Help coming up with a formula for determining weight lost in cold.
In summary, the conversation discusses the idea of losing weight by staying in the cold for extended periods of time. The participants mention the relationship between cold temperatures and calorie burning, as well as the potential for creating a formula to determine how much weight one may lose based on factors such as weight, time spent in the cold, and temperature. However, it is also mentioned that other factors such as an individual's metabolic rate, fat reserves, and ambient temperature also play a role in weight loss in the cold. The conversation highlights the need for specific knowledge in physics and biology to accurately calculate the effects of cold temperatures on weight loss.
wasteofo2
478
When you're cold, your body naturally burns calories to keep you warm. So it makes sense to me that if people were to just stay out in the cold enough, that they could lose some weight. Also, it seems that you could probabally figure out a formula to determine exactly how much weight you'll lose depending on how much you weigh, how long you stay out in the cold, and how cold it is. Though I suppose the specific heats of your bodily substances besides water would be of great importance in figuring it out exactly...
So first off, I'd have to know the average specific heat of the organic compounds in your body, then find the average specific heat of your body as a whole. After I've got the average specific heat of the human body, I'd need to know exactly how much heat cold air would "steal" form the body per a specific temperature.
Could anyone help me out a bit here? I'm somewhat brain-boggled right now, and can't really think of how this would work out...
Biology news on Phys.org
yea, i guess it does make sense but i think it's the same as starving youself. in the cold, you burn more calories to function your body AND to keep warm so you would quickly feel hungry, so you eat to get more calories and the same goes on. keep on burning and eating. if you don't eat, you'd lose weight (in an unhealthy manner) by starving yourself in the cold.
Yes, I've maintained that the best way to lose weight is to open the refrigerator...and stay put. :biggrin:
The specific heat is not what you want. THere are two quantities more important that it, which determine the rate of heat loss. They are : (i) the mean thermal conductivity of body tissue, and (ii) the convective heat transfer coefficient of skin (with/without hair). Get these numbers, and I'll help you with the calculation - this is a physics probem, even if it is set in a biological context.
It might be good to acknowledge that the body can only break down fat at a set rate. If this was not so then people would not freeze to death until they starved. Hope this has some meaning.
-Scott
You would also have to factor in the individual's metabolic rate, how much fat reserves they have (not just as an energy supply, but also as insulation), whether they are eating any other food that provides energy, etc. What you really need to figure out isn't just how quickly a body loses heat, which would only apply to a corpse (such a measure can be used to help approximate time of death), but at what ambient temperature the body cannot provide enough heat energy through metabolism, shivering, vasoconstriction in extremities to keep blood restricted to the body core, etc., to maintain body temperature. In other words, when does the rate of heat loss exceed the ability of the body to generate heat. The temperature at which this occurs would also depend on things like humidity, which would affect conductivity of the heat away from the body. For example, you can maintain body temperature fairly well in 68 degree (F) air, but jump into a 68 F body of water, and hypothermia becomes a concern.
Related to Help coming up with a formula for determining weight lost in cold.
What is the formula for determining weight lost in cold?
The formula for determining weight lost in cold is: (Body weight x Duration of exposure x Temperature drop) / (Clothing insulation x Wind speed x Metabolic rate).
How does cold temperature affect weight loss?
Cold temperature can increase weight loss by causing the body to shiver, which burns more calories. It can also decrease appetite and increase the body's metabolism, leading to a higher rate of calorie burning.
What factors should be considered when using a formula for weight loss in cold?
When using a formula for weight loss in cold, factors such as body weight, duration of exposure, temperature drop, clothing insulation, wind speed, and metabolic rate should be taken into account. These factors can vary greatly and affect the accuracy of the formula.
Can the formula for weight loss in cold be used for all individuals?
No, the formula for weight loss in cold is a general formula and may not be accurate for all individuals. Factors such as age, gender, fitness level, and overall health can also impact weight loss in cold temperatures.
Are there any limitations to using a formula for weight loss in cold?
Yes, there are limitations to using a formula for weight loss in cold. The formula does not take into account individual differences in metabolism and can only provide an estimate of weight loss. It is important to also consider other factors such as diet and exercise when trying to lose weight in cold temperatures.
  • Biology and Medical
  • Astronomy and Astrophysics
  • General Discussion
