- #1
supag33k
- 6
- 0
How would the solar system capture an extra solar planet ??
Hello! - my first post here...and an informative site to be sure!
I have checked the archives here and checked additional online resources, the point of my question being...
How would the solar system capture an extra solar planet..??
- I admit that I am formulating something to work in creative writing sense ...but don't let that stop anyone contributing...
Essentially I would like someone with real physics knowledge to look it over please...
The understanding I have so far, as a set of two main alternatives listed below. I know the chances are vanishing small to non existent - just want to get my head around the dynamics of it all - is that over several years either could occur...
1. Bad news generally, and for us on Earth especially if...
a. Incoming Exta Solar planet [ES for short] is much larger than Jupiter, and comes inside the orbit of pluto.
b. Incoming ES is larger than Earth and comes inside the orbit of Mars.
c. Incoming ES comes in on a collision trajectory - or head on approach...unlikely given the galactic orbital plane constraints.
d. Incoming ES actually impacts with our sun Sol and cause a major flare/nova event.
e. Incoming ES has orbiting moons that it could conceivably shed during ES capture by our solar system.
I understand in real life the likely outcome - however remote - is as above...as the constraints for point 2 below are most likely impossible..
2. Good news, and the point of my writing to try and verify, if...
a. Incoming ES is between 3 and 4 Earth masses, orbital velocity of 30km per sec.
b. closes on a trailing trajectory gradually overtaking the solar system, the incoming trajectory inclination is about 25 degrees.
c. For calc purposes the solar system is essentially the Sun and Jupiter...and possibly Saturn, so really a major body calculation.
d. On entry to the solar system, the ES misses Pluto, Uranus and Neptune.
e. The incoming ES at closest trailing approach to Saturn approaches with 40 Million km over the south pole on a converging approach, this flattens the inclination to 15 degrees, sheds 4 km sec, and vectors the ES on a trailing approach to Jupiter.
f. The orbital real estate between Mars and Jupiter in our system is not actually "dynamically full" ie Jupiter moved out to it's present position and/or planetary formation is not allowed, but planteray capture via major body deceleration of an ES object still may be valid..??
g. The incoming ES approaches Jupiter on a trailing approach at 24km sec and closest approach is 60 million km - due to Jupiter's much greater mass -
the inclination drops to 5 degrees, and the orbital speed drops to 20km sec.
h. The incoming ES drops into a "standard orbit" with 0.1 eccentricity about 440 million km from the sun, between Mars and Jupiter. My own rough estimates show that this is possible, and that bodes law also works at this point.
i. Possibly tidal heating is a problem on approach of the ES to a Jovian but the Roche limits are never reached...
- obviously the major players have to be in the correct locations otherwise...potentially a big crunch somewhere...
sorry for the longish post ..:uhh:
But as folks can see I have done serious thinking already!
cheers,
supa
cheers,
supa
