Meson is made up of one quark and one anti-quark
In summary, mesons are particles made up of one quark and one anti-quark. They can undergo annihilation, like an electron and positron, but this is less common due to the weak interaction involved. Mesons also have a similar force to the one that holds a nucleus together, called the Yukawa interaction, which is mediated by mesons.
iasc
In my physics class my teacher said that a meson is made up of one quark and one anti-quark.
But when, for example, an electron are that close to a positron pair annihilation occurs.
Why does this not happen in a meson?
It does, most have a lifetime of nanoseconds
Also note that most mesons are made of a quark and a different kind of anti-quark. For example, a [itex]\pi^{+}[/itex] is made of an up quark and an anti-down quark. So they can't annihilate electromagnetically to photons, but have to go via the weak interaction.
Thank you for clearing that up.
She said something about the same force used to keep a nucleus together is also present in a meson, or something like that.
I didn't completely understand it
Positrons annihilate with electrons, and electrons are ubiquitous. The average atom has one or two dozen (aluminum 13 iron 26). Pi mesons are the lightest strongly interacting mesons. Positive pions will stop and decay to a positive muon in about 26 nanoseconds; Negative pions will stop and often get captured in nuclear atomic orbits, and will get close enough to the nucleus to cause it to break up. Muons are leptons, with a lifetime of about 2 microseconds.
Yes, the 'force' that glues the protons and neutrons together in an atom is an effective force (as opposed to a 'fundamental' force, like the strong nuclear force or the electromagnetic force). This glueing is accomplished, because the particles continously exchange mesons with each other which serve as a mediator; a "messenger" of the force, for lack of better terminology ;)
This is very similar to what holds an electron and an atom-core together. These particles are held together because they exchange photons, which is the mediator of the electromagnetic force. In the nuclear core the role of mediating particle is played by the mesons and the corresponding force is called the Yukawa interaction.
1. What is a meson?
A meson is a subatomic particle that is made up of one quark and one anti-quark. It is a type of hadron, which are particles that are composed of quarks and held together by the strong nuclear force.
2. How is a meson formed?
A meson is formed when a quark and an anti-quark combine together. This process is known as quark-antiquark annihilation.
3. What is the role of quarks and anti-quarks in a meson?
Quarks and anti-quarks are the fundamental building blocks of matter. In a meson, one quark and one anti-quark are bound together by the strong nuclear force to form a stable particle.
4. How are mesons different from other particles?
Mesons are different from other particles because they are made up of both a quark and an anti-quark. This gives them properties that are different from particles made up of only quarks, such as protons and neutrons.
5. What is the significance of the existence of mesons?
The existence of mesons helps to explain the strong nuclear force, which is one of the four fundamental forces of nature. They also play a crucial role in the study of particle physics and the structure of matter.
