Back EMF in Solenoid: Explaining Current Flow
In summary, when an ideal solenoid is connected across an AC supply, the back EMF induced in it will be equal and opposite to the source voltage, causing the current to rise to a point where the back EMF exactly cancels out the applied voltage. This is similar to the behavior of current in a resistance, where the voltage across it increases until it opposes the applied voltage. However, in a practical motor, there is armature resistance that must be accounted for. When considering a solenoid connected to a DC source, the current will continue to increase as long as the applied voltage is constant, due to the relationship between voltage, inductance, and the rate of change of current. In the steady state, the
QwertyXP
66
Consider an ideal solenoid (no resistance, no leakage reactance etc.) connected across an AC supply. The back EMF induced in it will be exactly equal and in opposite direction to the source voltage (which means that when a certain terminal of the AC supply is positive, the side of solenoid connected with it would also be positive, and vice versa).
My question is, how will current flow at all when the EMFs of AC source and solenoid are cancelling each other out? It's like having having a circuit with only two batteries and terminals of similar polarities shorted with each other.
I've read quite a few explanations on the internet but have yet to fully understand what's happening here.
The back emf is proportional to di/dt, so if no current flowed there would be no back emf. Current will rise to the value where di/dt is such that back emf exactly opposes applied voltage.
This is not much different from current in a resistance. The voltage across a resistance increases as the current increases (obeying Ohms Law) until the voltage across the resistance exactly opposes the applied voltage.
i didn't really get this. I was comparing ''back EMF'' of a solenoid with the emf induced across a DC motor's armature. When the motor's back EMF = source voltage, no current flows. So it's like connecting a battery with opposite polarity.
Considering a resistor directly connected across a source, once the voltage across it is equal to source, the current through it does not increase because for that there would have to be a difference in potential. However, if you connect a solenoid across a DC source, the current through it continues to increase for a certain time even though source voltage = back EMF. With no difference in potential, how is this possible?
Also, the solenoid circuits's equation doesn't appear to be balanced:
V(source)=Back EMF (which is equal to source) + CurrentxReactance
when back EMF = source, the CurrentxReactance part should be zero!?
In an "ideal lossless" motor, yes. In a practical motor, there is armature resistance, so that drop has to be accounted for.
v=L.di/dt so if the applied voltage is maintained constant, di/dt will be constant, meaning current continues to ramp up forever (in a lossless inductor).
For sinusoidal AC, in the steady state, the back emf is the current x reactance term.
I can assure you that current will still flow in an ideal solenoid connected to an AC supply, despite the back EMF being equal and opposite to the source voltage. This is due to the fact that the back EMF is induced in the solenoid coil as a result of the changing magnetic field created by the alternating current in the solenoid. This changing magnetic field induces a current in the solenoid coil, which will flow in the opposite direction to the applied voltage.
In an ideal solenoid, there is no resistance or leakage reactance, meaning that the induced current will flow freely without any hindrance. This is similar to a superconductor, where current can flow without any resistance. Therefore, even though the back EMF may be equal and opposite to the source voltage, the induced current will still flow in the solenoid.
To better understand this concept, it may be helpful to think of the solenoid as a simple circuit with a resistor and an inductor in series. The back EMF can be thought of as the voltage drop across the inductor, while the source voltage is the voltage applied to the entire circuit. In this analogy, the resistor represents the resistance of the solenoid, which in an ideal solenoid is negligible. Therefore, the induced current will still flow through the solenoid, despite the back EMF and source voltage being equal and opposite.
In summary, the back EMF in an ideal solenoid does not cancel out the current flow, but rather it is a result of the changing magnetic field created by the alternating current in the solenoid. This induced current will flow in the opposite direction to the applied voltage, but will not be hindered by any resistance or leakage reactance in an ideal solenoid. I hope this explanation helps to clarify the concept for you.
1. What is back EMF in a solenoid?
Back EMF, or electromotive force, refers to the voltage that is generated in a solenoid when the current flowing through it is suddenly interrupted or changed. This voltage is opposite in direction to the applied voltage and is caused by the collapse of the magnetic field within the solenoid.
2. How does back EMF affect current flow in a solenoid?
When back EMF is present in a solenoid, it opposes the flow of current and can cause a decrease in current intensity. This is due to the fact that the voltage generated by back EMF is in the opposite direction of the applied voltage, making it more difficult for current to flow through the solenoid.
3. What causes back EMF in a solenoid?
Back EMF is caused by the change in magnetic field within a solenoid. When the current through the solenoid is suddenly interrupted or changed, the magnetic field collapses and induces a voltage in the opposite direction to the applied voltage, resulting in back EMF.
4. Can back EMF damage a solenoid?
In most cases, back EMF does not cause damage to a solenoid. However, if the voltage generated by back EMF is high enough, it can potentially cause damage to the insulation or windings of the solenoid. This is why it is important to consider back EMF when designing circuits with solenoids.
5. How can back EMF be reduced in a solenoid?
Back EMF can be reduced by using a diode in parallel with the solenoid. The diode allows the current to flow in a loop when the solenoid is turned off, preventing the sudden interruption of current and the resulting back EMF. Additionally, using a resistor in series with the solenoid can also help to reduce back EMF.
  • Electrical Engineering
