Distance between point and parametric equation
In summary, the conversation discusses how to find the distance between a point and a parametric equation. It is suggested to determine the plane perpendicular to the given line containing the point and find the intersection point. This is the minimum distance from the point to the line. There is also a standard formula for this problem.
natashajane
I've just had a brain block... how do I work out the distance between a point (-5,10,13) and a parametric equation:
x(t) = 57- 4t
y(t) = 75 + 5t
z(t) = -t
You write out an expression for the distance between (-5,10,13) and (x(t),y(t),z(t)) and minimize with respect to t.
he didn't ask for the minimum distance, he asked for the distance. hence the distance will be a function of t
Good point. Don't minimize.
First, he asked for the distance from a point to a "parametric equation" which makes no sense! I assume he meant the distance from a point to the line represented by those parametric equations.
Dick was right to start with: the distance from a point to a line is the minimum distance from that point to any point on the line.
In my opinion the simplest way to find the distance from the point (-5,10,13) to the line represented by the parametric equations, x(t) = 57- 4t, y(t) = 75 + 5t, z(t) = -t, is to determine the plane perpendicular to the given line containing the given point and determine where the line intersects that plane. The distance from point to line is the distance from the given point to that point.
There is, of course, a standard formula for that problem.
What is the distance between a point and a parametric equation?
The distance between a point and a parametric equation is the shortest distance between the point and any point on the curve described by the parametric equation.
How do you calculate the distance between a point and a parametric equation?
The distance between a point and a parametric equation can be calculated using the formula d = √((x - xp)2 + (y - yp)2 + (z - zp)2), where (xp, yp, zp) is the coordinates of the point and (x, y, z) is any point on the parametric curve.
Can the distance between a point and a parametric equation be negative?
No, the distance between a point and a parametric equation is always a positive value. It represents the length of the shortest line segment connecting the point and the curve described by the parametric equation.
How does the parameter value affect the distance between a point and a parametric equation?
The parameter value affects the distance between a point and a parametric equation by determining the specific point on the parametric curve that is being evaluated. As the parameter value changes, the coordinates of the point on the curve change, and therefore the distance between the point and the curve may also change.
What is the significance of finding the distance between a point and a parametric equation?
Finding the distance between a point and a parametric equation can be useful in many applications, such as in physics, engineering, and computer graphics. It allows us to determine the closest point on a curve to a given point, which can help in optimizing designs and solving real-world problems.
