lutheranian
- 1
A diaper liner is placed in each diaper worn by a baby. If, after a diaper change, the liner is soiled, then it is discarded and replaced by a new liner. Otherwise, the liner is washed with the diapers and reused, except that each liner is discarded and replaced after its third use (even if it has never been soiled). The probability that the baby will soil any diaper liner is one third. If there are only new diaper liners at first, eventually what proportions of the diaper liners being used will be new, once used, and twice used? Hint: Assume that a diaper liner ready for use is in one of the three states: new, once used, or twice used. After its use, it then transforms into one of the three states described
If A is a transition matrix and v is the initial state vector and
lim Am = L as m -->[itex]\infty[/itex] then eventual state is Lv
I set up the transition matrix with the first column/row corresponding to new liners, the second to once-used, and the third to twice-used, resulting in the following:
A= (1/3, 1/3, 1| 2/3, 0, 0 | 0, 2/3, 0)
The initial vector is v= (1, 0, 0)
I tried finding the limit of Am as m --> [itex]\infty[/itex] using wolframalpha (which is allowed because the homework problems have messy numbers) but the computation times out every time.
