- #36
Jonathan Scott
- 1,151
TobyC said:I don't see why the expression I derived is not relative to local coordinates? I defined the gravitational potential to be zero at ground level, so at ground level the metric is just the standard minkowski metric, so the expression should be valid from the point of view of a coordinate system which is located and fixed at ground level, which is the perspective that seems to be implied from the question.
As far as I can see, what you've calculated is the momentum in a coordinate system which is flat but locally coincides with the local coordinate system. By the time you get to a different potential, it can no longer match the local coordinate system, in that both time and space have changed in scale, so the coordinate speed of light has changed and the momentum defined by that process differs from local momentum.
However, the change in the energy is only affected by the relative time rate, so that can be compared from any static point of view.
