What is the equilibrium distance between two hydrogen atoms?
In summary, the conversation discusses the hypothetical scenario of a universe made up of only two hydrogen atoms and the exact distance at which the attractive and repulsive forces between them would balance. It is mentioned that the H-H bond length is 0.77 Angstrom and that the forces at work are electrostatic. The conversation also touches on the role of electron clouds and the polarizability of the H-atom in this scenario. The question is raised about the mechanism by which attraction exceeds repulsion at different separation distances, and it is noted that this difference becomes significant as the atoms get closer. The topic of photons and their role in mediating the EM force is also discussed. Ultimately, the conversation raises questions about the origin of photons and how
Rade
From another forum an interesting question comes to mind:
Suppose a universe made of only two hydrogen atoms {[P+]e-}. What would be the exact distance of separation where the total of all attractive and repulsive forces would balance ? Thus if < than this distance, union of the two atoms to form hydrogen molecule results.
Rade said:
Suppose a universe made of only two hydrogen atoms ...
This is the assumption we make when we do the standard calculation for the H-H bond length.
Or is there some Cosmological twist to this?
This is incorrect. When the atoms are at the separation where the net force is zero, we say that a hydrogen molecule has formed.
Gokul43201 said:
This is the assumption we make when we do the standard calculation for the H-H bond length.Or is there some Cosmological twist to this?This is incorrect. When the atoms are at the separation where the net force is zero, we say that a hydrogen molecule has formed.
Thank you. It is known that the H-H bond length is 0.77 Angstrom. So, it is exactly at this length that the net force between the two atoms = 0.0, that is, this is where all EM and gravity forces balance to allow the hydrogen molecule to be formed--is this a correct understanding ?
Gravity is weak enough that it doesn't figure in the calculation.
in quantum chemistry, we call this the "gas phase" calculation, we often times do dimers as well to get a fairly good idea of the intermolecular potential in pairwise terms
actually, NIST gives an experimentally-measured equilibrium bond distance of 0.741 A:
http://srdata.nist.gov/cccbdb/exp2.asp?casno=1333740
my own Hartree-Fock+MP2/631G* calculations give the same number
the forces at work here are electrostatic
Thank you all. I would like to take this thread one step further. From above we know that H-H bond forms when the two atoms come within 0.741 A. Suppose in this universe from Post #1 the two atoms by chance come within 1.0 A of each other, or perhaps closer, but never as close as 0.741 A. How do electrostatic forces alone result in union, given, that gravity is not involved ? That is, how do we overcome the coulomb repulsion of the protons to allow union ? It almost seems that, in a universe of only two hydrogen atoms, they could never form union without some "outside" force involved (that is, outside the boundary conditions of the two atoms)--the coulomb would always keep them apart. Is there a place for action of quantum gravity here, whatever that may be ? Please let me know where I error.
You're forgetting about the electrons on those atoms. Simplistically modeled, electron cloud1 attracts proton2 and electron cloud2 attracts proton1. But the electron clouds and the protons repel each other. The attraction exceeds the repulsion for all separations greater than the bond length (0.741A), and conversely for separations smaller than this. The reason for a non-zero net force at any given separation is due to the non-zero polarizability of the H-atom that gives it a dipole moment when in the vicinity of another atom.
Gokul43201 said:
... The attraction exceeds the repulsion for all separations greater than the bond length (0.741A), and conversely for separations smaller than this...
Thank you for your response. But now another questions arises. Do you really mean "all separation" distances ? How would the mechanism you explain above result in "attraction exceeds repulsion" if the two hydrogen atoms were say 2 meters apart ? So, I guess I ask, at what limit of separation distance between the two atoms does the mechanism of "attraction exceeds repulsion" kick into gear ?
Yes, I do.
In no different a manner than if they were 2A apart, only the difference, or net force, would be way smaller.
It's always there for any separation, even if the atoms are 2 lightyears apart, but as the atoms get closer, the difference gets significant. The separation where this any "kicking in" happens depends on what you consider significant.
See first figure and explanation here:
http://www.chem.ucalgary.ca/courses/351/Carey5th/Ch02/ch2-2-1.html
Gokul43201 said:
...It's always there for any separation, even if the atoms are 2 lightyears apart, but as the atoms get closer, the difference gets significant...
This comment brings forth another set of questions. Suppose the hypothetical universe is a circle with diameter of 2 lightyears. Now, place the two hydrogen atoms at each end of the circle opposite each other, 2 lightyears apart. Does not theory predict no EM attraction between the two atoms for 2 years (730 days) since it is photons that mediate the EM force and they cannot travel faster than c ? Next, what is the origin of the photons that will result in the EM attraction when it does occur after 730 days, is it from the two atoms, or from the space-time between the two atoms, or both, or neither ?
1. What is the equilibrium distance between two hydrogen atoms?
The equilibrium distance between two hydrogen atoms is the distance at which the attractive forces between the two atoms are balanced by the repulsive forces, resulting in a stable and minimum energy state.
2. How is the equilibrium distance between two hydrogen atoms calculated?
The equilibrium distance between two hydrogen atoms can be calculated using the Coulomb's law, which takes into account the charges and distances between the atoms. It can also be determined experimentally by measuring the bond length in a hydrogen molecule.
3. How does the equilibrium distance between two hydrogen atoms change with temperature?
The equilibrium distance between two hydrogen atoms is affected by temperature. As the temperature increases, the atoms gain kinetic energy and move farther apart, resulting in an increase in the equilibrium distance.
4. Can the equilibrium distance between two hydrogen atoms be altered?
Yes, the equilibrium distance between two hydrogen atoms can be altered by changing the conditions such as temperature, pressure, and the presence of other molecules. This can result in a shift in the equilibrium position, leading to a change in the distance between the atoms.
5. Why is the equilibrium distance between two hydrogen atoms important?
The equilibrium distance between two hydrogen atoms is important because it determines the stability and strength of the bond between the atoms. It also plays a crucial role in various chemical reactions and properties of molecules containing hydrogen bonds.
  • Atomic and Condensed Matter
