How is electron formed? Why does it travel?
In summary: The electron has enough kinetic energy to make the mass of the neutron from the mass of the proton and electron.2) The atom is unstable and the nuclear charge is big enough to hold the electron.The creation of an electron-positron pair requires much more energy than the creation of a proton-antiproton pair (because the proton is more massive than the electron).The likelihood of an electron sticking to a proton is very low, unless the proton is highly ionized (e.g., inside a pulsar, where the electric field is extremely strong).Btw, when you said destroyed, you meant naturally right? B/c they can easily be destroyed if they meet their anti.By "naturally," I
Skhandelwal
400
I understand that electron is made up of leptons which are made up of energy. But what I don't understand is that how can leptons be just made up of energy, I mean its not like a balloon. Another thing is that Wikipedia claims that Leptons and Quarks are the only 2 fundamental particles...but then what is neutrino made up of? What about antineutrino? I understand that this universe is made up of energy but then why is it moving?(why are the electrons spinning and rotating?) Don't tell me b/c the entropy is increasing b/c then I'll ask what caused the big bang. If like Hawkins, you say it is a cycle, then are you telling me time never began?
You are making a mess.
1) An electron is not "made up of leptons"; it's a lepton itself.
2) Neutrino IS a lepton (and so antineutrino too).
3) Leptons and quarks are not the only fundamental particles, unless you substitute the word "particles" with the word "fermions".
4) Electrons doesn't spin.
However there are many people here who knows these things better than me.
If they don't spin then why do they talk about half integer and integer spin? Besides, how are electrons created? Why do they rotate around the protons? Are the fermions and Bosons the only fundamental particles then(being leptons, quarks, gluons, photons, and w and z bosons.)?
Are you looking for answers in terms of the symmetry properties, like U(1), SU(2), SU(3), etc? Maybe someone more equiped could give us a brief summary of how particles are supposed to be the result of symmetry properties.
I believe the entymology of the term is that you have to spin an electron 720 degrees before it returns to its original position: you get half of a full rotation in a 360 degree rotation.
They don't. They don't revolve around protons either. An electron in an atom simply sits there, occupying its entire orbital.
I have never heard of this. I will defer to what I assume is your better knowledge on the subject, but my understandnig has been that, while electrons do not "orbit" the proton, they do not simply "occupy" the orbital either.
It was my understanding that they do actually move, and that the orbital merely describes a probability of where they will likely be found when sought out.
If that's the case then why don't they stick to the protons since they are attracted to it? Besides, that's what my chemistry teacher taught me. Also, how is it created? and how does it die?
What? The electrons? They're neither created nor destroyed. They're fundamental particles.
What about others? Protons, neutron, gluons, nuetrinos, etc. Btw, when you said destroyed, you meant naturally right? B/c they can easily be destroyed if they meet their anti.
proton's coulomb potential confined the electron cloud. But the electron cloud density in the nuclues center is zero.
I think the picture of electron cloud spinning around the nuclues should be physical
No, in the ground state hydrogen atom, the electron's probability density (per unit volume) is actually maximum at the origin (the nucleus)!
http://hyperphysics.phy-astr.gsu.edu/hbase/quantum/hydwf.html
You may be thinking of the "radial probability distribution" (probability density per unit radius), which does go to zero at the origin. But this is a geometrical artifact. The radial probability distribution gives you the probability that the electron is located somewhere in a thin spherical shell of radius r and (small) thickness dr. The volume of that spherical shell decreases to zero as r decreases to zero, so the radial probability distribution does also.
The electron doesn't "stick" to the proton because if it did, they would combine to form a neutron, emitting a neutrino in the process. But a neutron has a larger mass than a proton plus an electron, so this can't occur spontaneously; something would have to supply enough energy to create the increased mass.
In some heavier atoms, an electron can "stick" to the nucleus, converting a proton to a neutron and emitting a neutrino, provided that the resulting nucleus has a smaller mass than the original one plus the electron. This process is called electron capture. It's one mode of radioactive decay.
You ask these questions like the answer, "That's reasonable, but we simply don't know" is unacceptable. What caused the big bang? Whatever you want to pretend caused it. No on can say for sure right now.
Did time have a start at some point? Maybe, maybe not. Is this really a problem? Not so much -- it's weird, but not really unreasonable.
I am wondering about the more accepted theory. Ofcourse nothing is proven, but right now, scientific method is the most accepted way.
Btw, you guys are getting way too advance here, I am lost. Now, in a more elementary manner, why don't the electrons stick w/ protons?
I'm not an expert on this subject (yet), but let me try to clear things up a bit.
No, an electron is a lepton. Lepton is a name for a whole family of particles (muons, tau particles, neutrino's, etc)
Skhandelwal said:
[...]leptons [...] are made up of energy
Just as anything in our universe.
There is nothing to understand here, it's just something fundamental. Probably, when you say energy, you have in mind the stuff that moves objects around and heats your house. In fact, energy is a fundamental quantity, which - as far as I know - cannot be defined. We just divide energy that we see up in different forms (kinetic energy, chemical energy, mass, temperature, etc) though all of these are really the same thing.
I don't see the connection between those statements. Why would the universe being made up of energy exclude it from moving? Do you mean: why is part of the energy that makes up the universe in a form that we call kinetic energy?
Electrons are kept near atomic nuclei because of nuclear forces (mainly, Coulomb interaction). It's common to picture an electron as revolving around the nucleus in an orbit, just as a planet revolves around the sun. But in reality, we cannot pin-point the exact location on a given moment in time. We can just (by quantum mechanics) calculate the probability that we will find it in that-and-that area. Likewise, the name spin is confusing -- it refers to a property of (among others) electrons which has certain similarities to the classical spin of for example a ball or a top (in fact, it is similar to the orbital rotation, but it's an intrinsic property, like classical spin - hence the name I think). But the name is also a bit misleading, as the object does not really spin around an axis (in fact, we can look at an electron as a wave, rather than a solid "ball").
So, in both cases, nothing really "spins", it's just an attempt to link some strange, quantum-mechanical properties to familiar concepts, which gives us some grasp on the ideas, but one cannot extend the analogy too far.
You mean, if a proton is positive and an electron is negative, why don't they attract and collide? I think there is no answer without involving quantum mechanics again (sorry about all the QM, but on this scale, that's just the theory you need to accurately describe nature), but perhaps this link will give you some reading.
"Do you mean: why is part of the energy that makes up the universe in a form that we call kinetic energy?"
Yes! and thanks for the other answers you and other folks.
One more thing, I understand that all protons and Neutrons are collected together by Strong Nuclear Force and you told me that Electron are attracted to Protons due to weak nucleus force(so charge is basically weak nucleus force). Then how is one atom attracted to other?(gravity? What is the source of it?) How is one molecule attracted to another?(what I mean is that whenever 2 compounds meet, why do they start chemical reactions instead of repulsing each other?(I took AP Chem but trying to keep up my grade was a greater priority for me then understanding it)
Excepting in those few rare cases of pair productions and annihilations.
CompuChip said:
Electrons are kept near atomic nuclei because of nuclear forces (mainly, weak interaction).
Please?
Electrons are attracted to protons because of Coulomb force.
This is more complicated to answer. First, interatomic forces are different from the intermolecular ones, and in this last case there are more kinds.
a. Interatomic forces. Let's make a simple example: two hydrogen atoms (covalent bond, in this case). Even in this case the answer is not simple; simplyfing a lot, we can say one reason is the fact the electron of atom A is attracted to the proton of atom B too, and the same between electron of B and proton of A. All this however holds true in a specific range of distances, because in other ranges it's electronic repulsion (*) (simplifying again) to prevail on the first effect.
b. Intermolecular forces. As I said there are many kinds. However we can say that the main cases involve, at the end, electrostatic or electrodynamics forces, so, no gravity (in the sense that gravity do act, but with enormously lower intensity, so that it's never considered in these cases).
Some kinds of intermolecular bonds:
1. Van Der Waals bond. It's present in many cases, even together with other kinds of bond. It's present, e.g., in molecules with no net dipole moment or in big molecules. It's the reason of molecular hydrogen condensed states, for example.
2. Ionic bond. Is the case of common salt, NaCl. The crystal is made of Na+ and Cl- ions, which attracts one to another; a Na+ ion attracts more than one Cl- ions and the other way round, so you have an entire macroscopic structure, instead of single, detached molecules.
3. Covalent bond. It's the same as the bond between two hydrogen atoms in molecular hydrogen, but in this case the bond is extended to all atoms. One example is sylica, another is diamond.
4. Dipole-dipole interactions. Example: forces between HCl molecules. (HCl molecule has a separation of charges so a net dipole moment; two dipoles can attract one another).
5. Ionic - dipole interactions. Example: Ions hydratation.
6. Hydrogen bond. It's a kind of half-way between 4. and 5. Typical of water molecules e.g.
7. Metallic bond. Semplyfing: it's kind of the case of H-H bond, but involving a huge number of electrons and nuclei all together
...ecc.
In 2., 3. and 7. cases, molecules cannot be distinguished, so they actually cannot be called intermolecular bonds. I put them in that group just because they involve many atoms at the same time.
(*) or nuclei repulsion.
But shouldn't the atoms be repelled from each other due to electron repulsion?
So at what level gravity force comes into effect?
How is Coulomb's force created?(I understand they exist between charges but why?)
Atoms are usually, essentially electrically neutral. The + and - effectively cancel out (though not completely, or we'd have no molecules).
Gravity is in effect at all scales, but it is many, many, many orders of magnitude smaller than the other forces. It can for all practical purposes be treated as zero, which is why it does not factor in at atomic levels.
If you read well what I wrote, you would have understood that there is indeed electronic repulsion, but *also* attraction between electrons and nuclei. Which effect prevails depends on atomic distance.
There isn't a net separation, since gravity acts always and its action increases with the mass of the body we are considering. To make gravity so strong to break atoms, however, Earth's mass is still not enough; sun's mass it is. So this can give you a slight idea.
How is Coulomb's force created?(I understand they exist between charges but why?).
As far as i know, in some theories that force is equivalent to curvature in an higher dimension, like gravity is equivalent to space-time curvature, according to GR (General Relativity); but I actually know nothing about it.
But what is gravity? I mean I am sure it doesn't at photons level, so I am guessing it starts at atomic level...I know it is the fact that all atoms are attracted to each other...is it because of the neuclei?
Someone inhere said earlier that electrons are never created nor destroyed...but how is that possible? If Universe, time, basically everything has a beginning, then how come they exist since forever? And if they have existed after that time, then how?
Gravity can be seen as just an effect from the curvature in space-time. Or if you prefer you can look up gravitons, supposed massless particles that travel between all bodies conveying attraction.
Light is affected by gravity and will bend towards massive objects.
But gravity has no place in a discussion on atoms. It is so much weaker than the other forces at play that you would not notice if it disappeared.
How can a massless object convey attraction? Since it is massless, how can it attract anything?
Why do you think that it needs a mass in order to mediate attraction? I don't see why that is logically implied by anything.
? Are you saying th Sun's mass alone is enough to tear atoms apart? i.e. by gravity? Or you you mean that indirectly through pressure and fusion, atoms are broken?
Mass is a property of all matter, electrons, protons and neutrons alike. Gravitational attraction is a property of mass. That's pretty much it in a nutshell.
As to what or why matter has mass, we simply do not know.
Well, they didn't exist forever. I didn't mean it in that sense. In the early years after the Big Bang there was only energy; it was too hot for matter to exist, but eventually the universe expanded and cooled, and energy was able to condense into matter. Essentially, the amount of matter in the universe was fixed at that time - though there are processes that exchange matter and energy. Simply put, the modern universe is too cool for large-scale matter creation.
I was just thinking that string theory may be an interesting read for Skhandelwal. The very basic idea being that the strings vibrate in different patterns. These vibrational patterns are, in a sense, the characteristics of the particles as we see them. That is, something has mass because it, as a string, is vibrating in a way so as to produce the effects that we know of as mass.
I hope that is correct and makes sense. In any case, string theory does answer "what is mass?" to some extent, IMO.
I mean that pressure in that case is so high to make them collapse and trigger nuclear reactions.
  • #31
Oh, I watched that 6 hours long video by PBS about String Theory. Now, if I got what you were saying right, then you said at the beginning, everything was energy. However, as the temperature got cooler, things started turning into mass. But how? How does energy suddenly turn into mass? This brings another question...what is temperature? I believe temperature is the rate at which those tiny little energy strings vibrate but then again, why? What creates temperature? What controls temperature? I mean they can't be vibrating on their own as they feel like it.
I am sorry, I don't like asking these many questions...as a matter of fact, I am hating physics right now realizing I never really understood even the elementary science.
  • #32
Skhandelwal, the problem with the elementary physics concepts such as energy, force, etc. are that they are usually harder to understand than derived concepts (mass, movement, etc) because it is these concepts that we observe in nature, and fundamental concepts are often either abstract or not defined (they are simply there, as a starting point for our physical description).
It is possible for energy to turn into mass. This is exactly what the famous (and often mis-quoted) formula [itex]E = M c^2[/itex] (or [itex]\gamma m c^2[/itex]) says: energy and mass can be converted into each other. This is also what we observe in nuclear reactions where particles split or fuse, where the new (sum of) mass(es) is smaller than the original (sum of) mass(es), the remaining mass having been converted to energy. In fact, energy and mass are completely equivalent in principle (though in practice it's everything but easy to convert between them). As to why part of the energy of the universe is ... well, energy (light, heat, radio waves, etc) and some of it is in the form of mass, and why that part is what it is, I don't really know, so I'm afraid I also cannot give you the reason that energy started to be converted to mass when the temperature cooled. (Actually, I'm making here a distinction I just said doesn't really exist... so probably I'm making a conceptual mistake here.)
As for temperature, we should first look at entropy. Entropy tells us something about the number of states accessible to a system (actually, if there are g states in which a quantum system may be, the entropy is [itex]\sigma = \log g[/itex]). Nature always seeks to increase entropy (simple example: a solid may evaporate, because then all the particles in the solid are free to move about in a gas, which gives each particle more degrees of freedom - hence more entropy). Now temperature, basically, measures how much a system wants to exchange entropy with another system. Suppose we have one (closed) system divided into two subsystems. It may be possible that one subsystem sacrifices some entropy, so that the entropy of the other system increases - in such a way that the overall entropy increases. Actually, if the systems are left free to do what they want, they will do this until there is an equilibrium (thermal equilibrium): both systems have maximal entropy. In this case, the temperature is defined to be equal in both the systems. The more "drive" there is to exchange entropy, the higher the temperature will be.
That is the way I like to look at it, for other points of view and a more precise treatment you should take a look at this page or a good book (like the one from Kittel and Kroemer).
  • #33
Skhandelwal -- Answers to everything you have asked can be found in beginning atomic and quantum physics texts. For example, you will find that the idea of spin comes from the Stern-Gehrlach experiment, which involved magnetic moments, classically associated with rotational motion. But, as it turns out, spin is, in fact, an abstract property of particles. While spin is connected with angular momentum, there's no evidence that an electron is actually spinning.
Regards,
Reilly Atkinson
  • #34
hasn't the speed of light been broken? i saw a couple of authorititive looking pages from the BBC, which is usually trustworthy;
http://news.bbc.co.uk/1/hi/sci/tech/841690.stm
if its true does this mean the base of Quantum theory is wrong, rendering it all wrong? or would it cause more damage to the theory of relativity?
  • #35
No, your interpretation of it is wrong. If you actually read the paper itself (and not just rely on news report), you'll see that no part of that wave actually traveled faster than c. Do a search on here and you'll see that the NEC paper has been mentioned several times, including by me.
Zz.
  • High Energy, Nuclear, Particle Physics
