How to show this sum covereges
  • Thread starter zli034
  • Tags
    Sum
In summary, we are discussing the convergence of the sum series \sum_{m=1}^N(\frac{1}{m^4}-\frac{1}{m^6}) and exploring different ways to prove its convergence. One approach is to compare it to 1/m^4, which is a known convergent series. Another approach is to use the theorem that if the infinite sum of f(n) converges and g(n) <= f(n) for all n, then g(n) converges. However, this theorem only applies if the series are positive. Therefore, we must also prove that the series is positive in order to use this theorem.
zli034
107
[tex]\sum_{m=1}^N(\frac{1}{m^4}-\frac{1}{m^6})[/tex]
My math on sum series is very rusty, can anyone show me show this sum converges?
It is not geometric series, right?
Suddenly found out it is needed to show Kolmogorov SLLN of some random varianble.
Thanks in advance
Mathematics news on Phys.org
Have you done the basic algebra?
[tex]\frac{1}{m^4}- \frac{1}{m^6}= \frac{m^2}{m^6}- \frac{1}{s^6}= \frac{m^2- 1}{m^6}[/tex]
Now "compare" that to [itex]1/m^4[/itex] which converges.
Alternatively, one could note that Ʃ1/n4 and Ʃ1/n6 both converge, so Ʃ(1/n4-1/n6) converges (for good measure, it's equal to Ʃ1/n4 - Ʃ1/n6 = π4/90 - π6/945).
Why does Ʃ1/n4 not diverges? I have BS in biology, now I working with probability, only can troubleshoot math with you guys. Thanks
A series of the form Ʃ1/np converges if and only if p>1. There are several ways to prove this, the most common of which is probably the integral test.
A more general way to prove it converges is to use the theorem that if the infinite sum of f(n) converges and g(n) <= f(n) for all n, then g(n) converges.
You can use the theorem with 1/n^2, which converges. All you have to do is show that 1/n^2 > 1/n^4 - 1/n^6 for all n.
*** IF...the series are positive, of course. ***
Perhaps he/she doesn't know that [itex]\sum_{n=1}^\infty \frac{1}{n^2}[/itex] converges, and if he's going to prove this he might as well prove and use
the more general answer by Bahat.
DonAntonio
What is the meaning of sum coverage?
Sum coverage refers to the extent to which a set of data or events are represented or included in a larger total or sum. It is a measure of how well a specific set of data or events captures the overall picture or trend.
Why is it important to show sum coverage?
Showing sum coverage allows for a better understanding and analysis of the data or events being studied. It helps to identify any gaps or biases in the data and provides a more accurate representation of the whole picture.
How can sum coverage be calculated?
Sum coverage can be calculated by dividing the sum of the data or events being studied by the total sum or number of all possible data or events. This will give a percentage or ratio that represents the coverage.
What factors can affect sum coverage?
Sum coverage can be affected by the size and diversity of the data or events being studied. It can also be influenced by any missing or incomplete data, as well as any biases or limitations in the collection or analysis of the data.
What are some ways to visualize sum coverage?
Sum coverage can be visualized using graphs, charts, or tables that display the data as a percentage or ratio. Heat maps, bar graphs, and pie charts are commonly used to show the coverage of different subsets of data within a larger total.
  • General Math
  • General Math
  • General Math
  • Math POTW for University Students
  • General Math
  • General Math
