If a is even, prove a^(-1) is even
  • Thread starter STEMucator
  • Tags
    even
In summary: T a_2^T ... a_n^T)^{-1} which is (a_1^T a_2^T ... a_n^T)^{-1} since the order of the factors matters.
STEMucator
Homework Helper
2,076
140
If a is even, prove a-1 is even.
We know that every permutation in [itex]S_n, n>1[/itex] can be written as a product of 2-cycles. Also note that the identity can be expressed as (12)(12) for this to be possible.
Suppose a is a permutation made up of 2cycles, say [itex]a_1, ...,a_n[/itex].
We know that :
[itex]a^{-1} = (a_1, ...,a_n)^{-1} = a_{1}^{-1}, ..., a_{n}^{-1}[/itex]
Now since we can write (ab) = (ba) for any two cycle, we know : [itex]a^{-1} = (a_1, ...,a_n)^{-1} = a_{1}^{-1}, ..., a_{n}^{-1} = a_1, ...,a_n = a[/itex]
So if a is an even permutation, it means that |a| is even, say |a|=n. Then |a-1| is also even since |a| = |a-1| for 2cycles.
Thus if a is even, then a-1 is also even.
Is this correct?
We know that :
Is this correct?
It's correct if you can get rid of all that unclearly defined symbolism and verbiage that's giving me a headache. What's the definition of 'even permutation' in simple english? Please don't use symbols!
If a permutation 'a' can be expressed as a product of an even number of 2cycles, then every possible decomposition of a into a product of two cycles must have an even number of 2cycles.
I'll just take the 'definition' part of that. a is a product, right? Write it as a product. So [itex]a=a_1 a_2 ... a_n[/itex] where the a's are tranpositions (2 cycles) and n is even. Now express [itex]a^{-1}[/itex] as a product of transpositions. Be careful about factor order.
1. What does it mean for a number to be even?
A number is considered even if it is divisible by 2 without leaving a remainder. In other words, the number can be expressed as 2n, where n is an integer.
2. How do you prove that a number is even?
To prove that a number is even, you can divide it by 2 and show that it leaves no remainder. Another way is to show that the number can be expressed as 2n, where n is an integer.
3. What is the inverse of a number?
The inverse of a number is the number that, when multiplied by the original number, gives a product of 1. For example, the inverse of 5 is 1/5 because 5 * 1/5 = 1.
4. How do you prove that the inverse of an even number is also even?
To prove that the inverse of an even number is also even, we can use the fact that the product of two even numbers is always even. We know that a is even, so a = 2n for some integer n. The inverse of a is 1/a, which can be written as 1/(2n). This can be simplified to 1/2 * 1/n. Since 1/2 is an even number and 1/n is an integer, the product of the two is also even. Therefore, the inverse of an even number is also even.
5. Can you provide an example of proving that the inverse of an even number is even?
Yes, let's take the number 8. We know that 8 is even because it is divisible by 2. To prove that the inverse of 8 is even, we can use the fact that 8 * 1/8 = 1. Since 8 is even and 1/8 is 1/2 * 1/4, the product of the two is also even. This shows that the inverse of an even number such as 8 is also even.
