G, G' \uparrow H , a, b') = \sum_{k=1}^N (1/4)[(\lambda_{k} \hookrightarrow \lambda_{a}, \lambda'_{k} \hookrightarrow \lambda'_{a}) + (\lambda_{k} \hookrightarrow \lambda_{ai}, \lambda'_{k} \hookrightarrow \lambda'_{ai}) + (\lambda'_{k} \hookrightarrow \lambda'_{b}, \lambda_{k} \hookrightarrow \lambda_{b}) + (\lambda'_{k} \hookrightarrow \lambda'_{bi}, \lambda_{k} \hookrightarrow \lambda_{bi})] * (cos^2(a, \lambda_{k}) \uparrow H , a, \lambda_{k}) * (cos^2(b', \lambda'_{k}) \uparrow H , b', \lambda'_{k}) = (1/2) cos^2 (a, b').[/tex]
Edit 2: Alternative for God and Albert's frame: For better TeX display:-
(15)
(16)
[tex]P''(G, G' \uparrow H , a, b') = (1/2) cos^2 (a, b').[/tex]
PS:
With best regards,
JenniT
  • #50
Dear Jesse, Welcome back; and any others:
Question: How do I fix Equation (14) above -- copied below.
A long line of TeX coding does not wrap?
Is there a TeX WRAP command?
Thanks,
JenniT
--------------------------------------------------(14)
  • #51
I think it is double back-slash, but it does not work in the forum. You may have to use two separate tex blocks.
(14)
[tex]P''(G, G'|H , a, b') = \sum_{k=1}^N \frac{1}{4}[(\lambda_{k} \hookrightarrow \lambda_{a}, \lambda'_{k} \hookrightarrow \lambda'_{a}) + (\lambda_{k} \hookrightarrow \lambda_{ai}, \lambda'_{k} \hookrightarrow \lambda'_{ai}) + (\lambda'_{k} \hookrightarrow \lambda'_{b}, \lambda_{k} \hookrightarrow \lambda_{b}) [/tex]
[tex]
+ (\lambda'_{k} \hookrightarrow \lambda'_{bi}, \lambda_{k} \hookrightarrow \lambda_{bi})] * (cos^2(a, \lambda_{k}) | H , a, \lambda_{k}) * (cos^2(b', \lambda'_{k}) | H , b', \lambda'_{k}) = \frac{1}{2} cos^2 (a, b').[/tex]
  • #52
(14)
[tex]
Dear billschnieder,
Great, many thanks. I love it when great minds think alike. :redface: I HAD that in the early submissions but deleted it and more when the vbar problem kept occurring. &&^%$. But I am a beginner - :smile: - in TeX.
Question: Are you happy with me using P in all the equations? Rather than E in some?
I am thinking that Eqn (2) should stay with a P but change its intro to Joint probability defined?
Note: I hope I avoid the need for E anywhere here, actually; whereas Bell should have used E in his 1964 (2). But his P arguments were over A and B, not G and G', like mine?
E of course comes later when we combine the 4 P-s with their signs.
Also: Once we have one correct P, consistent with QM -- then we know the E will be correct too?
EDIT: I am not yet brave enough to re-edit Post #49 again, so will tidy it up in a new Post after some more comments are received.
Thank you again,
JenniT
  • #53
JenniT said:
Dear billschnieder,
You are correct, (2) is a marginalization with respect to (λ,λ'), not an expectation. Not sure about what name is appropriate since (1) is also a joint probability.
Bells (2) is an Expectation is because he is multiplying the functions A(.), B(.) with the probability P(λ) and integrating/Summing over all λ. A(.), and B(.) are not probability distributions but two-valued functions (+1, -1). In your case, G, G' are also two valued functions (0,1). Is this correct?
Are you referring to equation (9). I do not understand what you are doing in equation (9) within the square brackets. I can see it lists all the possibilities for how a specific pair of (λ, λ') can be transformed during the interaction but is not clear to me what you are adding up within the square brackets, number of case instances?
  • #54
Looks like we're out of my comfort zone and right into yours -- which is good.
Please be insistent here.
I'd like to be accurate and reflect the standards accepted by the relevant disciplines.
What about: Name (1) = Local realism defined via stochastic independence?
What about: Name (2) = Local realism defined via marginalization over local beables?
I think not. G, G' are discrete outcomes.
(9) uses JesseM's notation re P3. I'm OK with that. I personally use rho(λ, λ'), it being a normalized probability distribution (in my perhaps loose terms)? Is rho reserved for continuous distributions only?
[x], x = all the equiprobable [edit: hence the 1/2 out front] mutually-exclusive collectively-exhaustive beables. The beauty of the theory is that's all there are ... as far as Alice is concerned. Yes?
Are you OK with the use of Bell's term beables?
EDIT: In co-variant (15) there are 4 equiprobable [hence the 1/4 out front] mutually-exclusive collectively-exhaustive beables. OK?
Thanks,
JenniT
  • #55
Not trying to be pendantic but what about
(1) = Local realism defined ...
(2) = Marginalized over local beables
Ah, I see.
Still having problems. Let's use a coin analogy, we have two coins (CC') with mutually exclusive equi-probable outcomes HH', HT', TH', TT'
I can understand why you may write P(H,H') = 1/4,
What I don't understand is why you would write it as 1/4[(H,H')+(H,T') +(T,H') + (T,T')]
If the terms within [.] represent probabilities, then each term in the square bracket is 1/4 and they necessarily sum up to 1 no? Are you trying to list all the equi-probable outcomes? If so it could be made clearer if you put that in a sentence and simply state that P(H,H') = 1/4 and be done with it.
I welcome the term.
  • #56
1. You will never hear me object to pedantry.
2. I usually go with Bell's Cuisine idea that these equations are consequences of local causality. Any objection or pedantic improvement? Please let me know.
billschnieder said:
Ah, I see.
Good.
OK.
It is a density; a normalised probability distribution?
Stop. What is in [.] are not probabilities. They are the 4 possible outcomes, each equiprobable, so put the 1/4 in front of [.]. Then you have your normalized distribution.
Perhaps I am using terms incorrectly?[/QUOTE]
Yes, that is what I am trying to do.
NB: BUT if I do not list them all, no one seems to see the consequent picture?
Incidentally. Ignore that Alice and Bob stuff here.
I need a co-variant distribution over the whole sample space, and I need readers to see that I have such. So it is the God view that is important. Alice and Bob are but angels in this business.
billschnieder said:
I welcome the term.
Great to hear that.
Thanks,
JenniT
  • #57
Hi Jenni, sorry about the delay, I ended up being away from my apt. most of this week...
(3)
I'm not sure I understand, are you saying the angle between a and the spin vector is always going to be either 90 or 0, so that cos^2 of the angle between them is always 0 or 1? This would seem to require that the source "know in advance" what setting Alice was going to choose so it always created the particle with a spin vector parallel or orthogonal to Alice's setting, a violation of the "no-conspiracy condition" which appears in rigorous versions of Bell's proof (this condition says that P(λ) = P(λ|a), i.e. there is no correlation between hidden variables and the choice of detector setting). I suppose your condition that a and ai are orthogonal implies that the source doesn't have to know which specific choice Alice makes on each specific trial (since a lambda parallel/orthogonal to a will automatically be orthogonal/parallel to ai), but it still has to "know" the two possible angles Alice is choosing from and make sure it only emits lambdas parallel/orthogonal to them. And of course Bell's own proof does not restrict the choice of detector angles to all be parallel/orthogonal to one another, you could have an experiment with three settings a1=0, a2=60, and a3=120 for example.
(4)
(5)
OK, so λa just means a spin vector parallel to Alice's detector setting a, right? Your notation is odd--I think [tex]P(G \uparrow H , a, \lambda_{k}\hookrightarrow \lambda_{a})[/tex] means "the probability of result G given experiment H, detector setting a, and a value of k such that [tex]\lambda_k = \lambda_a[/tex]"...if that's right, I think it would be more in line with standard notation conventions to write it as [tex]P(G | H, a, \lambda_k = \lambda_a )[/tex]
(6)
(7)
I don't follow this. What "set notation" do you mean? What does the uparrow represent? Earlier you seemed to just replace the | denoting conditional probability with an uparrow, but these equations don't seem to be expressing conditional probabilities. Can you explain in words what these equations are saying?
(8)
(9)
Is the right side of equation 9 supposed to involve probabilities? If so I think it would make more sense to write it as [tex] P_3(\lambda_{k}, \lambda'_{k}) = (1/2)[P(\lambda_{k} = \lambda_{a}, \lambda'_{k} = \lambda'_{a}) + P(\lambda_{k} = \lambda_{ai}, \lambda'_{k} = \lambda'_{ai})][/tex]...is that OK? Even so the equation is a little unclear, does the 1/2 just mean you assume [tex]P(\lambda_{k} = \lambda_{a}, \lambda'_{k} = \lambda'_{a}) = 1/2[/tex] and [tex]P(\lambda_{k} = \lambda_{ai}, \lambda'_{k} = \lambda'_{ai}) = 1/2[/tex], i.e. these are the only two possible ways the source can emit spin vectors and both ways are equally probable? Then the sum of the two would be 1, and you'd have to multiply that by 1/2 to get [tex] P_3(\lambda_{k}, \lambda'_{k})[/tex] for any specific value of k (k=a or k=ai). If that's the idea, I think it would be a lot less convoluted to just say that k can only take one of two values, k=a or k=ai, (which could perhaps be represented by the numerals 1 and 2, so the sum would just be [tex]\sum_{k=1}^2[/tex]) and that either way [tex]P_3(\lambda_{k}, \lambda'_{k}) = 1/2[/tex]. In that case we could go from equation (8) to a simplified version of (10):
[tex]P''(G,G'|H,a,b') = \sum_{k=1}^2 (1/2)*(cos^2(a,\lambda_k)|H,a,\lambda_k)*(cos^2(b',\lambda_k)|H,b,\lambda_k)[/tex]
Let me know what you think of my comments/questions/suggested changes to notation so far, then we can proceed.
  • #58
The angle between a and the spin vector is always going to be either 90 or 0, so that cos^2 of the angle between them is always 0 or 1. That is what polarizers do: They orient the randomly arriving (and so randomly specified k) particles in just that way.
So I believe that your questions should move to the random specifications? Yes?
Especially as you fix my notation below with an impossibility. Which is not a criticism of you at all -- just an excellent way to show what I cannot say. AND MY notation sure could do with some help -- to make it more "standard" to the disciplines of maths and physics.
Oh NO, goodness NO!
Could I get away with that!?
Really, that would be too easy, surely? Yes?
As I see it: This is the standard trick in QM -- as I say, as I see it.
You are assigning to an unmeasured photon a property that has probability zero prior to any measurement. It at the same time being a property that the subject photons will certainly have after the measurement interaction?
You have here the crux of my case, I think?
See note given earlier, below. Is that OK? How would you word it?
NOW please see here, and note please: Any specific value of k (k=a or k=ai) has probability zero before a test and equiprobable certainty after a test. This simple dichotomy being the basis of our 2 lovely equivalence classes.
How would you put this FACT in your words and notation, please?
Also: Avoiding that zero-probability clash -- how about this?
What if we said something like this?
''Whereas before k was a number -- k = 1- N -- we now let k = 1 be the proxy for all the twins in equivalence class 1, and k = 2 be the proxy all the twins in equivalence class 2.''
How might you word that to be compatible with your specialist discipline?
Dear Jesse, so glad to learn that you are back home, safe and sound, and in good form -- from what I see here.
This is just a short reply to say "many thanks" again. And to knock off some rough edges.
1. To the last para: OK, will do.
2. The \uparrow was used to by-pass my big-time server clashes with too many \vbars. It is to be read as \vbar throughout (despite how much I like it as it is).
3. The set notation piece is simply saying that we are defining (just two will do) disjoint sets by giving the condition that the elements of each set must satisfy.
4. I think I see again the lovely simplification that billschnieder pointed out. Thanks to you too for that.
Pardon my caution in not replying too quickly: I need to be sure that absolutely nothing is lost or presumed when we simplify stuff.
PS: Some EDITS inserted above by me might help you comment progressively? I hope they do not confuse you?
More soon,
XXOOXXOO
Jenni
  • #59
So do you mean the λk in cos^2(a, λk) refers to the angle of the particle's spin vector after it's been reoriented by the polarizer (when the angle between λk and a is always guaranteed to be 0 or 90), not the angle of the spin vector given to the particle when it's first sent out by the source, before any such reorientation? Is cos^2 supposed to be the probability it will pass through the polarizer (so the polarizer is imagined to first reorient, then allow to pass through or not) or is it the probability of something else happening after passing through it, and if so what?
Also, do the polarizers reorient the spin vectors in a deterministic way, so that if both polarizers are at the same angle and both spin vectors start out at the same k before passing through the polarizer, they are guaranteed to both end up parallel or both end up orthogonal, with no chance of one ending up parallel to the polarizer and one ending up orthogonal? If so we can say that at the moment the two particles first begin their journey from the source, their initial spin vectors should give them a predetermined answer to what direction they would end up if they met a polarizer at any given angle, right? For example, we might have a situation where one particle's initial spin vector (the spin vector assigned to it by the source, prior to encountering the polarizers) is such that it if it encountered a polarizer at a=30 it would be predetermined to end up parallel to it, predetermined to come out orthogonal a polarizer at a=60, and predetermined to come out parallel to a polarizer at a=120. Is this how you see things, or do you not agree that the angle of the initial spin vector plus the angle of the polarizer should deterministically generate the angle of the spin vector after being reoriented by the polarizer?
JenniT said:
Oh NO, goodness NO!
"No" to what? Is my English summary of the meaning of your equation as "the probability of result G given experiment H, detector setting a, and a value of k such that [tex]\lambda_k = \lambda_a[/tex]" incorrect? And given your point about "reorientation" here which I hadn't caught before, does λk in this equation represent the angle of the spin vector after it's been reoriented by the spin vector (when it's guaranteed to be parallel or orthogonal to a) or to the spin vector prior to reorientation? Also, does λa mean a spin vector parallel to a, with λai representing a spin vector orthogonal to a?
What property are you talking about?
I'll wait for your answers before continuing...
  • #60
As I see it, we are dealing with Probability Functions. They map a subset of the Sample Space to [0, 1].
λk is the angle of the spin vector given to the particle when it is first sent out by the source.
If that were not the case, it would be written λX, or something.
Any change in the sample space relating to λk will be reflected in the mapping.
It is my understanding that polarizers deterministically re-orient the spin.
So the Sample Space changes ... so the mapping changes correspondingly.
Doesn't it have to be the first?
This is Mermin's baby. In my view the answer here is Yes.
If it is something else, like a different singlet state, we just change the correlation and proceed.
That is correct.
Is that what is required?
JesseM said:
For example, we might have a situation where one particle's initial spin vector (the spin vector assigned to it by the source, prior to encountering the polarizers) is such that it if it encountered a polarizer at a=30 it would be predetermined to end up parallel to it, predetermined to come out orthogonal a polarizer at a=60, and predetermined to come out parallel to a polarizer at a=120. Is this how you see things,...
Yes.
IS THAT HOW IT SHOULD BE? Sorry for caps - hit wrong key.
JesseM said:
... or do you not agree that the angle of the initial spin vector plus the angle of the polarizer should deterministically generate the angle of the spin vector after being reoriented by the polarizer?
Does that question make sense?
The angle of the initial spin vector plus the angle of the polarizer deterministically generate the NEW angle of the spin vector WITHIN THE the polarizer. THE PHOTON THEN ENTERS THE RELEVANT ANALYZER CHANNEL.
JesseM said:
"No" to what? Is my English summary of the meaning of your equation as "the probability of result G given experiment H, detector setting a, and a value of k such that \lambda_k = \lambda_a" incorrect?
Yes. This property ... \lambda_k = \lambda_a ... has probability zero before the test!
Do you see that?
JesseM said:
And given your point about "reorientation" here which I hadn't caught before, does λk in this equation represent the angle of the spin vector after it's been reoriented by the spin vector [SIC] POLARIZER Yes?
No -- see above re Sample Space. You can't change λk in the trig argument except via the SS.
Yes.
This property \lambda_k = \lambda_a has probability zero before the test!
Regards,
JenniT
  • #61
No, (9) is meant to represent a discrete normalized probability distribution. So LHS says what it is and RHS gives the normalized distribution.
If this were a continuous case then RHS would be written with delta-functions.
Does this last comment help?
As explained in earlier reply: These equalities have probability zero prior to measurement.
Do you now agree?
Yes, but you have to see that we simply cannot go with those equality signs.
We have to go with the characteristic spin-related transformation symmetries that define the equiprobable etc. equivalence classes (EC).
Check what I said in earlier reply, please.
k_1 now denotes the defining condition for EC_1, k_2 the defining condition for EC_2.
Do you go with that?
Well I don't see how this gives any output??
If you change it to this, well OK:
[tex]P''(G,G'|H,a,b') = \sum_{k=1}^2 (1/2)*(cos^2(a,\lambda_k)|H,a,\lambda_k = \lambda_1)*(cos^2(b',\lambda_k)|H,b, \lambda_k = \lambda_1[/tex],
where lambda_1 is defined by the \uparrow business -- which is a discriminator between the ECs.
And, for completeness you include the equivalent expression for lambda_2 -- which is also is defined by the \uparrow business -- it being also a discriminator between the ECs. Though this addition = 0, on summation, it is needed for completeness.
Which is all getting messy for me, and surely for you?
Thanks, as always,
Jenni
  • #62
OK, so you were using the horizontal arrow in [tex]P(G \uparrow H , a, \lambda_{k}\hookrightarrow \lambda_{a})[/tex] to represent the possibility that the initial spin vector λk was changed to the new spin vector λa as the particle passed through the polarizer, correct? If so my earlier interpretation of the equation was wrong so much of my subsequent discussion of your equations was based on wrong premises, we should step back and start from here.
JenniT said:
That is correct.
Yes, that's what Bell would assume must be true under local realism where the experimenters choose detector angles randomly and always find that same detector angle=same result...it must be true (under local realism and the given experimental conditions) that the particles had identical predetermined responses for each detector angle (so presumably the source always emits pairs of particles with hidden variables that give them identical predetermined responses).
JenniT said:
Yes.
Yes, according to local realism. OK, so let's focus on this issue for now. Given that each λk gives predetermined responses to each polarizer angle, would you agree that if the experimenters are choosing between three polarizer angles 0, 60, and 120, we can define a new variable Li with only 8 possible values, like this:
L1 means the original λk was such that the particle would be predetermined to pass through setting 0, to pass through setting 60, and to pass through setting 120. We can denote this 0+, 60+, 120+
L2 means the original λk was such that the particle would be predetermined to pass through setting 0, to pass through setting 60, but not to pass through setting 120. We can denote this 0+, 60+, 120-
L3: 0+, 60-, 120+
L4: 0+, 60-, 120-
L5: 0-, 60+, 120+
L6: 0-, 60+, 120-
L7: 0-, 60-, 120+
L8: 0-, 60-, 120-
So no matter what direction λk is on any given trial, it must be associated with a single value of Li, one of the 8 possible values above. Agreed? And to explain the fact that the experimenters always get identical results when they both choose the same polarizer angle, we must assume that on each trial, each particle has an identical value of Li...e.g. if the particle sent to Alice has an initial spin vector λk that can be classified as L5, then the particle sent to Bob must also have an initial spin vector that can be classified as L5. Would you agree with this so far?
  • #63
L3: 0+, 60-, 120+
L4: 0+, 60-, 120-
L5: 0-, 60+, 120+
L6: 0-, 60+, 120-
L7: 0-, 60-, 120+
L8: 0-, 60-, 120-
OK, thank you very much for these clarifications.
I think I am saying Yes to all the above; but maybe you should explain this small piece:
Q1: Why only 8?
Q2: Would it be better to discuss GHZ?
PS: Like, have you checked your mail-box?
Thank you,
JenniT
  • #64
Q1: Why only 8?
Because the point of Li is just to specify which of two possible binary measurement results (+ or -) would be predetermined to occur for each of the three polarizer settings. Eight is the total number of possible combinations of +'s and -'s for the three angles:
0+, 60+, 120+
0+, 60+, 120-
0+, 60-, 120+
0+, 60-, 120-
0-, 60+, 120+
0-, 60+, 120-
0-, 60-, 120+
0-, 60-, 120-
The point I'm getting at is just about whether cos^2(a-b) could be possible for the types of hidden variables theory you're assuming. I want to show that, given the assumption that every λk falls into one of the above 8 categories of predetermined responses above, it's impossible to get cos^2(a-b) for the probability they both get the same response when they choose different polarizer angles (note that for the polarizer angles 0, 60, and 120, if Alice and Bob choose different angles, cos^2(a-b) will always be equal to 0.25)
Yup, sorry for the delay on that!
  • #65
0+, 60+, 120+
0+, 60+, 120-
0+, 60-, 120+
0+, 60-, 120-
0-, 60+, 120+
0-, 60+, 120-
0-, 60-, 120+
0-, 60-, 120-
I'm also sorry for the delay too.
But note that lambda has to deliver results at any combination of any angular settings; so OK; please go ahead and demonstrate the point. If it fails at 8, I guess you'd agree it fails at a countable infinity of angular settings also. Right?
PS: On a related point, could you briefly explain what I should understand by spin? For example, photons are spin 1; electrons spin 1/2. What does this difference mean? What are its consequences, please? If someone said that electrons were spin 1, photons spin 2, would the world crumble? Why would they be wrong? Could an EPR-Bohm test shoot them down? Or some other test?
You guessed: I'm not very much into QM; mainly maths. Hope you can help; thanks.
Jennifer
  • #66
OK, good. So that I understand what is going on: Please be sure to show the QM result for however you arrive at your conclusion with the above assumptions, please.
Must run, J
  • #67
Right, although any given Bell test will involve only a small number of possible angular settings for the experimenters to choose from, like the three possible settings 0, 60 and 120 that I assumed are available to Alice and Bob. Of course, it's arbitrary what set of angles we choose to make available, I just chose 0, 60 and 120 for convenience.
So, assume that on each trial Alice and Bob choose their settings randomly, and independently. Then in the limit as the number of trials goes to infinity, each possible combination of settings will occur equally frequently--for example (Alice:60, Bob:120) occurs on the same fraction of trials as (Alice:120, Bob:0).
On each trial, both particles have the same value for Li (for example on any trial where Alice's particle has a λk corresponding to L5, Bob's particle also has a λk corresponding to L5). This means that in the subset of trials where Alice and Bob both chose the same detector setting, they always get the same measurement result with probability 1. But what if we look at the subset of trials where they chose different settings, what is the probability they got the same measurement result in that case? Here we want the conditional probability that they get the same result given that they chose different settings, which we can write as P(same measurement result | Alice&Bob chose different measurement settings).
Now, under the type of hidden variables theory you are proposing, would you agree we can break this up into the following sum?
P(same measurement result | Alice&Bob chose different measurement settings) =
P(same measurement result | Alice&Bob chose different measurement settings AND L1)*P(L1) +
P(same measurement result | Alice&Bob chose different measurement settings AND L2)*P(L2) +
P(same measurement result | Alice&Bob chose different measurement settings AND L3)*P(L3) +
P(same measurement result | Alice&Bob chose different measurement settings AND L4)*P(L4) +
P(same measurement result | Alice&Bob chose different measurement settings AND L5)*P(L5) +
P(same measurement result | Alice&Bob chose different measurement settings AND L6)*P(L6) +
P(same measurement result | Alice&Bob chose different measurement settings AND L7)*P(L7) +
P(same measurement result | Alice&Bob chose different measurement settings AND L8)*P(L8)
If you agree this sum is valid, consider an individual term like P(same measurement result | Alice&Bob chose different measurement settings AND L5). L5 was 0-, 60+, 120+. Would you agree that since two predetermined results are + and one is -, the only way they can both get the same measurement result is if they both chose settings with predetermined result +? And would you agree that if we know Alice chose her setting randomly, there should be a 2/3 chance she chose a setting with predetermined result + (i.e. either 60 or 120), and if we know Bob also chose randomly and we are dealing with a trial where his setting was different from Alice's, there is a 1/2 chance he chose the other setting with predetermined result +? In other words, do you agree that P(same measurement result | Alice&Bob chose different measurement settings AND L5) = (2/3)*(1/2) = 1/3? Another way of seeing this is just by considering all possible ways they can choose different settings, and what their results will be given particles in state L5:
(Alice:0, Bob:60): different measurement results (Alice-, Bob+)
(Alice:0, Bob:120): different measurement results (Alice-, Bob+)
(Alice:60, Bob:0): different measurement results (Alice+, Bob-)
(Alice:60, Bob:120): same measurement results (Alice+, Bob+)
(Alice:120, Bob:0) different measurement results (Alice+, Bob-)
(Alice:120, Bob:60) same measurement results (Alice+, Bob+)
So, in 2 out of the 6 possible cases where they choose different settings, they get the same result, meaning P(same measurement result | Alice&Bob chose different measurement settings AND L5) = 2/6 = 1/3.
If you agree with this, it's not hard to see why P(same measurement result | Alice&Bob chose different measurement settings AND L2) would also equal 1/3 (since here you also have two + and one - for the predetermined results), and likewise for L3, L4, L6 and L7, which we might call the "inhomogenous states" since they each involve two predetermined results of one type and one of the other. On the other hand, for the "homogenous" states L1 and L8 where all three predetermined results are the same, then even if they choose different settings they are guaranteed to get the same result, so P(same measurement result | Alice&Bob chose different measurement settings AND L1) = P(same measurement result | Alice&Bob chose different measurement settings AND L8) = 1.
Let me know whether you agree with all of this so far, and if so I'll continue, if not I'll try to elaborate on whatever you're unclear about in the above.
  • #68
Pray, good sir; please continue -- this is getting interesting -- must rush; J xxoo
  • #69
OK, if you agreed that P(same measurement result | Alice&Bob chose different measurement settings AND Li) would be equal to 1/3 if Li was L2, L3, L4, L5, L6 or L7, and you also agreed that it would be equal to 1 if Li was L1 or L8, then this equation:
...would reduce to this:
P(same measurement result | Alice&Bob chose different measurement settings) = 1/3*[P(L2) + P(L3) + P(L4) + P(L5) + P(L6) + P(L7)] + 1*[P(L1) + P(L8)]
Now, we don't know the value of each P(Li), they represent the frequencies that the source sends out pairs of particles with different values of Li, which would depend on how the source works in the context of our hidden-variables theory. But we do know that the sum of all 8 probabilities must be 1 since those are the only possible values for Li, so [P(L2) + P(L3) + P(L4) + P(L5) + P(L6) + P(L7)] + [P(L1 + P(L8)] = 1.
If [P(L2) + P(L3) + P(L4) + P(L5) + P(L6) + P(L7)] = 1 while [P(L1 + P(L8)] = 0, then that would mean P(same measurement result | Alice&Bob chose different measurement settings) = 1/3. If [P(L2) + P(L3) + P(L4) + P(L5) + P(L6) + P(L7)] = 0 while [P(L1 + P(L8)] = 1, that would mean P(same measurement result | Alice&Bob chose different measurement settings) = 1. If both [P(L2) + P(L3) + P(L4) + P(L5) + P(L6) + P(L7)] and [P(L1 + P(L8)] have values between 0 and 1 (which together add up to one), then that would mean P(same measurement result | Alice&Bob chose different measurement settings) is somewhere between 1/3 and 1. In any case, according to this type of hidden variables theory it must be true that P(same measurement result | Alice&Bob chose different measurement settings) is larger than or equal to 1/3. Do you agree?
If so, it becomes easy to see why this type of hidden variables theory can't reproduce the cos^2 relationship predicted by QM. If the three angles are 0, 60, and 120, then on any trial where Alice and Bob pick different detector angles, the probability of getting the same result according to QM will always be 0.25, since cos^2(120 - 0) = cos^2(120 - 60) = cos^2(60 - 0) = cos^2(60 - 120) = cos^2(0 - 60) = cos^2(0 - 120) = 0.25, which is smaller than 1/3.
  • Quantum Physics
  • Quantum Physics
