Do objects made of different matterials radiate at different rates?
  • Thread starter rds-s
In summary: Every material has a property called emissivity, this is determines how much energy it radiates. Yes it varies from material to material.
rds-s
I have a question regarding heat transfer/ heat loss. When the sun goes down, let's say in December, is it possible that some objects lose heat (through radiation) at a quicker rate than other objects? If so, colder objects would lose heat, or emit radiation, to its surroundings (warming its surroundings). I doubt this is possible because I'm thinking it would violate the 2nd law of thermodynamics.
Objects colder than ambient cannot radiate heat; they absorb heat from hotter objects. This is a consequence of the Zeroth Law of Thermodynamics.
Some objects emit and absorb more radiation than others. For visible light, those objects appear darker (as they are not hot enough to emit significant quantities of visible light). If you heat them up, they can appear brighter than other materials. For infrared radiation, it is the same - some objects cool down quicker than others, if they are hotter than the environment. If you shine IR radiation on them, they will heat quicker as well.
I think you have this wrong ! What about an object at the same temperature as ambient?
What would happen when the ambient cooled to below the object temperature... would the ambient cease to radiate and the object take over to radiate ! Think about the physics.
I think/hope that you are only confused about 'net' rate of heat transfer.
So let's say the sun warmed a sidewalk abutting black pavement and the air surrounding it all. And then the sun goes down. Actually, for this scenario let's say the sun disappears. The pavement, sidewalk and air no longer have the warming energy of the sun and would then radiate (lose) thermal energy. I would imagine that the three objects radiate heat at different rates. Would that not mean one of the objects (sidewalk, pavement and air) would be cooler than the others? Or would all three objects have to cool down at the same rate?
Every material has a property called emissivity, this is determines how much energy it radiates. Yes it varies from material to material. Of course the temperature differential determines which way the energy goes.
A clear night sky has a very low temperature for radiation purposes. One of my profs claimed that if you took a good thermos jug put a little water in the bottom and pointed the opening at a dark (few stars) portion of sky, you could freeze the water, even on a warm summer night. I might take a while.
Lets say we are walking on grass field shortly after the sun goes down. We walk onto a blacktop asphalt surface. Do we perceive more heat coming off of the blacktop? Probably yes.
The grass field might not be the best example of material but you get the idea.
Related to Do objects made of different matterials radiate at different rates?
1. What is radiation and how does it differ between materials?
Radiation is the process of emitting energy in the form of waves or particles. It can occur in different forms such as electromagnetic radiation or thermal radiation. The rate at which an object radiates energy depends on its material composition, with different materials having different abilities to absorb and emit radiation.
2. Do all materials radiate at the same rate?
No, different materials have different abilities to radiate energy. This is due to differences in their atomic and molecular structures, which affect how they absorb and emit radiation.
3. How does the atomic structure of a material affect its radiation rate?
The atomic structure of a material determines the amount and type of energy it can absorb and emit. Materials with higher atomic numbers, such as metals, have more electrons and can absorb and emit more energy compared to materials with lower atomic numbers, such as plastics.
4. Can the temperature of a material affect its radiation rate?
Yes, the temperature of a material can affect its radiation rate. The higher the temperature, the more energy it emits, as hotter objects have more molecular motion and can emit more radiation.
5. How is radiation rate measured in different materials?
Radiation rate can be measured using different units, such as watts or joules per second. The specific unit used depends on the type of radiation being emitted and the properties of the material. For example, thermal radiation is often measured in watts, while nuclear radiation is measured in becquerels or curies.
  • Earth Sciences
  • Other Physics Topics
  • Thermodynamics
