How Relativity say about redshift in terms of curvature?
In summary, Relativity explains that redshift is caused by the expansion of space. As we go back in time and space, the universe becomes smaller and the frequency drops to zero at the time of the big bang. If we could travel faster than light and go back in time, we could reach a point where there is no outside of the universe. Relativity also states that space is curved by gravity, causing light to curve in both 3-dimensional space and the 4th dimension of space-time.
Ignition
54
Space news on Phys.org
Well red shift is caused by the expansion of space and the further back in distance and time the more red shift. Now think about this as you go back in time and space the smaller the universe until the frequency drops to zero at the time of the big bang. So now think about this if you point any direction and could travel faster than light you could go back to a point in time. So IE light curves in space in the 4d of space. Now Relativity says that space is curved by gravity and light will curve in the 3d of normal space and also curve in the 4th dimension of space time. Also if you can only go back to time zero there is no outside of this bottle we are in.
milt
Related to How Relativity say about redshift in terms of curvature?
1. What is the concept of redshift in relativity?
Redshift in relativity refers to the observed phenomenon of light from distant objects appearing to have a longer wavelength, or "shifted" towards the red end of the spectrum. This is due to the expansion of the universe causing a stretching of the light waves as they travel through space.
2. How does the theory of relativity explain redshift?
According to the theory of relativity, the observed redshift is a result of the curvature of space-time caused by the presence of massive objects. This curvature causes the light to follow a curved path, resulting in a longer apparent wavelength.
3. Can redshift be used to measure the curvature of space-time?
Yes, redshift can be used as a measure of the curvature of space-time. The amount of redshift observed in the light from a distant object can provide valuable information about the distribution of matter and the overall geometry of the universe.
4. What is the relationship between redshift and the expansion of the universe?
The observed redshift in light from distant objects is a direct result of the expansion of the universe. As space expands, the wavelengths of light are stretched, causing the redshift. This relationship is known as Hubble's law.
5. Is redshift the same for all objects in the universe?
No, redshift can vary for different objects in the universe depending on their distance and relative motion. Objects that are further away will generally have a higher redshift, as the expansion of the universe has had more time to stretch the light waves. Additionally, the motion of an object towards or away from the observer can also affect the observed redshift.
