Reactions of calcium carbonate
In summary: to the equilibrium lying far on the side with solid calcium carbonate, just to make the reaction irrelevant - note, that they are identical, just reversed.
Moogie
168
Hi
What is the reaction of calcium carbonate and water. I thought it was insoluble but I was looking up some notes from a chemistry practical i did and it says
CaCO3(s) + H2O (l) → Ca(OH)2(s) + CO2(g)
Can someone please explain this reaction for me as I can't find it on the internet.
I'm familiar with the reverse reaction
Ca(OH)2(aq) + CO2(g) → CaCO3(s) + H2O(l)
but I would appreciate an explanation of why this reaction occurs.
Many thanks
Chemistry news on Phys.org
Equilibrium of this reaction is shifted far to the solid calcium carbonate side. However, assuming the mixture is in contact with air free of carbon dioxide (not that such thing exist in nature) dissolution reaction is not impossible (hint: LeChatelier's principle, you are removing one of the products). But this is more theoretical construct than something that may happen in the reality.
Thanks for your reply but I don't know what you mean. Which reaction are you describing? I think you mean the first reaction as you mention dissolution but why does it matter how much CO2 is in the air when the calcium carbonate is in the water? But I am only really interested in what happens under normal conditions, not extreme conditions. So is it correct to say calcium carbonate is generally insoluble? The notes i have say it formed a milky white ppt in water with ph 11 but i don't know what is supposed to be happening. The best i could imagine was that the carbonate might abstract a proton from water to make bicarbonate
I have referred to the equilibrium lying far on the side with solid calcium carbonate, just to make the reaction irrelevant - note, that they are identical, just reversed.
Because carbon dioxide is between the dissolution product. Do you know LeChatelier's principle?
Yes, unless you lower pH.
Moogie said:
Hi
Many thanks
Where did you find that reaction? Non considering very pathological situations (described by Borek), you can confidently consider it incorrect.
If, instead, you were considering this other reaction:
CaCO3(s) + CO2(g) + H2O(l) → Ca(HCO3)2(s)
It would be different.
I thought it was wrong. That was why I asked the question. :)
So what does happen when you add CaCo3 to water? Please can you give reaction and observations. Does it form a milky white solid ppt and an alkaline pH?
I believe this reactions only occurs in exess CO2?
No milky white, unless you use powdered carbonate and mix it with water. Just a piece thrown into water will dissolve a little bit, to the extent described by several equilibrium constants - solubility constant, carbonic acid dissociation constants. pH will go up to almost 10 (that is assuming there is no carbon dioxide in the air, if it is present, pH won't go that high).
Depends on what you mean by 'excess'. Amount present in the air is enough for the reaction to occur and carve karst landscape.
Thanks, so when you add the lump of CaCo3 to water and it dissolves a little bit, what is the reaction that is occurring. Wikipedia says the water has to be saturated with CO2 for this to occur so does that mean it ISN'T this reaction as water isn't saturated with co2?
If it isn't this reaction, what reaction is it please?
CaCO3 in water dissolves according to the most obvious reaction equation:
CaCO3 -> Ca2+ + CO32-
However, this goes only till the solution is saturated, which happens quite fast, as CaCO3 is weakly soluble.
This reaction is followed by CO32- hydrolysis (to HCO3-) which slightly increases solubility.
Now, I haven't read the wikipedia article you refer to, but either it is misleading or you are reading it wrong. Presence of carbon dioxide substantially increases carbon carbonate solubility, but is not necessary for the carbon carbonate dissolution.
Thanks. I presume then that the alkaline ph is because the carbonate ion is the conjugate base of a weak acid so it abtracts a proton from water to give hydrogen carbonate as you say and OH-
Yes, that's hydrolysis that I referred to.
this is the wikipedia link
http://en.wikipedia.org/wiki/Calcium_carbonate:
Calcium carbonate will react with water that is saturated with carbon dioxide to form the soluble calcium bicarbonate.
CaCO3 + CO2 + H2O → Ca(HCO3)2
What role does CO2 play in that reaction because, as you have just shown me, that reaction happens anyway in two steps without co2:
1) dissolution of ca/carbonate ions
2) carbonate hydrolysis to bicarbonate
In other words, why does CO2 increase the solubility of carbonate? I tried to think in terms of le chateliers principle but couldn't see why. carbon dioxide and water gives carbonic acid which dissociates to hydrogencarbonate. This is one of the productions of the hydrolysis of carbonate which makes me think it would reduce solubility. So obviously my logic is warped. Please can you correct it for me :)
CO32- + CO2 + H2O -> 2HCO3-
Try to apply LeChatelier's principle now.
Ah right, i see. That's brilliant I get it now.
However, i don't understand why carbon dioxide features in the hydrolysis reaction. Can i ask the following:
a) being as carbonate is the conjugate base of a weak acid it would do this reaction if carbond dixoide wasn't present?
CO3[2-] + H20 <=> HCO3[-]
b) why does the carbon dixoide participate in the reaction (and please don't say, I don't know, you'll have to ask it :-D). Perhaps there is no simple reaction to that one but i thought i would ask anyway
It is all in equilibrium.
Presence of CO2 means presence of carbonic acid, so you have a mixture of CO32- and H2CO3. Obviously one is an acid, the othe rone is a base, so they will react, producing HCO3-.
First reaction you wrote - hydrolysis of CO32- - takes place whenever carbonates are dissolved in water, but only to some extent. Presence of carbon disoxide automatically shifts the equilibrium right.
1. What are the chemical reactions of calcium carbonate?
Calcium carbonate can undergo a variety of chemical reactions depending on the conditions. In general, it can react with acids to produce carbon dioxide gas, water, and a calcium salt. It can also react with bases to form calcium hydroxide and carbon dioxide. At high temperatures, calcium carbonate can decompose into calcium oxide and carbon dioxide.
2. How does calcium carbonate react with acids?
When calcium carbonate reacts with an acid, a neutralization reaction occurs. The calcium carbonate acts as a base and reacts with the acid to form water, carbon dioxide, and a calcium salt. For example, when calcium carbonate reacts with hydrochloric acid, the products are water, carbon dioxide, and calcium chloride.
3. What happens when calcium carbonate reacts with bases?
When calcium carbonate reacts with a base, a double displacement reaction occurs. The calcium carbonate and the base switch partners to form calcium hydroxide and the salt of the base. For example, when calcium carbonate reacts with sodium hydroxide, the products are calcium hydroxide and sodium carbonate.
4. How does temperature affect the reaction of calcium carbonate?
The reaction of calcium carbonate can be affected by temperature. At high temperatures, calcium carbonate can decompose into calcium oxide and carbon dioxide. This reaction is reversible, so as the temperature decreases, the calcium oxide can react with carbon dioxide to form calcium carbonate again.
5. What are some common uses of calcium carbonate?
Calcium carbonate has many practical applications. It is commonly used as a dietary supplement for calcium, as an antacid to neutralize stomach acid, and as an ingredient in toothpaste and other dental products. It is also used in the production of cement, paper, and plastics.
  • Chemistry
  • Biology and Chemistry Homework Help
