Boas: Mathematical Methods for Phys Sci Pr.1.13.25
In summary: ManessIn summary, the Maclaurin series for function f(x) is 1+x+x^2/2+x^3/6+\cdot\cdot\cdot. If x<0, then the series is undefined, but if x=0, then the series is the limit of 1+u/2+u^3/6+\cdot\cdot as u goes to 0.
kq6up
368
Mclaurin Series with Division by Zero?
Using the methods of this section:
(a) Find the first few terms of the Maclaurin series for each of the following functions.
(b) Find the general term and write the series in summation form.
(c) Check your results in (a) by computer.
(d) Use a computer to plot the function and several approximating partial sums of the
series.
[tex]f(x)=\frac { 2x }{ { e }^{ 2x }-1 } [/tex]
[tex]f(x)=\sum_{n=0}^{\infty}f^{n}(0)x^{n}/n![/tex]
Since f(0) is division by zero, how do you find a Maclaurin series for it?
Thanks,
Chris Maness
Yes, the function, as written, is not defined. But it is a "removable" discontinuity. I suspect they intend you to use the limit there. You can simplify by letting u= 2x. Then the limit is [itex]\lim_{u\to 0}\frac{u}{e^u- 1}[/itex]. And now you can take that limit in a number of ways:
1) L'Hopitals rule: differentiating both numerator and denominator gives [itex]\frac{1}{e^u}[/itex] which has limit 1 as u goes to 0.
2) Since you are dealing with MacLaurin series, the MacLaurin series of [itex]e^u[/itex] is [itex]1+ x+ x^2/2+ x^3/6+ \cdot\cdot\cdot[/itex]. So [itex]e^u- 1= u+ u^2/2+u^3/6+ \cdot\cdot\cdot[/itex] and [itex]\frac{u}{e^u- 1}= \frac{u}{u+ u^2/2+ u^3/6+ \cdot\cdot\cdot}[/itex][itex]= \frac{1}{1+ u/2+ u^3/6+ \cdot\cdot\cdot}[/itex] which again has limit 1 as u goes to 0.
(It would have been better if the problem had said "[itex]f(x)= \frac{2x}{e^{2x}- 1}[/itex] if [itex]x \ne 0[/itex], [itex]f(0)= 1[/itex]".)
Likes 1 person
Find the limit, if it exist, as x goes to 0.
Likes 1 person
Yes, they don't mention using the limit if f(0)=D.N.E, and I should have use L'Hosp.
Thanks,
Chris
1. What is the purpose of the book "Boas: Mathematical Methods for Phys Sci Pr.1.13.25"?
The book "Boas: Mathematical Methods for Phys Sci Pr.1.13.25" is a comprehensive guide to mathematical methods commonly used in the physical sciences. It is designed to help students and professionals in the field understand and apply these methods to solve complex problems.
2. Who is the author of "Boas: Mathematical Methods for Phys Sci Pr.1.13.25"?
The author of "Boas: Mathematical Methods for Phys Sci Pr.1.13.25" is Mary L. Boas, a renowned physicist and mathematician who has taught at various universities and authored numerous textbooks in the field of mathematical methods.
3. What topics are covered in "Boas: Mathematical Methods for Phys Sci Pr.1.13.25"?
The book covers a wide range of topics including calculus, differential equations, linear algebra, complex analysis, Fourier analysis, and more. It also includes numerous examples and exercises to help readers practice and apply the concepts.
4. Is "Boas: Mathematical Methods for Phys Sci Pr.1.13.25" suitable for self-study or is it better used as a textbook in a classroom setting?
The book can be used for both self-study and as a textbook in a classroom setting. It is written in a clear and concise manner with plenty of examples and exercises, making it suitable for self-study. However, it can also be used as a textbook with the guidance of an instructor.
5. Are there any prerequisite knowledge or skills required to understand "Boas: Mathematical Methods for Phys Sci Pr.1.13.25"?
Some basic knowledge of calculus and algebra is recommended, but the book is designed to be accessible to students and professionals in the physical sciences with varying levels of mathematical background. It starts with the fundamentals and gradually builds upon them, making it suitable for readers with different levels of mathematical proficiency.
