- #36
Ken G
- 538
Not to get the luminosity. Those shocks and T variations are due to the stirring below the surface caused by, you guessed it, the luminosity of the star! It's not a bad example of a natural Carnot engine, whereby you move heat across a temperature difference and get it to do work, which is then used to stir the gas up and make shocks and magnetic activity. But eventually that work turns back to heat, and rejoins the luminosity from whence it came, without having much effect on the latter.Mordred said:Wouldn't you also have to be concerned by the variations in temperature absorbtion, shock waves etc?
You can say that again!So at best this method is an approximation.
It's the only approximation. There isn't any other simple approximate scheme for deriving the luminosity of a star from first principles, there just isn't. If anyone thinks I'm wrong, they are welcome to try and provide an alternative approach to the link I gave!However I'm unclear if the method your proposing is a better or worse approximation.
Composition is only in there in how it affects the diffusion physics, how long it takes the light to get out. This depends on the opacity in the interior, and that depends on the composition. You would see that if you filled in the constants in the factors they left out in that link, the opacity is in there (and so it has to be approximated rather roughly to get their result, but again, do you really want to model in detail the opacity in a star, or just understand that the reason it matters is it can quantitatively alter that diffusion physics?). For example, you could change the composition at the surface, but if you didn't change the mass or the composition over the bulk of the star, it would have little to no effect on the luminosity.Seems to me you still need to understand the stars composition to get an accurate luminosity relation.
