Truck tire pressure / load on road
In summary: There is a limit to how much weight can be added to the truck before it starts to lift off the ground. If the weight is too much, the pressure in the tires will increase and the truck will touch the ground again.
pescador
hi to all
problem:
a truck with a total weight of 5000kN and with 4 wheels will be placed on 4 glass cups each under one wheel. if each tire has a internal air pressure of 2MPa. what will be the load on each cup? and if the truck was standing on the road without the cups under wheels what will be the load on the road.
pescador said:
hi to all
problem:
So what are your thoughts on how tire pressure affects the downward force of the truck?
AM
if the tires were solid then i can exactly say that the load per tire transfering down to road is 5000/4 = 1250 kN
but the tires are like pneumatic pillows. so some of the load should be carried by the tire surface.
the load effecting to road should be the surface of the interface between the tire and road * tire internal pressure.
So if we, say, let out half the tire air (and, therefore, reduced pressure by half), the load on the road would reduce by half?
AM
no because if we let the half of air out. then the touching surface area to the road of the tire will increase and the load will remain the same.
So what effect does tire pressure have on the force exerted on the ground by the truck?
AM
sees like nothing if i dunt make a wrong model
if we say that it has no effect on the load why we have so mch pressure on the tires?
The pressure inside the tires is balanced by the forces holding the tire to the wheel. It contributes no net force to the road.
AM
got it
so if i have a truck of total weight is a N on 4 tires with a tire pressure of p Pa then the surface area touching the road per tire should be
[tex] N/(4*p) [/tex]
so there force to the road will be pressure times the surface area so N again.
do u have a source that tells theory about the pressurized systems with flexible layer?
ok let's change the subject.
i got a basketball it stands still on the road. then i come and start pressing on the ball with my one foot. the ball will be deformed from the point that i press. and also the area of the ball touching the road will be deformed and increase.
i think that because of the volume decrease in the ball the pressure will increase and then this pressure will transfer my weight to the road with it's increased area touching the road. so there reaction force from the road will increase.
true?
true?
You are making it too complicated. The tire pressure does not affect the load on the road. At best, it changes the distribution of the load so changing air pressure may change the pressure on the road somewhat. But that is all. The pressure in the tires has no bearing on the total force on the road.
AM
:) ok.
last one. what will happen if i increase the load (add more things to truck) there must be a limit for that if i put more weight and suppose that the tire surface is strong enough. the air will go upwards and the truck will touch the bottom. but if i put more pressure on it will lift the truck again.
so there must be a connection, hmm don't know may be alittle mixed up
pescador said:
:) ok.
If you have a deflated tire and pump it up, the truck will rise as the air pressure builds up inside the tire. The air in the tire does work as it expands. This work raises, slightly, the centre of mass of the truck and increases its gravitational potential energy. But (when the truck stops moving up) the force exerted on the road is exactly the same as it was with the deflated tire.
Draw a diagram showing the forces on the truck and on each wheel. Since the truck is not accelerating in the vertical direction, the vertical forces sum to 0. Those forces are the weight of the truck (down) and the normal force of the road on the tires (up). The air in the tire is exerting a force in both directions but is balanced by the mechanical forces holding the tire onto the truck. It would be exactly the same if the truck was sitting on four vertical springs.
AM
so can we clearly say that the weight of truck is transferred to pressured tire by [tex] surface area 1*pressure [/tex] and it transfers the same load to the road by [tex] surface area 2*pressure[/tex]
surface area 1 : area of the rigid part touching to the tire
surface area 2 : area of the tire touching to road
The pressure in the tire does not determine the pressure on the road or the force on the road. A flat tire with 0 air pressure will still exert a force and pressure on the road.
The pressure on the road x area of contact with the road would give you the force on the road, provided the pressure was evenly distributed (which it probably is not). But that is not the same as the tire pressure.
Don't get hung up on how the weight is mechanically borne by the tire because there are too many variables that affect it. The issue is not pressure. The issue is force. The weight on each tire is 1/4 of the weight of the vehicle regardless of how much pressure is in the tires.
AM
I kept myself busy with calculation of tire-pressure and made spreadsheets for it.
The formula the tire-manufacturers use , has a power in it but the next article about another way of calculating , I concluded of, that a part of the load is bare by the construction of the tire.
This is for smal tires with low pressure about 20% of the max load,so about 60 kg still, and for large truck tires with high pressure only 2%, but still about 120kg.
http://cid-a526e0eee092e6dc.office.live.com/self.aspx/.Public/tirepressureatreducedloads.pdf
I myself concluded that at a sertain supression of the side wall of the tire, the construction of the tire bares a sertain weight , and this gives a sertain calculatable surface on the ground. The rest of the load is bare by the simple pressure in kgf/sqcm * calculated surface.
Not the issue now but , for every speed there is a sertain supression of the tire-side-wall permissable, and so a sertain surface on the ground.
Mayby you can do something with my information.
1. What is the recommended tire pressure for a truck?
The recommended tire pressure for a truck can vary depending on the make and model of the truck, as well as the weight of the load being carried. It is important to refer to the manufacturer's guidelines for the specific truck to determine the recommended tire pressure.
2. How does tire pressure affect the load a truck can carry?
Tire pressure plays a crucial role in determining the maximum load a truck can carry. If the tire pressure is too low, the tires will not be able to support the weight of the truck and its load, leading to increased wear and tear on the tires and potentially causing a blowout. On the other hand, if the tire pressure is too high, the truck may have a rougher ride and the tires may wear out faster. It is important to follow the recommended tire pressure for optimal load capacity.
3. Can overloading a truck cause issues with tire pressure?
Yes, overloading a truck can cause issues with tire pressure. When a truck is carrying more weight than it is designed to handle, it puts extra strain on the tires and can cause them to become overinflated. This can lead to uneven wear and tear on the tires and decrease their lifespan. It is important to always adhere to the weight restrictions and load capacity of a truck to prevent damage to the tires.
4. How often should truck tire pressure be checked?
Truck tire pressure should be checked at least once a month, or before every long trip. It is also important to check the tire pressure after any significant changes in temperature or when carrying a heavier load than usual. Maintaining proper tire pressure is essential for safe and efficient truck operation.
5. What are the consequences of driving with incorrect tire pressure?
Driving with incorrect tire pressure can have serious consequences, such as increased fuel consumption, decreased handling and control of the truck, and decreased tire life. It can also lead to unexpected blowouts or tire failures, which can be dangerous for both the driver and other vehicles on the road. It is important to regularly check and maintain proper tire pressure to ensure safe and efficient truck operation.
  • Mechanical Engineering
