How do I find acceleration of two block.
In summary, the conversation involved solving a physics problem involving forces and acceleration. The individual was stuck on a step involving finding the tension and acceleration, but with help from the expert, they were able to successfully solve the problem by applying Newton's 2nd law and determining the forces acting on each block. The final solution for acceleration was 1.54m/s^2.
cheater1
34
http://yfrog.com/0k43313183j
Ok i got a, b, and c. But i need help with d.
My attempt was to find the force of block b - Tension of block C
block B = sin(36.9)25 - the force on block b
cos(36.9)25*0.35 - which is the friction.
block C = 30.8N (which I got from part c)
Then I took the force on C-B which I got 22.787N but then tried to divide by the mass to get acceleration. This is there I'm confused. Please help me out and thanks in advance.
What forces act on block B? Apply Newton's 2nd law.
What forces act on block C? Apply Newton's 2nd law.
Combine those two equations and you can solve for both tension and acceleration.
This is the step I am stuck on. What Fb= 22.007N, Fc=30.08N, What equation are you referring to?
What do those forces represent?
Each time you apply Newton's 2nd law, you'll get an equation. So you'll get one equation for block B and another for block C.
Fc-Fb=F and F=ma ?
cheater1 said:
Fc-Fb=F and F=ma ?
One step at a time. What forces act on block B?
Friction and the Tension of the string.
That's two of them. Don't forget gravity. Now apply Newton's 2nd law: ∑F = ma.
Tension - friction= ma?
huh? gravity is a force?
so tension - friction - sin(36.9)(9.8) =ma ?
Of course! The weight of the box.
Almost. The weight of block B is given as 25 N. What are its components parallel and perpendicular to the incline? Express the friction force in terms of the normal force.
Doc Al said:
Of course! The weight of the box.Almost. The weight of block B is given as 25 N. What are its components parallel and perpendicular to the incline? Express the friction force in terms of the normal force.
N= cos(36.9)(25)
Friction = (cos(36.9)25)(0.35)
Tension = 30.8N
∑F= t-f-n?
So i got 30.8-19.99-6.997=3.813N
and mass is 25/9.8=2.55kg
so in the end i get 3.813=2.55a
a = 1.495m/s^2
cheater1 said:
N= cos(36.9)(25)
Good.
Tension = 30.8N
You won't know the tension until you solve for it. Where did you get this value from?
∑F= t-f-n?
Almost. Not "-n" but minus the parallel component of the weight.
Doc Al said:
Good.
∑F= t-f-parallel?
N= cos(36.9)(25)
parallel= sin(36.9)25
T= can't i use the value i got from part c) of the problem?
cheater1 said:
∑F= t-f-parallel?
N= cos(36.9)(25)
Good!
No. The tension will be different once things accelerate.
Doc Al said:
Good!
Then how is it possible to solve for tension?
First finish with block B: write out the equation for Newton's 2nd law.
Then do a similar analysis for block C. What forces act on it?
You'll end up with two equations and two unknowns.
ma=t-f-parallel (block b)
For block C there is only Tension and Weight. F=t-w, ma=t-w (block c), right?
Good. What's the mass of block B?
Good. Two points:
(1) Since the acceleration will be downward, take down as positive: W-T = ma.
(2) What's the mass of block C? (You already know its weight from part c.)
Good. Two points:
Omg you did it!
Mass of B will be 25/9.8=2.55
Mass of C will be (the answer I got from part c), 30.8/9.8=3.14
so with the questions you gave me
w-t=ma and t-f-p=ma
i can t=w-ma and replace t in the 2nd equation
w-ma-f-p=ma, and replacing with what I already know.
30.8-3.14a-cos(36.9)(25)(0.35)-sin(36.9)25=2.55a
8.79=5.69a
a=1.54m/s^2
Thank you so much for you help, never could have done this without you!
1. What is acceleration?
Acceleration is the rate at which an object's velocity changes over time. It is a vector quantity, meaning it has both magnitude and direction.
2. How is acceleration calculated?
Acceleration is calculated by dividing the change in velocity by the change in time. The formula for average acceleration is a = (vf - vi) / t, where vf is the final velocity, vi is the initial velocity, and t is the time interval.
3. How do I find acceleration of two blocks?
To find the acceleration of two blocks, you will need to know the mass of each block and the net force acting on the system. You can then use the formula a = Fnet / m to calculate the acceleration, where Fnet is the net force and m is the total mass of the system.
4. Can the acceleration of two blocks be different?
Yes, the acceleration of two blocks can be different if they have different masses or if they are being acted on by different forces. However, if the blocks are connected by a rope or other constraint, their accelerations will be equal.
5. How does friction affect the acceleration of two blocks?
Friction can decrease the acceleration of two blocks by creating a force that opposes the motion. This force must be taken into account when calculating the net force and acceleration of the system.
