How to Solve Mechanics Problems Involving Framed Structures
  • Thread starter mikex24
  • Tags
    Mechanics
In summary, the conversation discusses a problem involving a trapezoidal-shaped metallic bill board plate welded to an inverted L-shaped framework. The framework is made of standard hollow tubing of low carbon steel and the goal is to determine shear forces and bending moments in the frame. The first step is to find the support reactions at the fixed end support, which can be calculated by summing moments of the loading force about it. The conversation also addresses the importance of drawing shear and moment diagrams, and the need for internal upward loads on the horizontal beam for equilibrium. Additional steps, such as calculating P1, P2, x1, x2, M, R, and its components, are necessary to solve the problem.
  • #71
This is where I now don't really know what to do next.
So...
The shear force diagram is going to look something like...a straight line starting at the lhs out to the 0.1m point, then would it be a cubic curve (terminology?) down to -64.5, horizontal line to the very rhs and then a vertical line up to the 0 line?
As for the bending moment diagram, zero until 0.1m then a steady curve down to -61.1 at...the very rhs? Not really sure on this one.
For this particular part, do I need to draw the whole shape back together and draw the respective diagrams underneath? I shouldn't leave them apart, right?
  • #72
So...
, yes, and the value of the shear is 0 in this section
the shear is a quadratictc (parabolic) curve in this section of the problem from x =0.1 to x =2.25, (it is in the form of Ax^2 + Bx + C)
down to -64.5,
yes, at x = 2,25 m
Yes from x = 2.25 to x =2.35 m, it is a horizontal line with a value of -64.5 to the very rhs, then a straight vertical line up to 0 line. Very good! Now you have to draw the shape of the parabola correctly...remembering that the slope of the parabolic shear at a given point is the negative of the load intensity at that point, that is, -20 at x =0.1, and -40 at x=2.25, so the slope gets increasingly negative as you move from left to right.
I'll get back you as soon as I can...
  • #73
Ok brilliant, I'll get that bit done then.
Thanks so much, you've been a massive help so far.
  • #74
how did u get 68.112
D44 said:
I think I have calculated the moment about the rhs point. I have this as 68.112Nm. Does this look about right?
When calculating shear forces and bending moments, do I still need to keep the rectangle and triangle separate? This part is what's causing trouble!
  • #75
when u say cut left of the knee, do u mean cutting the l shaped frame work or cutting it at the start of the horizontal section
PhanthomJay said:
This problem seems to be a popular one. This response is for you and jobz1yes, correct, 64.5 N up Start with the horizontal member first. Draw a free body diagram of that member, isolating it (cutting it) just to the left of the knee. The vertical (shear) force at that cut is 64.5 N, as you have noted. That is the shear at that point. There is also a moment at that point. Can you calculate the moment at that point? It acts opposite and equal to the moment about that point from the trapezoidal load. The moment from the trapezoidal load can be found by breaking that load into a uniformly distributed load and a triangularly distributed load, and summing the moments of the resutants of each about that point.
  • #76
The rectangular load has a resultant load of 20(2.15) = 43 N acting at the cg of it's load, which is (2.15/2) + 0.1 = 1.175 m away from the knee. Thus its moment is 43(1.175) = 50.5 N-m ccw. The triangular load has a resultant load of (20/2)(2.15) = 21.5 N acting at the cg of the load (1/3 its length away from the fat end), which is (2.15/3) + 0.1 = 0.82 m away from the knee. Thus its moment is 21.5(0.82) = 17.6 N-m ccw. And the total of the moments from both those loadings is 50.5 + 17.6 = 68.1 N-m ccw. So the moment just to the left of the knee acting on the horizontal beam is 68.1 N-m cw.
Cut the horizontal beam with a saw just to the left of the knee. That exposes the internal forces and moments at that knee, which we are solving for. They act up and cw respectively, on the beam, and down and ccw, respectively, on the slanted member, per Newton 3.
  • #77
You have to proceed in the same manner; you have established earlier that the moment of the loading about a point x distance from the start is Mx=-(4.65*(x-0.1)^2)*((x-0.1)/3) + (-10(x-0.1)^2). This is a cubic curve. The slope of the moment diagram at a given point is equal to the shear at that point. You can also plug in different values of x to get the numerical values at those different points. After x = 2.25, then the moment diagram continues as a straight slanted line with a slope having the shear value of -64.5 in that short 0.1 m section.
Well, the moment diagram as I explained above includes both the triangular and rectangular loading in the same diagram.
  • #78
right i get it know... this took like 4 hours to understand ... i would recommend to look through http://books.google.co.uk/books?id=...#v=onepage&q=free body diagram moment&f=false
Engineering Mechanics By Sharma D. P.
because u have have to understand how the moment and the force act on the triangular part
any how thanks d44 and jay , much appreciated
PhanthomJay said:
Yes, that looks about right...good work. Now you have to (roughly) draw the shear and moment diagrams... watch your curvatures...then proceed to the slanted member.
  • #79
So in order to get the curve right I can just enter values between 0.1 and 2.15 for x into that equation and whatever the value is then I plot that on the graph?
As for the next part with the slanted section, am I meant to turn that so it's horizontal?
  • #80
yes, you can do it that way, and get exact points, and draw the curve...and as a check, the slope of the shear diagram at a point is equal to the negative of the distributed load intensity at that point, and the slope of the momemt diagram at a point is equal to the shear at that point.
yes, resolve the end forces into components perpendicular and parallel to the slanted member...leave the end momemt as is...and proceed. The parallel force components produce an axial compressive force...it's the perp force components and end moment that produce the shears and moments in that member.
  • #81
Can I just recheck, when I'm drawing these bending moment diagrams, combined, it's a cubic curve? The curve starts at 0Nm at 0.1m and curves down to -61Nm at 2.25m, then a straight diagonal line down to -68.1Nm then back up to 0Nm.
For the reaction forces of the ground on the sloping section I have Fy=64.5N, Fx=17.28N and FR=66.78N. Obviously there's an anti clockwise moment at the top of the slope and a clockwise moment at the bottom. Are they both equal to 68.1Nm?
So when the section is turned to the horizontal position, would there be a force of 66.76N acting vertically down (ground side)? Are there only moments at the top part then? What are the x1 and x2 values needed for that you mentioned on the posts from months ago? I've calculated these, but I'm not entirely sure what they are for? Moments?
  • #82
yes, the moment is in the form of Ax^3 + Bx^2 + Cx + D, in the distributed load piece only
yes, more or less, there is a round off error somewhere, Mx = -61.7 at x = 2.25.
Be careful how you define your axes and components. In the vertical Y direction, Fy = 64.5 N up . There is no horizontal x component. But when you are looking at the slanted member and want to draw a shear and moment diagram, you want to break up the 64.5 N vertical force into its components perpendicular and parallel to the member. The perp comp is 64.5 sin15 (that's the shear), and the axial compressive load is 64.5 cos 15. See post #11 on page 1.
No, the cw moment at the bot is larger...the shear force at the top adds moment.
When you turn the member horizontal by rotating your computer 75 degrees ccw, the shear force at the left is 64.5 sin 15 down,and you know the moment there. Calculate the shear and moment at the fixed (right) using the equilibrium equations, and draw the shear and moment diagrams. The moment at the fixed end should be the P1x1 + P2x2 values you have calculated.
  • #83
So the ground reaction force is the hypotenuse of the triangle used to calculate the other forces? I'd previously written it as the adjacent. Just for future reference, how would you know which it was?
The shear force, 64.5sin15, does this not act at the rhs (ground)? If not, so far at the lhs I have a moment of 68.1Nm, a shear force of 64.5sin15N - at the rhs I have a horizontal force of 64.5cos15N and an moment of 128.4Nm? Am I also trying to find a vertical force at the rhs too?
  • #84
Using the equillibrium equations, the vertical up force at the rhs is equal to the 64.5sin15N force?
What happens with the horizontal force at the rhs? Because the sum of Fx=0, but where does the other horizontal force come from to balance the rhs force? 64.5cos15 from lhs from splitting the 64.5N force up?
  • #85
When you first look at the frame in its entirety, always find the reactions first, using sum of y forces =0, sum of x forces = 0, and sum of moments about any point = 0. When you look in the x direction, there are no applied forces in that direction, hence, no horizontal reaction at the support. There is only a vertical reaction P1 +P2, and a moment, P1x1 + P2x2. The vertical reaction is the resultant hypotenuse if you wish to break it up into comonents parallel and perpendicular to the sloped member.
yes...
yes, the shear force at the right hand side as you noted. Direction of force please at the left and right hand sides?
yes...
yes...the horizontal (axial) force in the member is 64.5 cos 15. You are doing very well so far...now just draw the shear and moment diagrams for this slanted member and you've got it nailed...
  • #86
Shear forces at both ends then, lhs acting downwards at 64.5sin15 and rhs acting upwards at 64.5sin15?
So the axial force of 64.5cos15 is what equals the ground reaction force to make the sum of Fx=0?
When drawing the shear and moment diagrams, how is the axial force incorporated? What effect does it have?
  • #87
Yes! Since the sum of all forces perp to the member must be 0, if you have the shear force down at the left end, then it must act up at the right end,equal in mgnitude, because there are no other external forces applied on the beam in that direction.
The axial compressive force of 64.5cos15 at the lhs must be balanced by an equal and opposite axial component of the reaction force at the ground.
It has no effect when drawing the shear and moment diagrams. You could draw an axial force digram separately, which would be a constant force throughout. When determining the axial and bending memberstresses later, then you combine those stresses for the final results, per P/A +/- Mc/I.
  • #88
Brill, thank you!
My shear force diagram is looking like a vertical line down to -16.69N, horizontal line straight along to the rhs then back up to 0?
As for the BM diagram, I'm not so sure, but it has to go vertically staight down to -68.1Nm and then up to 128.4Nm at the rhs? Is this a curve crossing at the centre point of the 0 line, not a linear line?
The induced stresses are a combination of which, sorry? The shear forces and the axial force? Although I know what the P/A +/- Mc/I means, how am I to apply this? How do you mean per?
  • #89
D44 said:
Brill, thank you!
Yes, you are quite correct.
yes
It doesn't cross the line. The moment at the lhs and the shear at the lhs, both produce ccw moments about the support, so the straight line (not a curved line) from left to right slants down, not up. You must remember that the slope of the moment diagram at a given point is equal to the shear at that point. Thus, its slope is -16.69, a negative slope, and the moment at the right end is thus -68.1 - 16.69(4) = about -134 ( there is a round off error somwhere, as it should agee with the 128.4 you calculated earlier).
It looks like the problem as given on page 1 did not ask for stresses..that's probably the 2nd part of the question.. If you haven't got to stresses yet, don't go any further until you study that topic.
  • #90
i am confused about the moment at the slanting bit... i have worked it out as 134 .. is that right
PhanthomJay said:
Yes, you are quite correct. yes It doesn't cross the line. The moment at the lhs and the shear at the lhs, both produce ccw moments about the support, so the straight line (not a curved line) from left to right slants down, not up. You must remember that the slope of the moment diagram at a given point is equal to the shear at that point. Thus, its slope is -16.69, a negative slope, and the moment at the right end is thus -68.1 - 16.69(4) = about -134 ( there is a round off error somwhere, as it should agee with the 128.4 you calculated earlier). It looks like the problem as given on page 1 did not ask for stresses..that's probably the 2nd part of the question.. If you haven't got to stresses yet, don't go any further until you study that topic.
  • #91
Ok let's crank it out. P1 is (20)(2.15) = 43 and P2 is (20/2)(2.15) = 21.5, so the vert load is 64.5 N. The moment about the support is 43[(2.15/2) +.1 + 4 sin15] + 21.5[(2.15/3) + .1 + 4 sin15] = 134.9 N-m. Or, if you look at the moment at the support in the free body of the slanted member, it's 64.5(4)(sin15) + 68.1 = 134.9 N-m...checks out OK.
  • #92
Using the bending equations, I have a value of approx 88Pa for the induced stresses.
Am I right in using the the biggest moment in the equation, which is at the ground?
  • #93
Sorry, 44.24MPa
  • #94
D44 said:
Sorry, 44.24MPa
It's somewhere around there, I didn't calc out the numbers, but yes, max bending stress is Mc/I where M is the max moment (139 Nm) occurring at the support, which controls the overall frame structural design. The I term comes from the properties of the hollow circle, and c is its outside radius.
  • #95
Hi, i am having the same trouble with this assignment, mainly drawing the free body diagram of each section. Not sure exactly whether to draw it as a full frame or two separate parts.
thanks
  • #96
thanks
First draw it as a full frame to determine reactions at the fixed support at the base. Then break it up into the horizontal piece and slanted piece separately to determine forces and moments in each of those members.
  • #97
Thanks, so for the horizontal piece, when your working out the vertical forces, how do you know whether to use the 20Mn or the 40Mn? and does it only have 2 downward forces due to the billboard and one moment force due to the slanted piece?
Thank you
  • #98
sorry i ment 20Nm and 40Nm
  • #99
M3_CSL said:
Thanks, so for the horizontal piece, when your working out the vertical forces, how do you know whether to use the 20 N/m or 40 N/m ? and does it only have 2 downward forces due to the billboard and one moment force due to the slanted piece?
Thank you
The vertical load is the area of the distributed loading diagram. It's a combimation of a rectangle 20 x 2.15 and a triangle with a long leg of 2.15 and a short leg of 20. Total = 64.5 N. The moment at the right hand side of the horizontal member is the equal and opposite of the moment about that point from the given applied loadings.
13K
  • Mechanical Engineering
