Help With Gas/Liquid Pressure/Volume
  • Thread starter Brzostek
In summary, using the ideal gas law and assuming P = 1 atm = 1 bar and temperature is 25 C, if you have a liter of water with a dissolved oxygen level of 10 mg/L, removing all of the oxygen would result in a volume of 0.0224 L of oxygen at 1 atm and 25 C.
Brzostek
1. Assume that a high dissolved oxygen level is 10 mg/L. If you have a liter (L) of water and removed all of the oxygen from it what volume would it occupy? (Use the ideal gas law and assume that P = 1 atm = 1 bar and that temperature is 25 C).
2. PV = nRT
3. Don't know how to use this equation with a gas and liquid.
So how many milligrams of O2 would be removed (assume there are 10 mg/L dissolved in the water)? How many moles of O2 is that? How much volume will that amount of O2 occupy at 1 atm = 101325 Pa. and 25C (Hint: use PV=nRT. What is the temperature in K?)?
AM
I can provide some guidance on how to use the ideal gas law equation in this scenario. The ideal gas law, PV = nRT, relates the pressure (P), volume (V), number of moles (n), and temperature (T) of a gas. In this case, we are dealing with a gas (oxygen) dissolved in a liquid (water), so we need to make a few adjustments.
First, we need to convert the dissolved oxygen level from mg/L to moles/L. This can be done by dividing the given value of 10 mg/L by the molar mass of oxygen, which is approximately 32 g/mol. This gives us 0.3125 mol/L.
Next, we need to consider the fact that the oxygen is dissolved in water, which will exert its own pressure on the gas. This is known as the partial pressure of the gas. In this case, we can assume that the partial pressure of oxygen is equal to the atmospheric pressure, which is 1 atm or 1 bar.
Now, we can rearrange the ideal gas law to solve for volume (V).
V = nRT/P
Plugging in the values we have, we get: V = (0.3125 mol/L)(0.0821 L*atm/mol*K)(298 K)/(1 atm) = 7.66 L
Therefore, if we were to remove all of the oxygen from 1 L of water, it would occupy a volume of 7.66 L. It's important to note that this is an estimate, as the ideal gas law assumes ideal conditions and may not be entirely accurate for a gas dissolved in a liquid. However, it can give us a general idea of the volume that the gas would occupy.
1) What is gas pressure and how is it measured?
Gas pressure is the force exerted by gas molecules on the walls of their container. It is measured in units of pressure, such as atmospheres, pascals, or torr. Gas pressure can be measured using devices such as barometers, manometers, or pressure gauges.
2) How does gas pressure change with volume?
According to Boyle's Law, gas pressure and volume are inversely proportional. This means that as volume increases, pressure decreases, and vice versa. This relationship is described by the equation P1V1 = P2V2, where P1 and V1 are the initial pressure and volume, and P2 and V2 are the final pressure and volume, respectively.
3) What factors affect liquid pressure?
The pressure of a liquid is affected by its density, depth, and the force of gravity. The deeper the liquid, the greater the pressure due to the weight of the liquid above. The density of the liquid also plays a role, as denser liquids exert more pressure. Gravity also plays a role, as it pulls the liquid downward, increasing the pressure at lower depths.
4) How does temperature affect gas pressure?
According to Charles's Law, gas pressure and temperature are directly proportional. This means that as temperature increases, pressure also increases, and vice versa. This relationship is described by the equation P1/T1 = P2/T2, where P1 and T1 are the initial pressure and temperature, and P2 and T2 are the final pressure and temperature, respectively.
5) Can gas pressure be negative?
Yes, gas pressure can be negative. This occurs when the gas is under a vacuum or when it is compressed below atmospheric pressure. Negative gas pressure is typically measured in units of pressure, such as pounds per square inch (psi) or pascals (Pa).
