Performance Characterisitics Given a Zero in the System
In summary, to determine the performance characteristics (rise time, peak time, percent overshoot, and settling time) for a generic second-order system with no zeros, given a unit step input for the open-loop transfer function G(s)=(s+1)/(s2+2s+1), you can split the transfer function into two parts and apply the appropriate time-response function. For the second part, which has a zero at the origin, you can use the fact that sF(s) → df(t)/dt to obtain the time response. This method can be used instead of using MATLAB to obtain the performance characteristics.
Kuriger9
I have the equations to determine the rise time, peak time, percent overshoot, and settling time for a generic second-order system with no zeros in the system. Given a unit step input for the open-loop transfer function G(s)=(s+1)/(s2+2s+1) how do I analytically determine the performance characteristics (aside from using MATLAB)?
Thanks in advance!
Thanks in advance!
You can split your transfer function into two parts. One part has no zeros so you an apply your time-response function directly.
The second function is the same as the first except there is a zero in it - at the origin. A clever way to get the time response to this part is to realize that if F(s) → f(t) then sF(s) → df(t)/dt.
Thank you, this certainly helps!
Related to Performance Characterisitics Given a Zero in the System
1. What are performance characteristics?
Performance characteristics refer to the measurable qualities or attributes of a system, process, or product that determine its effectiveness, efficiency, and reliability.
2. Why is it important to consider a zero in the system when evaluating performance characteristics?
A zero in the system can affect the overall performance and accuracy of the system. It is important to consider it in order to accurately assess the system's capabilities and make necessary improvements.
3. What are some examples of performance characteristics?
Examples of performance characteristics include speed, accuracy, durability, energy efficiency, responsiveness, and user-friendliness.
4. How are performance characteristics typically measured?
Performance characteristics are typically measured using quantitative or qualitative methods, such as tests, surveys, observations, or simulations.
5. Can performance characteristics be improved?
Yes, performance characteristics can be improved through various means, such as implementing new technologies, optimizing processes, and continuously monitoring and analyzing data to identify areas for improvement.
10K
