Calculate KINETIC ENERGY of proton traveling close to speed of light
In summary, the relativistic kinetic energy of a proton traveling with a speed of 2.990x108 m/s is 2.50x10-19 J.
LBRRIT2390
29
A proton is traveling with a speed of v = 2.990x108 m/s. Calculate the (relativistically correct) value of the kinetic energy for this proton. Assume that the speed of light is c = 3.000 x 108 m/s and that the mass of the proton is 1.673 x 10-27 kg.
Note: Do your calculations to 4 significant figures. Then round off to give an answer good to 3 significant figures. Be sure to include the correct abbreviation for the SI unit.
K = 1/2 mv2
Limit is K = 1/2mC2
K=1/2(1.673x10-27)(2.990x108)
K=2.50x10-19J
Is this correct? I feel like I'm missing something here...
O should I be using the equation:
K =( g - 1 )MC2
or
K= (1/2)gMV2
What is the correct formula for calculating kinetic energy when a particle's speed approaches the speed of light??
you should use the relativistic equations to calculate the kinetic energy .. I suggest you to use :
Ek = gama*m*c^2 - mc^2 , where gama= 1/sqrt(1-(v/c)^2 ) ..
when a particle moves with very high velocity ( close to the speed of light )
then the moving mass of the particle is given as :
M = m/sqrt(1-(v^2/c^2))
here,
m is ths rest mass of the particle = 1.673X10^(-27)kg
v is the velocity of the particle = 2.990X10^(8)m/s
c is the speed of light = 3.00X10^(8)m/s
using above formula the mass of the proton moving with the speed close to that of light can be calculated :
M = 6.480X10^(-26)kg
then we can obtain the kinectic energy of the proton as:
KE = (1/2)M(v^2)
KE = 2.914X10^(-19) joule
please correct if m wrong!
here,
KE = (1/2)M(v^2)
KE = 2.914X10^(-9) joule
I don't recall doing this when I used to take that course .. I just substitute in the formula I wrote
here,
KE = (1/2)M(v^2)
That's wrong. You should abandon the notion of relativistic mass because it leads to errors like this.
In special relativity, the energy of an object of rest mass m is given by
[tex]E=\frac{mc^2}{\sqrt{1-(v/c)^2}}[/tex]
When v=0, you get E=mc2. This is the rest energy of the object. The object's kinetic energy is the energy in excess of the rest energy, so it's given by
[tex]K=E-mc^2[/tex]
If you express the total energy E as a series in (v/c)2, you get
[tex]E=mc^2\left[1+\frac{1}{2}\left(\frac{v}{c}\right)^2+...\right]\cong mc^2+\frac{1}{2}mv^2+...[/tex]
When the speed of the object is much smaller than the speed of light, you can neglect the higher-order terms and recover the Newtonian expression for kinetic energy
[tex]K=\frac{1}{2}mv^2[/tex]
To get this result, we assumed v<<c, so this formula is only good when the speeds are not a significant fraction of the speed of light. In particular, you can not use it in this problem.
[tex]K=E-mc^2[/tex]
then what should be the kinetic energy for such problem!
I clearly said what it was in my previous post.
ohh you ..thanx
1. What is kinetic energy?
Kinetic energy is the energy an object possesses due to its motion. It is a scalar quantity and is measured in joules (J).
2. How is kinetic energy calculated?
Kinetic energy can be calculated using the formula: KE = 1/2 * m * v^2, where m is the mass of the object in kilograms and v is the velocity of the object in meters per second.
3. Can the kinetic energy of a proton traveling close to the speed of light be accurately calculated?
Yes, the kinetic energy of a proton can be accurately calculated using the formula mentioned above, as long as the mass and velocity of the proton are known.
4. What is the speed of light in meters per second?
The speed of light in a vacuum is approximately 299,792,458 meters per second.
5. How does the speed of the proton affect its kinetic energy?
The speed of the proton has a direct relationship with its kinetic energy. As the speed of the proton increases, its kinetic energy also increases. This is because the kinetic energy formula involves the square of the velocity, meaning that even small increases in speed can result in significant increases in kinetic energy.
