Simple and quick question on rotational motions
  • Thread starter SecretSnow
  • Tags
    Rotational
In summary: That radial acceleration is in the opposite direction of the force that held it together, so there is also a negative tangential acceleration.
SecretSnow
66
Hi guys, if a particle that is rotating around a axis at a constant angular acceleration, and at the highest point, it broke loose and flies off tangently and horizontally into the air, does it have a tangential acceleration of r*angular acceleration alpha? Please help! This is found in University physics textbook qns 9.63 and the answer never includes the tangential acceleration although I think it should!
After the particle breaks loose, what forces are acting on it?
I think it's weight...and nothing else? Oh! I see... So the tangential acceleration serves its purpose only when it's rotating?
Yes.
"serves its purpose" is a little bit unclear. The particle, while attached to the accelerating wheel, experiences tangential acceleration and radial acceleration.
lewando said:
Yes.
Serves it purposes meaning speeding up the tangential velocity. So it only still speeds up the tangential velocity while spinning right? Thanks a lot!
Sorry, words are failing me lately. I would say that while the wheel is experiencing angular acceleration, the particle is experiencing tangential acceleration, with a resulting change in tangential velocity (could be speeding up or slowing down based on the direction of angular acceleration), as long as it is attached.
Any time a particle moves along a curved path we can speak about tangential and radial acceleration.
The tangential acceleration is along the tangent of the path, and its magnitude is at=dv/dt, derivative of the speed with respect to time. The radial acceleration is normal to the tangent and points toward the centre of the curvature of the path; the magnitude is v2/R where R is the radius of curvature.
When the particle loses contact, it experiences a different force as before: gravity instead of the resultant force which forced it move along the circle with constant angular acceleration. The acceleration is proportional to the force: the force changes so does the acceleration. At the same time the velocity stays the same as just before loosing the contact, it is horizontal.
As the force is vertical and the particle moves horizontally at the first instant after breaking loose, there is no tangential force acting on it so the tangential acceleration is zero.
Later on, the particle moves like a projectile along a parabola. With respect to that parabola, gravity has both tangential and radial components, so there will be both radial and tangential components of the acceleration.
ehild
What is rotational motion?
Rotational motion is the movement of an object around an axis or center point. It is often described in terms of the object's angular velocity and angular acceleration.
What is the difference between rotational and linear motion?
The main difference between rotational and linear motion is that rotational motion involves movement around an axis, while linear motion involves movement along a straight line. Rotational motion also involves concepts such as torque, moment of inertia, and angular momentum, which are not present in linear motion.
How does rotational motion affect objects?
Rotational motion can affect objects in various ways. It can change an object's orientation, speed, or direction of movement. It can also cause objects to experience forces such as angular momentum or centrifugal force.
What is the role of rotational motion in everyday life?
Rotational motion plays a significant role in many everyday activities. For example, it is involved in the movement of gears in a bicycle, the rotation of wheels on a car, and the spinning of a top. It is also essential in sports such as figure skating, gymnastics, and diving.
How is rotational motion measured?
Rotational motion is typically measured using units such as radians, revolutions, and degrees. These units are used to measure angular displacement, velocity, and acceleration. Other measurements, such as torque and moment of inertia, can also be used to quantify rotational motion.
