Calculating Density of 0.7M NaOH Solution | Jim
In summary, the density of a solution of 0.7M NaOH solution can be calculated by weighting the solution and determining the amount of water present, and then converting to g/mL.
jimbo007
41
does anyone know how to calculate the density of a solution of 0.7M (say) NaOH solution. if so, could you please show me how its done
i have looked everywhere on the net but to my extreme surprise i couldn't find it
thanks
jim
Chemistry news on Phys.org
It's pretty much all about knowing how to convert units.
0.7 M = 0.7moles/L
NaOH Mol Weight= 40g/mol
So [tex](0.7moles/L)*(40g/mol)=28g/L[/tex]
and since density is usually in units of [tex]g/mL[/tex],
[tex](28g/L)(1L/1000mL)= .028g/mL[/tex]
Hello Jim,
Well, we may use the conventional formula d=m/v, and if your NaOH solution is 1L, then let me calculate the density:
1L, 0,7M NaOH=0,7 moles=0,7*40=28 grams of NaOH (in 1 L of solution)
You may calculate the density for your needs; if you want it to be expressed as g/100 mL, then you may say that d=2,8 g/100 mL.
If you want in as g/mL; then you may write 0,028 g/mL for the solution.
If your solution is not 1 L, we can still use d=m/v. Just calculate the following:
d {g/L}=(c {mol/L} * v {L}) * mw {g/mol} / v {L}; here, (c * v) * mw gives the mass of your NaOH solution (providing that v is given in liters), and further dividing it to v gives the density. So just multiply the concentration with molecular weight, that gives the density in g/L.
Changing the units will lead to different expressions of density, you may even try these.
Regards,
chem_tr
Neither of the above calculations is correct. They calculate "density" based only on the NaOH present but the solution is made of water and NaOH so the density must take into account both. There is no easy way to do this without a measurement. You must weight your solution and determine the amount of water present in addition to NaOH, as the exact amount of H2O needed to reach 1 liter cannot be calculated exactly, only approximated. For dilute solutions the density will be close to that of pure water,but for more concentrated solutions, there will be a significant difference. You should expect the density of be greater as more NaOH is dissolved in the solution.
At an even more pedantic level, there is no mention of this being a solution in water.
At the most pedantic level, this thread is 7 years old and none of the original posters is still with us.
1. What is the formula for calculating density?
The formula for calculating density is mass divided by volume (D=m/v).
2. How do you measure the mass of a substance?
The mass of a substance can be measured using a scale or balance. The substance is placed on the scale and the weight is recorded in grams (g).
3. How do you measure the volume of a liquid?
The volume of a liquid can be measured using a graduated cylinder or a volumetric flask. The liquid is poured into the cylinder or flask and the measurement is recorded in milliliters (mL).
4. What is the concentration of a 0.7M solution?
The concentration of a solution is a measure of how much solute is dissolved in a given amount of solvent. In a 0.7M solution, there is 0.7 moles of solute per liter of solution.
5. How do you calculate the density of a 0.7M NaOH solution?
To calculate the density of a 0.7M NaOH solution, you would need to know the mass of the solution and the volume of the solution. Then, you would use the formula D=m/v to calculate the density. Keep in mind that the units for mass and volume must be consistent (e.g. both in grams or both in milliliters).
  • Chemistry
  • Chemistry
  • Biology and Chemistry Homework Help
  • Chemistry
  • Chemistry
