warfreak131
- 188
Starting with [tex]\psi(r,\theta,\phi)=R(r)Y(\theta,\phi)[/tex] saubstitute into the Schrodinger equation and show (using the technique of separation of variables) that R satisfies:
[tex](\frac{\hbar^2}{2m}\frac{1}{r^2}\frac{d}{dr}(r^2\frac{d}{dr})+\frac{C}{2mr^2}+V(r))R=ER(r)[/tex]
[tex]L^2 Y(\theta,\phi)=CY(\theta,\phi)[/tex]
[tex]C=l(l+1)\hbar^2[/tex]
The way I wrote it above is exactly the way the teacher wrote it, and I'm assuming that the R on the left side of the equation is not a function of r. And that being the case, it passes through the derivatives on the left hand side and and are left with a function of r.
C is a constant, so that entire term is also just a function of r. And V(r) itself is a function of r, therefore I'm inclined to think that you can pull out some constant E and multiply it by some function R(r) to give it the required format.
