Einstein's special relativity beyond the speed of light
In summary, physicists have proposed a new aspect of Einstein's theory of special relativity that allows for faster-than-light motion, using new transformations between inertial frames. However, this idea has already been shown to only work in higher dimensions, and the paper has received criticism for being wrong and not taking into account previous research on the topic. The paper was published in a low-impact, paywalled journal and has not been made available on arXiv.
bohm2
828
55
Not sure if this was posted but this seems like an interesting paper. Then again, I'm not well read in this topic to judge their arguments:
We propose here two new transformations between inertial frames that apply for relative velocities greater than the speed of light, and that are complementary to the Lorentz transformation, giving rise to the Einstein special theory of relativity that applies to relative velocities less than the speed of light. The new transformations arise from the same mathematical framework as the Lorentz transformation, displaying singular behaviour when the relative velocity approaches the speed of light and generating the same addition law for velocities, but, most importantly, do not involve the need to introduce imaginary masses or complicated physics to provide well-defined expressions. Making use of the dependence on relative velocity of the Lorentz transformation, the paper provides an elementary derivation of the new transformations between inertial frames for relative velocities v in excess of the speed of light c, and further we suggest two possible criteria from which one might infer one set of transformations as physically more likely than the other. If the energy–momentum equations are to be invariant under the new transformations, then the mass and energy are given, respectively, by the formulae and where denotes the limiting momentum for infinite relative velocity. If, however, the requirement of invariance is removed, then we may propose new mass and energy equations, and an example having finite non-zero mass in the limit of infinite relative velocity is given. In this highly controversial topic, our particular purpose is not to enter into the merits of existing theories, but rather to present a succinct and carefully reasoned account of a new aspect of Einstein's theory of special relativity, which properly allows for faster than light motion.
http://rspa.royalsocietypublishing.org/content/early/2012/09/25/rspa.2012.0340
Physicists extend special relativity beyond the speed of light
http://phys.org/news/2012-10-physicists-special-relativity.htmlPage2/3PhysicistsextendspecialrelativitybeyondthespeedoflightThis3Dgraphshowstherelationshipbetweenthreedifferentvelocities:v/
Extending Einstein's Theory Beyond Light Speed
http://www.sciencedaily.com/releases/2012/10/121010092742.htm
Lots of math turns out not to have a physical basis...
"We are mathematicians, not physicists, so we've approached this problem from a theoretical mathematical perspective," said Dr Cox. "Should it, however, be proven that motion faster than light is possible, then that would be game changing.
"Our paper doesn't try and explain how this could be achieved, just how equations of motion might operate in such regimes."
time may tell if such math applies to our universe.
It appears only the abstract is available for free...
I find it hard to work up any motivation to worry about a paper that's published in a low-impact, paywalled journal, not available on arxiv, and appears to be a rehash of a topic that's already been carefully studied and found to be uninteresting.
The possibility of defining superluminal frames of reference (as opposed to just describing superluminal particles) has been studied for a long time. There is a no-go theorem described by Vieira, which says that it only works in n+n dimensions. It doesn't work in 3+1 dimensions. The physics.SE thread discusses the fact that this objection also applies to Hill and Cox's work.
Vieira, An Introduction to the Theory of Tachyons, 2011, http://arxiv.org/abs/1112.4187
I'd like to see what those equations are that allow us to travel faster than c! Also, what's non-zero?
Nothing of interest. Except it does serve to illustrate how much popular attention you can garner with the words "faster than light". :tongue2:
If you like, here's the full paper.
I didn't read it, just looked at Fig. 4. If I understand correctly:
v : Velocity of frame B relative to frame A
u : velocity in frame B
U : velocity in frame A
Is that right?
Lets say a rocket fires a missile from it's nose launcher. The missile moves at u = 0.5c relative to the rocket. But In a frame where the rocket moves at v=4c the missile is slower than the rocket (U < 4c) and stays behind it, or destroys it right after launch.
How is that resolved?. Is the entire rocket mirrored in the frame where it moves FTL? Negative length contraction?
Here is a recent note that points out what Cox and Hill did wrong:
Andréka, 'A note on "Einstein's special relativity beyond the speed of light" by James M. Hill and Barry J. Cox,' http://arxiv.org/abs/1211.2246
The criticism is essentially the same as in this thread and the physics.SE thread: the idea only works in n+n dimensions, not 3+1.
But Andréka, like Cox and Hill, doesn't seem to realize that this was all settled way back in 1986 by Recami.
Obviously the RSPA doesn't have very high standards or very knowledgeable reviewers if they accept this kind of paper, which is both wrong and wrong for reasons that have been known and published in the literature for 25 years.
Threads merged.
Thanks a lot for your comments and the link.
It seemed somewhat suspicious so I thought to confirm the results with you guys. :)
1. What is Einstein's special relativity and how does it relate to the speed of light?
Einstein's special relativity is a theory that describes how time and space are affected by the motion of an observer. It states that the speed of light is constant and is the maximum speed that anything can travel in the universe. This means that nothing can move faster than the speed of light.
2. Can anything travel faster than the speed of light according to Einstein's special relativity?
No, according to Einstein's special relativity, nothing can travel faster than the speed of light. This is because as an object approaches the speed of light, its mass increases and the amount of energy required to accelerate it also increases. Therefore, it would require an infinite amount of energy to reach the speed of light, making it impossible.
3. Is there any evidence that supports Einstein's special relativity?
Yes, there is a lot of evidence that supports Einstein's special relativity. For example, scientists have observed that the speed of light is constant in all reference frames, meaning that it does not change regardless of how fast an observer is moving. Additionally, many experiments have been conducted that confirm the predictions of special relativity, such as the time dilation and length contraction effects.
4. What is the concept of time dilation in Einstein's special relativity?
Time dilation is a phenomenon predicted by Einstein's special relativity that states time moves slower for objects that are moving at high speeds relative to an observer. This means that if someone were to travel at extremely high speeds, time would pass slower for them compared to someone who is stationary. This has been proven through experiments such as the Hafele-Keating experiment.
5. Can Einstein's special relativity explain the concept of time travel?
No, Einstein's special relativity does not support the concept of time travel. While it does allow for the possibility of traveling to the future by moving at extremely high speeds, it does not allow for traveling to the past. This is because it would violate the principle that the speed of light is the maximum speed in the universe, and would require an infinite amount of energy.
