Oscillations: Pendulum with initial velocity
In summary: Acosδ=0.253-Asinδ=-0.319We have to find δ from these equations. Divide the second by the first. tanδ=-0.319/0.253=-1.261δ=-51.6°Note that the sign of tanδ gives the quadrant of δ. Here δ is in the fourth quadrant, between -90° and -180°. ehildIn summary, a child on a 4m long swing is pulled back 1m from the vertical and released with a push imparting a speed of 2m/s. By using the equations θ = θmax*cos(ωt + δ) and ω = √g
Stealth849
38
A child on a 4m long swing is pulled back 1m from the vertical and released with a push imparting a speed of 2m/s. Find an expression for the angle θ, as a function of time, identifying the frequency ω, amplitude θi, and phase constant δ.
ω = √g/l
I got a value for omega, from √g/l, of 1.565
The fact that the child starts with initial velocity is really throwing me off. In order to find the phase constant, I've tried looking at equations
v = -ωθ*sin(δ)
θ = θi*cos(δ)
and solving for tan(δ) to get a value for δ of 3.17rad...
I don't even know if this is valid, but I otherwise don't know where to start.
I know that if the child is starting from an angle of 0.253rad with initial velocity, he should travel passed the point where I can use small angle approximation.
I thought also about differentiating the basic equation for harmonic motion θ = θmax*cos(ωt + δ) to get velocity, and setting that velocity equal to 2 at time 0, but there are still two unknowns. Any help will be appreciated. Thanks!
ω = √g/l
v = -ωθ*sin(δ)
θ = θi*cos(δ)
Your equations are not correct. In the small-angle approximation,
θ(t)=Acos(ωt+δ)
If Ω is the angular velocity of the pendulum, Ω=V/L
Ω(t)=dθ/dt=-Aωsin(ωt+δ)
You push the child inward, so the direction of the initial velocity V is opposite to the displacement theta. Taking V negative you get a phase constant less than pi/2.
The If you can apply small angle approximation depends on the maximum angular displacement, the amplitude. Get A by from the equation A2=θ(0)2+(Ω(0)/ω)2.
ehild
I'm not sure I completely understand..
I am using θi to signify amplitude for a simple pendulum in the equations that you mentioned are incorrect, but when I look at how you say to find amplitude, θ(0) and dθ/dt (0) give me the equations you say are incorrect.
θ(t)=Acos(ωt+δ)
say I am using this, where A is amplitude instead of θi, if t = 0,
θ(t)=Acos(δ)
and if t = 0 here,
then
dθ/dt=-Aωsin(δ)
And from those, would I not still need a phase shift value to solve the equation for A in
A^2= A^2cos(δ)^2 - A^2sin(δ)^2
Or am I just missing something blindingly obvious...?
θ(t)=Acos(ωt+δ)
θ(t)=Acos(δ)
and if t = 0 here,
then
dθ/dt=-Aωsin(δ)
That is wrong. A^2= A^2cos(δ)^2 +A^2sin(δ)^2, as cos(δ)^2 +sin(δ)^2=1.
Note that the initial θ is not the amplitude. θ(0) = 0.253 rad, as you have found already and dθ/dt is initially -2(m/s)/4(m).
ehild
Okay, I'm starting to see it...
where Acos(δ) = 0.253 = θ(0)
and -Aω*sin(δ) = -0.5 = dθ/dt at 0
so
A^2 = (0.253)^2 - 0.5^2
and solve for A.
I don't see how I would find the phase shift however. Does it involve dividing the sin and cos functions and solving for tan (δ)?
so
and solve for A.
Check the eq. in red, it is not correct.
Yes, you do just that.
ehild
I have to divide the second term by ω = 1.565, yes?
A^2 = (0.253)^2 - (0.5/1.565)^2
Then
tan (δ) = AΩ(0)/-Aωθ(0)
I don't know how to determine which quadrant the function would be in, as in how to determine how sin and cos are positive or negative. Would only cos be negative if the denominator is negative in the equation?
Why minus??
Stealth849 said:
Then
What is Ω(0) = V/L=-2/4. So both sin(δ) and cos(δ) is positive, δ is in the first quadrant.
In the second quadrant, sine is + and cosine is -
In the third quadrant, bot sine and cosine are -
In the fourth quadrant, sine is - and cosine is +
ehild
Ahh, forgot the fact that it is squared. Sorry that took so long to catch. I see it is positive now, not negative.
So ultimately, we have an equation where
A = 0.408
tan(δ) = -0.204/-0.162 = 0.33
in quadrant 1,
δ = 0.033
so
θ(t) = 0.408*cos(1.565t + 0.033) ?
A = 0.408
tan(δ) = -0.204/-0.162 = 0.33?
in quadrant 1,
δ = 0.033?
so
The amplitude is OK. I do not understand how you calculated delta. It is not right.
Acosδ=0.253
-Asinδ=-0.319
Where did -0.204 and -0.162 come from?
ehild
I multiplied A by Ω(0)
0.408*(-0.5)
and -A by ωθ(0)
-0.408*1.565*2.53 = -0.162I see now I already had the values for Acos(δ) and -Asin(δ)
tan(δ) = 0.319/0.253
δ = 0.9
so my equation for tan, tan (δ) = AΩ(0)/-Aωθ(0) is actually incorrect, because I am changing the ratios if i choose to multiply by reciprocal... I needed to keep the divisions separate to keep the sine and cos ratios. silly silly mistake. sorry for all the trouble.
should be
tan (δ) = (Ω(0)/-Aω)/((θ(0)/A)
It is correct now. No need to divide by A, it cancels when you calculate the tangent.
ehild
1. What is a pendulum with initial velocity?
A pendulum with initial velocity is a type of simple harmonic motion in which a pendulum is given an initial push or velocity that causes it to oscillate back and forth.
2. What factors affect the period of a pendulum with initial velocity?
The period of a pendulum with initial velocity is affected by the length of the pendulum, the gravitational acceleration, and the initial velocity given to the pendulum.
3. How does the amplitude of a pendulum with initial velocity change over time?
The amplitude of a pendulum with initial velocity decreases over time due to the effects of damping, which is the gradual loss of energy in the system.
4. What is the relationship between the period and frequency of a pendulum with initial velocity?
The period and frequency of a pendulum with initial velocity are inversely proportional - as the period increases, the frequency decreases, and vice versa.
5. Can the initial velocity of a pendulum affect its maximum displacement?
Yes, the initial velocity of a pendulum can affect its maximum displacement. A higher initial velocity will result in a larger maximum displacement, while a lower initial velocity will result in a smaller maximum displacement.
