Blood Test and Auto Immune Disease
In summary: Yes, it is considered an autoimmune disorder. There is no cure, but there are treatments available. For example, for MS, there is a drug called Betaseron that helps to reduce the symptoms.Thanks for the clarification.
misskitty
737
Vampyred!
I have a question...how long does it usually take a lab to do blood work on you? :confused:
Biology news on Phys.org
It depends on the type of test and the number of sample at the time. Lab tend to do sample by batch.
Some test will take 24 hours other 48 hours some may take up to a week. A good and high through put lab can do almost every test within 48 hours.
How do they do things like Auto Immune Deficency tests?
Auto Immune Deficiency...
I had a few questions about Auto Immune Deficiency...like MS and MD.
How do they test for things like that?
How do they treat it?
Also, how do the technicians do a blood count, red and white?
just curious.
Btw: thanks to whom ever linked these...I wanted to edit them, but couldn't do it without deleting them.
just curious.
I don't know about your other questions but for white blood cells WBC, here is a method they could use:
First you lyse (break) the red blood cells, which essentially removes them from view. Then you take a dilution of the remaining sample and place it on a hemocytometer. This is a grid pattern on a slide you can observe under a light microscope. You just count up the number of nuclei you see on the grid and multiply that by a known factor (for that cytometer). This gives you the number of cells per volume of blood.
A good reference on how white blood cells are counted in animals can be viewed at a veterinary science website at Cornell Univ. It has a nice diagram of the hemocytometer. :rolleyes:
http://www.diaglab.vet.cornell.edu/clinpath/modules/hemogram/wbc.htm
I am familiar with these calibrated slides. I have used them to count phytopathogenic fungal spores, to determine their concentration in suspension.
That makes sense. How do they do a red count to check for anemia (sp?)? Or do they just check the levels of iron in you blood.
A quick test for red blood cell is to take blood in a capillary and let the RBC settle at the bottom of the capillary tube. If the RBC are below 50% (give or take) then the person might be suffering from annemia. RBC above 50% is also not a good thing.
i got my results always the day later..
but the work for the test wouldn't cost so much time for the lab... some minutes until some hours, i think...
Greets
Soeren
So I should have my results by the next time I visit my PCP?
Depending on when you are visiting. Some doctors request blood test results faster and most likely have the results for the next visit.
I hate waiting for them. Especially since it took over two months to even get the tests ordered.
Did you call your doctor and ask? That would be the easiest way to find out. Sometimes they get the results in quickly, but as long as you have an office visit scheduled, don't bother calling with the results if they can tell you in person. Some doctors also have a bad habit of not calling if there's nothing abnormal requiring follow-up, which leaves you stuck wondering and worrying unless you call them and ask.
They wouldn't order the tests. Even though I requested them several times. All of my physicians kept telling me that the tests were not necessary. Until I met withone doctor and told him why I had had such difficulty with this, he actually asked me it I had had a blood work-up, he said they should have ordered the tests a long time ago. Especially since nothing had shown up on the MRI.
just curious.
Not sure what MD is but as for multiple sclerosis there is no single blood test that confirms its diagnosis. It is usually a constellation of tests and their results... such as an MRI that shows demylenation process, a visual evoked potential that is abnormal (special type of EEG) and a spinal tap ( to look for oligoclonal antibodies) combined with clinical presentation that supports the diagnosis of MS.
MD is the abbreviation for Muscular Dystrophy. Those test sound like a blast! :frown:
Muscular dystrophies in general are considered genetic diseases rather than autoimmune diseases.
I was told it is also considered an auto immune deficency.
No, you were told wrong. Perhaps they meant other muscle disorders such as myasthenia gravis or polymyositis which are autoimmune disorders but are not muscular dystrophies. This link gives a nice synopsis about the different main types of muscular disorders, delineating the inflammatory, autoimmune types from the congenital muscular dystrophys. http://www.geocities.com/CollegePark/Classroom/9056/muscle.html
What is a blood test and how is it used to diagnose auto immune diseases?
A blood test is a medical procedure in which a sample of blood is collected and analyzed for various purposes, such as detecting the presence of certain substances or diseases. In the case of auto immune diseases, blood tests can be used to measure the levels of certain antibodies or immune cells that indicate the presence of an auto immune disorder.
What are some common auto immune diseases that can be diagnosed through a blood test?
Some of the most commonly diagnosed auto immune diseases through blood tests include rheumatoid arthritis, lupus, celiac disease, type 1 diabetes, and multiple sclerosis. However, there are over 80 known auto immune diseases, each with their own unique markers that can be detected through blood tests.
Is a blood test the only way to diagnose auto immune diseases?
No, a blood test is not the only method of diagnosing auto immune diseases. In some cases, doctors may also use imaging tests, biopsies, or physical examinations to confirm a diagnosis. However, blood tests are often the first step in the diagnostic process as they are non-invasive and can provide valuable information.
How accurate are blood tests in diagnosing auto immune diseases?
The accuracy of a blood test in diagnosing an auto immune disease depends on various factors, such as the specific disease being tested for and the quality of the test. Generally, blood tests can provide a reliable indication of the presence of an auto immune disease, but a definitive diagnosis may require further testing.
Can a blood test predict the severity of an auto immune disease?
While a blood test can indicate the presence of an auto immune disease, it is not always possible to predict the severity of the disease based on the results. The severity of an auto immune disease can vary greatly from person to person and can change over time, so additional monitoring and testing may be needed to assess the progression of the disease.
  • Biology and Medical
