Most efficient way to convert mechanical energy into heat.
In summary: to help circulate the gas and increase heat production.yeah it is connected to a rotating fan in the cylonic separation tank to help circulate the gas and increase heat production.
ciurio
Hi
What is most efficient way to convert mechanical energy into heat?
ciurio said:
Hi
Well you don't have a lot of choices, mainly mechanical friction or fluidic friction. Between the two I'd say mechanical friction is pretty good at converting work to heat, but if you need to harvest the heat drag in a fluid might be the way to go...
virtually any way you do it will be 100% efficient.
Perhaps the intended question was: what's the best way to get high quality (low entropy) heat from a mechanical process?
Exactly. Converting work to heat is relatively easy and conservation of energy says that all the mechanical energy must be converted to some other form so unless that energy is being stored as kinetic energy, potential energy or some other form that DOESN'T create heat, it's all going to be heat. For example, expanders used in industry (ie: to remove work energy from a fluid stream) convert that work to heat using either hydraulic resistance or electrical resistance. Same for engine http://en.wikipedia.org/wiki/Dynamometer#Types_of_absorption.2Fdriver_units".
and how can we generate heat from mechanical energy? if we want to generate heat from some pulley system how can we do that?
Really bad axle bearings... :uhh:
Let go of the rope.
Light it on fire
But seriously, unless you have combustion or other chemical reactions, you will have to rely on friction to make your heat. That's easy enough to do.
Travis_King said:
Light it on fire
and how to generate heat from that...i know that's easy but according to my project i need to plan out which would be suitable so kindly pls list out all the possible ways plsssss...
Dude... unless you have access to national level multibillion dollar laboratory facilities, your only hope is friction. How you want to generate that is up to you. Something akin to automotive brake pads might be worth looking at as a starting point.
Danger said:
Dude... unless you have access to national level multibillion dollar laboratory facilities, your only hope is friction. How to want to generate that is up to you. Something akin to automotive brake pads might be worth looking at as a starting point.
soo...wat do u think will be the best way to get more heat from a pulley system through fricton...meant ...wats the best way to achieve as per ur opinion!
How about shearing a fluid? Make a device that stirs a liquid and the liquid will heat up. The more difficult it is to stir, the better.
How about using your pulley to drive a tilt hammer, driving a reciprocating air compressor, and squishing that air through an orifice, then using that compressed air to drive a little air turbine, connect that to a generator, and connect that to a set of heating elements. That would make some heat.
make fire by spinning a piece of wood. That's the oldest example of mechanical friction causing heat that I know of.
You are a cruel man... :biggrin:
Is the pulley allowed to drive another device?
What is mechanical energy and how is it converted into heat?
Mechanical energy refers to the energy possessed by an object due to its motion or position. This energy can be converted into heat through various processes such as friction, compression, and conduction.
Why is it important to convert mechanical energy into heat efficiently?
Efficient conversion of mechanical energy into heat is important because it allows for the conservation of energy and reduces waste. It also plays a significant role in various industrial processes and energy production.
What factors affect the efficiency of converting mechanical energy into heat?
The efficiency of converting mechanical energy into heat can be affected by factors such as the type of material used, the amount of friction present, and the design of the conversion system. Other external factors like temperature and pressure can also impact efficiency.
What are some common methods used to convert mechanical energy into heat?
Some common methods for converting mechanical energy into heat include rubbing or sliding friction, compressing a gas or liquid, and passing an electric current through a resistor. Other methods include using heat engines, thermoelectric devices, and heat pumps.
How can the efficiency of converting mechanical energy into heat be improved?
The efficiency of converting mechanical energy into heat can be improved through various means such as using materials with low friction coefficients, designing systems with less energy loss, and utilizing heat exchangers to transfer heat more efficiently. Additionally, advancements in technology and research can also lead to more efficient methods of conversion.
  • Mechanical Engineering
