Time for block of ice to reach 20 C in an isolating box.
In summary, the conversation involved a discussion of finding the time it would take for 8 kg of ice, kept in a sealed isolating box with dimensions of 20 cm x 20 cm x 20 cm and a thickness of 2 cm, to melt into water at a temperature of 20 C when placed in a room with a temperature of 25 C. The variables κ, CW, Ci, Lf, and Lv were provided and used in calculations involving heat conduction and the thermal conductivity of the container. The final answer was estimated to be approximately 24 days, but it was noted that this calculation assumed the ice conducted heat well and neglected other factors such as transient heat conduction, gravitational effects, and natural convection
peripatein
880
Hi,
I am trying to find how long it will take 8 kg of ice whose temperature is -10 C, kept in a sealed isolating box placed in room temperature (25 C), to turn into water whose temp. is 20 C. The box is a cube whose side is 20 cm, the thickness of the box is 2 cm, and κ = 0.04 W/m*K, CW = 4190 J/Kg*K, Ci = 2000 J/Kg*K, Lf = 3.34*105 J/Kg, Lv = 2.256*106 J/Kg.
1. Warming the ice to melting point (0 C)
2. Melting ALL the ice AT 0 C
3. Warming the water to 20 C
These will all be achieved through heat conduction, from the surrounding to the box.
I believe stages 1 and 3 ought to be calculated via T(t) = Tc + (TH - Tc)*e-t/τ, where T(t) - Tc denotes the temp. difference between the box and its surrounding through a separating medium (in this case, one of the walls of the box), TH denotes the temp. of the body giving off heat at t=0, and τ = mCLf / κA.
I believe stage 2 needs to be calculated via t = Lfm/H, where H = κA(TH - Tc)/L, where L is thickness of isolating layer.
I'd truly appreciate comments on the validity of this approach.
peripatein said:
I believe stages 1 and 3 ought to be calculated via T(t) = Tc + (TH - Tc)*e-t/τ, where T(t) - Tc denotes the temp. difference between the box and its surrounding through a separating medium (in this case, one of the walls of the box), TH denotes the temp. of the body giving off heat at t=0,.
Yes, except that you need to interpret TH and Tc carefully. The TH / Tc notation in the equation you quote assumes a hot body in (infinite) cold surroundings, so everything ends up at Tc. In the present problem, you need to set TH as the box contents temperature and Tc as the ambient.
and τ = mCLf / κA
The Lf looks out of place, but there should be something in there for box thickness. You just meant L, I guess.
Looks good.
Hi haruspex,
Thank you for replying. I did mean L (and not Lf).
I would like to ask you, in view of the above, to kindly review my evaluation thereof:
Stage 1: 25-0 = (25+10)e-t1/200,000, hence t1 = 67294.41 sec
Stage 2: t2 = [3.34*105*8]/[(25-0/0.02)*0.04*0.2*0.2] 1336000 sec
Stage 3: 25-20 = (25-0)e-t3/419,000, hence t3 = 674354.49 sec
Could the final answer indeed be (approx.) 24 days? Seems a bit too much, wouldn't you say?
peripatein said:
Hi haruspex,
How many faces does a cube have? Other than that, your calculations look OK, and I'm not surprised it would take days. In practice it might take rather longer; this calculation assumes the ice conducts well.
It's actually an isolating container "in the shape of a square whose side is 20 cm".
Does anything still require emendation?
PS I wasn't surprised it would take days, simply nearly a month seemed rather off.
I wish to get this straight, please. Do I now need to multiply all the above calculations involving the surface area by a factor of 6?
Presumably heat will enter the cube via all the sides, not just one. To find the thermal conductivity or resistance you'll need to take into account the entire surface area through which the heat enters. One 20x20 cm face is only, well, one face of the cube...
You need to take into account transient heat conduction within the block of ice. The ice can't be treated as having a uniform temperature throughout its mass. Furthermore, once the surface of the ice rises to 0C, the ice at the surface of the block will begin to melt. Then things get more complicated because, in a gravitational environment, (a) the ice will float to the top of the ice chest, and (b) natural convection can occur within the water. If you assume that the ice chest is in outer space, away from gravitational attraction, these effects can be neglected. In this case, there will be heat conduction from the inner surface of the chest to the ice-water interface. The interface will be at 0C until all the ice is melted. So the transient heat conduction problem continues once the ice starts to melt, but in this case there is a moving melt front between the water and the unmelted block. At the interface between the ice and the water, there will be a discontinuity in the heat flux equal to the velocity of the interface times the density times the latent heat of fusion. This is a complicated moving boundary problem. Eventually, after all the ice is melted, the transient heat conduction problem will continue on the water, and the water will still be at a non-uniform temperature. Even when the average water temperature rises to 20C, the water temperature will be non-uniform. Even if this were a transient heat conduction problem on a non-melting solid, the 3D geometry of the cube would still have to be contended with. I'm not saying that this is not a solvable problem. I'm just saying that it is much more complicated problem than can be solved using the implicit simplifying assumptions invoked in the previous posts.
Okay, thanks! I realize it is far more intricate, and yet supposing I am asked to regard the temperature within the container as uniform and continuous at all time, without any gravitational effects, will the sole required emendation now be to replace the A in my calculations with 6A?
Yes. If the problem as presented to you doesn't quote any numbers for conductivity through water or ice, that seems a reasonable assumption.
Yes. I agree with Haruspex. But the answer you would get that way would only be a lower bound to the true amount of time it would take to reach 20 C.
I thank you! :-)
Related to Time for block of ice to reach 20 C in an isolating box.
1. How does the temperature of the block of ice change in an isolating box?
The temperature of the block of ice will decrease as it absorbs heat from its surroundings until it reaches an equilibrium temperature of 20 degrees Celsius.
2. What factors affect the time it takes for the block of ice to reach 20 degrees Celsius in an isolating box?
The time it takes for the block of ice to reach 20 degrees Celsius can be affected by the initial temperature of the ice, the temperature and insulation of the isolating box, and the surrounding temperature.
3. Can the time for the block of ice to reach 20 degrees Celsius in an isolating box be calculated?
Yes, the time can be calculated using the specific heat capacity of ice, the mass of the block, and the rate of heat transfer between the block and its surroundings.
4. Does the size of the block of ice affect the time it takes to reach 20 degrees Celsius in an isolating box?
Yes, the time can be affected by the size of the block of ice as it will take longer for a larger block to absorb enough heat to reach 20 degrees Celsius compared to a smaller block.
5. What is the purpose of conducting this experiment on the time for the block of ice to reach 20 degrees Celsius in an isolating box?
This experiment can help us understand the principles of heat transfer and how different factors can affect the rate at which an object reaches thermal equilibrium. It can also be used to test the effectiveness of insulation materials in maintaining a stable temperature.
