Evaluating double integrals to find area
In summary, the student attempted to find the area of the region bounded by the parabola y = 2x2−2 and the line y = 2x + 2 by sketching the region and evaluating the area integral. However, they are stuck on evaluating the integral.
footboot
Find the area of the region R bounded by the parabola y = 2x2−2
and the line y = 2x + 2 by sketching R, and evaluating the area
integral
A = (doubleintegral) R dxdy.
i found the points of intersection which were -1 and 2 and sketched the region. but I am really stuck on evaluating it. If it was dydx i would have no problem but since its dydx i keep ending up with x's in my answer!
What did you put as the limits for the integrals?
Welcome to PF!
Hi footboot! Welcome to PF! :smile:
(have an integral: ∫ and try using the X2 tag just above the Reply box :wink:)
Show us exactly what you've done. :smile:
im sorry its quite hard ot get used to writing maths on the internet!
The limits i used were 2 and -1 on the left integral and 2x+2 and 2x2 -2 on the right integral.
I integrated with respect to x which just gave x, then filled in the values and got
(2x+2)-(2x2-2) which gave -2x2 +2x +4
I then integrated with respect to y and filled in 2 and -1 for y but all the x's from the first parrt are still there so I get an answer of x2+x+10. Which is obviously not right as I presume the answer should have no variables in it?
Hi footboot! :smile:
oh i see now …
you've integrated in the wrong order!
integrate wrt y first, that gives you a function of x, then integrate wrt x and that gives you a number. :smile:
(alternatively, if you integrate wrt x first, you must do it between limits which are a function of y)
In the question it says dxdy so doesn't this mean i have to integrate wrt to x first? And if i do have to do it that way how would I find the limits as a function of y?
Thanks for your help!
Without seeing the exact question, it's difficult to say.
dxdy = dydx, and the order of integration doesn't matter, so you can do it either way.
However, of course, if the question insists on integrating wrt x first, then it's checking whether you know how to get the limits (which you don't, yet! :wink:), and of course you must do it that way.
So, what are the limits for x (they are functions of y) if you integrate wrt x first? :smile:
(in other words, for a fixed value of y, what are the limits of x?)
In lectures we have been doing examples of functions where dxdy is not equal to dydx so that's why i thought i couldn't do it here. I did integrate wrt y first anyway and came out with an answer of 9 which looks about right from the graph iv drawn.
By changing the limits for x did you mean change the original functions for the parabola and line? because I did that first and i came out with quite complicated terms for the limits! So I am really hoping 9 is right
Thanks for all your help!
footboot said:
… I did integrate wrt y first anyway and came out with an answer of 9 which looks about right from the graph iv drawn.
Unless you show what you've done, I can't say whether it's right. :redface:
I integrated wrt to y and got y, filled in 2x+2 and 2x2-2 into y and got -2x2 +2x +4. Then integrated with respect to x and got -2x3/3 + x2 + 4x. filled in 2 and -1 to this function and ended up with a value of 9. Which is hopefully right as iv been spending hours on this question! Also I was wondering I did a different
integration area question earlier and got a negative answer even though the function was above the x-axis would this indicate that I went wrong somewhere in the question?
Yes, that looks ok. :smile:
(if you got a negative area in another problem, then yes, that's obviously wrong …
I'd guess you got the two limits the wrong way round :wink:)
1. What is a double integral?
A double integral is a mathematical concept used to find the area under a 3-dimensional surface in a specific region. It involves integrating a function over a specific region on a 2-dimensional plane.
2. How do you evaluate a double integral?
To evaluate a double integral, you first need to identify the limits of integration for both the inner and outer integrals. Then, you need to integrate the inner function with respect to the inner variable, followed by integrating the resulting function with respect to the outer variable. This will give you the final value of the double integral.
3. What is the purpose of evaluating double integrals to find area?
The main purpose of evaluating double integrals to find area is to calculate the area under a 3-dimensional surface in a specific region. This can be useful in many applications, such as calculating the volume of a solid or determining the probability of a certain event in statistics.
4. What are some common methods for evaluating double integrals?
Some common methods for evaluating double integrals include using the Fubini's theorem, which allows you to switch the order of integration, and using geometric interpretations, such as finding the area of a rectangle or triangle to represent the double integral.
5. Are there any limitations to using double integrals to find area?
Yes, there are some limitations to using double integrals to find area. For example, the region of integration must be a simple shape, such as a rectangle or triangle. Additionally, the function being integrated must be continuous over the region of integration. If these conditions are not met, alternative methods may need to be used.
