Are black holes explained by complex analysis?
In summary, the center of a black hole is not essentially a point at infinity, but rather a finite size with a very high density. The gravity of the large mass still exists and the measure of the mass determines the EH boundry, but the mass (or density) is not infinite.
Hercuflea
596
49
Is the center of a black hole essentially a pole, or a "point at infinity"? I always thought about this in my complex analysis class because one variable complex functions are 4 dimensional, which could translate into space-time. Black holes have to have infinite density in their center, too, right? And the extremely strong gravitational field would basically make time go to zero?
Astronomy news on Phys.org
I'm not sure what you mean by "pole" but most recent accepted theory is that the "center" of a black hole is not a zero-point singularity. The "center" must have a finite size of at least a Planck length: (1.61624 × 10-35 m).
Infinities simply do not work in math, and a zero-size point of any mass would require infinite mass, which we know is not the case since black hole masses can be measured and are definitely not infinite.
The "old" zero-point/infinite mass "singularity" definition has been dropped as far as I have read recently.
So does time practically stop at the center of a black hole because of the immense gravitational field?
To any "outside observer", time appears to stop at the Event Horizon (EH) which is an "effect" at: 2Gm/c^2 or at the poles (only) of an "Ergosphere" where the gravity curves space-time back into a "loop" returning to the interior of the EH boundry. (That is definitely a non-technical description)...:biggrin:
Inside the BH, time would seem to continue for any observer who might survive. Most PF posters are aware (I think) that an observer (human?) could survive inside the EH if the BH was large enough so that the gravitational pull at the EH was not strong enough to cause the "spaghetti effect". Near a small BH, the "spaghetti effect" would tear any matter apart, even individual atoms, before the EH was reached.
Yes, but the OP is asking about the center of the black hole, which he presumably meant the singularity, not the horizon.
Mathematically you cannot extend any curve in spacetime pass the black hole singularity, so practically time "ends".
Having said that, of course we don't really know what happens at (and very close to) the singularity since general relativity should get corrections in that regime.
Huh? I don't get that. Infinities work perfectly well in math. It's in PHYSICS that they don't work.
I don't get that either. It does imply infinite DENSITY, but how do you get that it implies infinite mass?
agreed
Agreed, but what I meant to explain is that a "signularity" as defined 10-15 years ago doesn't exist. The "center" of a BH has a finite size with a very large density but not an infinite density.
Take any sized finite volumn you can think of; maybe a sphere with a diameter of 1 Planck length, or a basketball. How can you fill that volumn to infinite density without using an infinite amount of mass? I can't think of a way to accomplish that.(?) That's how it implies infinite mass.
p=m/V.
...Black holes have to have infinite density in their center, too, right? And the extremely strong gravitational field would basically make time go to zero?
No. Nobody knows either of those.
GR and QM breakdown in the vicinity of the singularity...In any case, as you approach such a 'point', quantum foam seems to blur space, time, mass etc...We just do not yet have a theory that works in those conditions.
p=m/V.
Exactly. P=m/V, so finite mass and zero volume gives infinite density. Why do you think infinite mass is required?
This seems to tie in with your being wrong about infinities not working in math, which they do. Do you not get that 3/0 = infinity?
:uhh:
But, my point is that there is nothing with zero volumn! If zero-volumn is considered, then whatever it may be called just doesn't exist. This is "General Astronomy" so go to some other more advanced forums, or many recent (last 5 years) papers published by "well-known" astrophysicists and see what they have to say about "zero-point" singularities.
Yes, I get that one. How about ∞/∞? Is that = to 1? Is that a prime number? How about ∞-1/∞? Same number? Mathematicians can can play around with many "infinity tricks" but as someone once said, Infinities might work in math but not in physics.
Black Holes are physical entities with only 4 "detectible" properties, as opposed to Wheeler's original 3 "no-hair" properties. I have (long ago) posted at least 3-4 separate posts regarding the four properties, yet still today books, and PF posts, ignore that. And the gravity of a BH is proportional to its finite mass. If we have to use any infinities to describe any properties of a BH, then all that can be said is that "we don't know". (I saw that on TV)
That argument is erroneous.
The way you deduce infinite density is by assuming zero volume and a finite mass. If you accept the conclusion of infinite density but then reject the assumption of zero volume in favor of a different assumption of non-zero volume, you are committing an error.
You can't have your cake and eat it too.
A real mathematician would probably say that a finite mass divided by a zero volume is undefined rather than infinite. Or he would admit that he's not working in the field of real numbers but rather in some compactification thereof. A physicist is not bound by those rules. But he is bound to not call the volume zero in one breath and non-zero in the next.
You didn't get my meaning. I will never "accept the conclusion of infinite density" OR accept any assumption of zero volume.
I never called any "volume" zero; it is exactly that which I have been posting about.(Against?)
I think that we generally agree but have a "semantics" problem going on here.
Post 2 by you. "Zero-size point".
That you accepted it for purposes of a reductio ad absurdum is irrelevant. You are not allowed to have it both ways in the same argument.
From Post 2:
What else can I say? Other people refer to "zero-point" something(?) but I'm saying no such thing. No reply is needed, PLEASE!
1. What is complex analysis?
Complex analysis is a branch of mathematics that deals with the study of complex numbers. It involves the analysis of functions and their properties in the complex plane, which is the set of all complex numbers. Complex analysis is used in various fields of science, including physics and engineering.
2. How does complex analysis relate to black holes?
Complex analysis is used in the study of black holes because it allows scientists to model the behavior of black holes using mathematical equations. These equations involve complex numbers and are used to understand the properties and behavior of black holes, such as their mass and the effects of gravity on their surroundings.
3. Can complex analysis fully explain black holes?
While complex analysis is an important tool in the study of black holes, it is not the only factor that can explain their existence. The theory of general relativity, proposed by Albert Einstein, is also used to understand the nature of black holes. Other fields of physics, such as quantum mechanics, may also play a role in fully explaining black holes.
4. How does complex analysis help us understand the event horizon of a black hole?
The event horizon of a black hole is the point of no return, where the gravitational pull is so strong that nothing, not even light, can escape. Complex analysis is used to calculate the size and shape of the event horizon for different types of black holes, providing insight into the behavior of matter and light near the event horizon.
5. Are there any limitations to using complex analysis to study black holes?
While complex analysis is a powerful tool in understanding black holes, it does have its limitations. For example, it is unable to fully explain the behavior of matter and energy within a black hole's singularity - the point of infinite density at the center of a black hole. Other theories, such as quantum gravity, may be needed to fully understand this aspect of black holes.
  • Astronomy and Astrophysics
