Finding a particular solution (Diff. Eq.)
In summary: It says that if you have:y''' - 6y'' + 11y' - 6y = 6etthen y_p = Aetand if you have:y''' - 3y'' + 2y' = 2etthen y_p = (At + B)e^tSo I wasn't sure if I was supposed to look back and see what the solution was and guess an even higher order, or if I was supposed to just try the next x in the solution. That's why I was confused. I'm pretty sure I understand it now though.Also, I was told that for t^2,
EugP
107
I seem to not fully understand how to find particular solutions. I'm having a hard time guessing what the solutions maybe. I'll explain as I write out the problem.
[tex]y''' - 2y'' + y' = te^t + t^2 + 4[/tex], find the general solution.
[tex]Z(r) = r^3 - 2r^2 + r[/tex]
Found the homogenous solution:
[tex]r^3 - 2r^2 + r = 0[/tex]
[tex]r (r - 1)^2 = 0[/tex]
[tex]r_1 = 0, \ r_2 = 1, \ r_3 = 1[/tex]
[tex]y = C_1 + C_2e^t + C_3te^t[/tex]
Now I'm trying to find the particular solutions.
For [tex]te^t[/tex], I assume:
[tex]y_1 = At^2e^t[/tex]
[tex]y_1' = Ae^t (t^2 + 2t)[/tex]
[tex]y_1'' = Ae^t (t^2 + 4t + 2)[/tex]
[tex]y_1''' = Ae^t (t^2 + 6t + 6)[/tex]
Now I plug back in:
[tex]Ae^t (t^2 + 6t + 6) -2Ae^t (t^2 + 4t + 2) + Ae^t (t^2 + 2t) = te^t[/tex]
[tex]2A = t[/tex]
[tex]A = \frac{t}{2}[/tex]
[tex]y_1 = \frac{1}{2}t^3e^t[/tex]
Now, for [tex]t^2[/tex], I assumed [tex]y_2 = Bt^3[/tex], but in an example in the book that had [tex]t^2[/tex], it said that [tex]y_2 = t^2 (A_1t^2 + A_2t + A_3)[/tex]. I don't understand how they got that.
Also, for the constant 4, I assumed [tex]y_3 = Ct[/tex]. Is this correct?
I don't fully understand how I am supposed to go about guessing the solutions. There must be some guidelines, but we weren't taught what they are. If someone could help me with this, it would be greatly appreciated.
Are you trying to use superposition to get solutions?
Generally, it works out that you guess the type of function that's the same as the particular part. So if you have ODE = k, where ODE is some kind of diff eq, then you should guess a constant as the solution. Another example would be if you had ODE = cos(2t) you should guess Acos(2t) + Bsin(2t) or simply exp(i2t).
Sometimes you will have a mixture of functions, in which case your guess should also be a mixture. Say there was a polynomial with
[tex]ODE = At^2 + Bt + C[/tex], you should just a polynomial of the same form
[tex]y_p = \alpha t^2 + \beta t + \gamma[/tex]
If you had something of a mixture, such as
[tex]ODE = e^{\alpha t} P_2(t)[/tex]
you should guess
[tex]y_p = exp(\alpha t)(At^2 + Bt + C)[/tex]
for each case just extend the generalization further and further
[tex]ODE = e^{\alpha t} P_2(t) sin(\beta t)[/tex] gives
[tex]y_p = exp(\alpha t)sin(\beta t)(At^2 + Bt +C) + exp(\alpha t)}cos(\beta t)(At^2 + Bt + C)[/tex]
But don't I have to look back to see if the solution I'm guessing already exists?
For example, if I have:
[tex]ODE = e^t[/tex]
My homogenous solution comes out to be:
[tex]y = C_1e^t + C_2te^t[/tex]
and I need to guess a solution for [tex]e^t[/tex], I was told that I can't guess that [tex]y_1 = Ae^t[/tex], because [tex]e^t[/tex] is already a solution. Neither can I choose [tex]y_1 = Ate^t[/tex], because it's also a solution. So I need to use [tex]y_1 = At^2e^t[/tex]. So do I just need to look back to make sure that what I'm guessing is not a solution already?
Now I plug back in:
[tex]2A = t[/tex]
No, no, no! A has to be a constant- it cannot depend on t!
I don't fully understand how I am supposed to go about guessing the solutions. There must be some guidelines, but we weren't taught what they are. If someone could help me with this, it would be greatly appreciated.[/QUOTE]
Have you looked in your textbook? I don't know of any that doesn't go into pretty specific detail about how to "guess" solutions. The kind of solutions that you expect for any "linear homogenous d.e. with constant coefficients: are:
1) exponentials: Cekx
2) sine or cosine: Ccos(kx) or Csin(kx)
3) polynomials: Cxn+ Dxn-1+ ...+ Yx+ Z.
4) Combinations of those: (Axn+ ...)ekx(Ucos(mx)+ Dsin(nx)
The method of "undetermined coefficients" only works if the right-hand-side of the equation is one of those forms. In general, if it is, you try that same type. That is, if the rhs is ekx you try Aekx. If the rhs is either sin(kx) or cos(kx), you try Asin(kx)+ Bcos(kx) (in general you will need both sin(kx) and cos(kx)). If the rhs is a polynomial or a polynomial times an exponential you try the same thing: however, if the highest power of x is n, you may need all powers from n on down even if the lower powers do not all appear in the rhs.
The reason Aet doesn't work here is that et is that it, as well as tet and t2et are already solutions to the homogeneous equation. You need to try At3et.
HallsofIvy said:
...The reason Aet doesn't work here is that et is that it, as well as tet and t2et are already solutions to the homogeneous equation. You need to try At3et.
That's what I need to know. I wasn't sure about that. See the thing is, there is a chart in the book that supposedly explains how to find the particular solutions:
[tex]\begin{array}{l|cr} g_i(t) & Y_i(t)\\\hline \\ P_n(t) = a_0t^n + a_1t^{n-1}+ ... + a_n & t^s(A_0t^n + A_1t^{n-1} + ... + A_n)\\\\P_n(t)e^{\alpha t} & t^s(A_0t^n + A_1t^{n-1} + ... + A_n)e^{\alpha t}\\\\P_n(t)e^{\alpha t}\left\{\begin{array}{cc} \sin{\beta t\\ \cos{\beta t}\end{array} \right. & t^s[(A_0t^n + A_1t^{n-1} + ... + A_n)e^{\alpha t} \cos{\beta t} + (B_0t^n + B_1t^{n-1} + ... + B_n)e^{\alpha t} \sin{\beta t}]\end{array}[/tex]
So I understand how to choose them, but I wasn't sure whether I need to look and see if what I chose is already a solution.
Now I get it, Thanks Mindscrape and HallsofIvy.
What is a particular solution in the context of differential equations?
A particular solution in differential equations is a specific solution that satisfies the given differential equation. It is obtained by substituting initial conditions into the general solution.
How do you find a particular solution to a differential equation?
To find a particular solution, you must first solve the differential equation to obtain the general solution. Then, substitute the initial conditions given in the problem into the general solution to find the specific particular solution.
What is the difference between a general solution and a particular solution?
A general solution is a formula or set of formulas that contains all possible solutions to a differential equation. A particular solution is a specific solution that satisfies the given initial conditions.
Can a differential equation have multiple particular solutions?
Yes, a differential equation can have multiple particular solutions. This is because the general solution can have multiple constants, which can be adjusted to satisfy different initial conditions.
What is the importance of finding a particular solution in differential equations?
Finding a particular solution allows us to solve real-world problems and make predictions based on mathematical models. It is also necessary for verifying the accuracy of the general solution and understanding the behavior of the system described by the differential equation.
