Size of a proton as a function of relative strength of color force?
In summary, decreasing the strength of the strong force by a factor of ten would cause the proton radius to increase significantly. However, the proton would still be bound due to quark confinement. The dependence of the proton radius on the coupling constant is drastic, with the radius increasing rapidly as the coupling constant decreases. This would also affect the confinement length scale and could potentially lead to a phase change where quarks are no longer confined. However, a complete reduction of the strong force would result in the absence of confinement and a breakdown of the proton.
Spinnor
431
If we could set the strong force to be ten times weaker (compared with the electromagnetic force) how much would the radius of the proton change if any?
In the limit that the strength of the strong force goes to zero does the proton radius approach some limit?
Thanks for any help!
If the strong force strength was zero there would be no proton (infinite radius).
If that is true then if we could slowly reduce the strength of the strong force then matter would undergo a "phase" change where quarks were no longer confined?
How would a single hydrogen atom in a box change as the strength of the strong force went to zero?
Two up quarks, a down quark, and an electron could still form a charge neutral bound system in some limit where the strong force goes to zero?
An excited state of such a bound system could emit a photon or a gluon?
I am having a weird feeling coming from your questions...
A zero strong force, as stated above would mean the destruction of nuclei ... A proton would not be a good choice of a system, because what would keep the quarks together? What keeps them together, although they have charges, is the strong interactions... and the same is true for nuclei as well... Without that interaction, they would break up in their constitutes ...
What is the limit that this can hold? probably depends on what you want to say... For example, you get an idea of the relation between strong forces and electromagnetic, by checking a nuclei... A rough calculation can be that you know that the radius of a nuclei is of magnitude ~1fm, and you just say you'd like at that level the electromagnetic repulse of the protons to be equal to their strong attraction... then I guess you'll get a "ratio" between strong and electromagnetic interaction strengths... then by lowering the strong interaction you'd raise the radius, in the limit of zero strong interaction, you'll get that there won't be a bound state...
I guess there can be more explicit calculations taking more into account...
How could they make a neutral bound system? that is very unlikely to happen, and if it does I don't think you can have a stable state... In the way that you can't excite it (it would break everything appart). But if you send the strong interaction to zero, then there won't be gluons for sure... Photons will exist because you have charges
If I am somewhere wrong, let me know...
If we had four charged particles of charge -1, -1/3, 2/3, and 2/3 won't they minimize electrostatic energy and form a bound system (allowing the strong force to get very weak)?
they could... but as I said even if this happened, it would be terribly unstable... the fact that in order to have a complete cancel out of the charges you'd have to put them in a very specific way to get the "minimized energy" which of course I am not even sure if it's enough for a bound state...
To get a complete cancelation of charges you'd have to put in a point A the -1, -1/3 (impossible) and shoot around with enough momentum the 2/3, 2/3... and that's a classical way of seeing it
The size of the proton will increase very rapidly as you decrease the strength of the strong force. But as long as the coupling constant is positive, the proton will be bound because of the phenomenon of quark confinement.
Actually the strength of the strong force depends on the distance scale. The "coupling constant" that defines the strength of the force increases as the distance scale you are examining increases. For instance at a separation of ##10^{-18}## meters the strong force is much weaker than it is at ##10^{-16}## meters. At about ##10^{-15}## meters the coupling constant, by a certain measure, actually blows up to infinity. This length scale where the coupling constant blows up sets the size of hadrons, including the proton: the proton's radius is about ##10^{-15}## meters.
Now, when we think about "making the strong force ten times weaker," what we presumably mean is that at a fixed length scale--say, ##10^{-18}## meters--we decrease the coupling constant by a factor of 10. This will delay the blow-up of the coupling constant to a larger length scale, and thus will make the proton larger. The dependence of the radius ##r## on the coupling constant ##g## [measured at a fixed length scale] is quite drastic; I think to first order it should look like
[itex]r \sim e^{c/g}[/itex]
for some constant ##c##. The exponential means that ##r## increases quite rapidly as ##g## decreases. As ##g \to 0##, ##r \to \infty##.
No. Quarks will always be confined as long as ##g > 0##. And if you set ##g = 0## then there is no strong force. Confinement has a certain length scale, though--basically, the maximum distance color charges are allowed to separate--which is approximately equal to the proton radius and which will increase as the proton radius increases.
At first, the radius of the proton would increase without incident. Once the proton radius became comparable to the Bohr radius of the electron wave function things would get interesting. I guess the system would become quite complicated to analyze.
Yes, in the limit where the strong force is extremely weak [i.e., proton radius much greater than Bohr radius], we could mostly neglect the strong force compared to the electromagnetic force. Then we'd have to analyze the hydrogen atom as an electromagnetic bound state of four particles of charge 2/3, 2/3, -1/3, and -1. This system is definitely bound electromagnetically.
Yes, but gluons are still confined which essentially sets a maximum distance such a gluon could travel before being absorbed (which could be much greater than the radius of the "hydrogen atom" if the strong force is very weak).
is there quark confinement without strong interactions?
Also what kind of state would that be? they are totally asymmetric
It's even stronger, I think: g2 rather than g.
Thank you for the details! Interesting!
Maybe a follow up question. Let the strong force be small enough so that the following question makes sense (assuming it can make sense),
Let there be three dipole antennas which occupy nearly the same space with the same orientation. Let these dipole antennas have oscillating color currents of the strong force, red, anti-red, blue, anti-blue, green, and anti-green, with adjustable phase and amplitude (this can't be done but is only a thought experiment to maybe understand the color forces better). When say blue color charge was maximum at one end of the antenna there would be an equal amount of anti-blue color charge at the other end.
With proper phase and amplitude modulation can we produce the eight types (is it nine if color is not confined) of dipole gluon radiation?
Edit, gluons carry color charge so the above won"t work?
2nd edit, so color and anti color charges must "bleed" off the antennas?
So if say a red charge jumps from the red charged end of the red/anti-red antenna to the green or blue charged end of the green/anti-green or the blue/anti-blue antenna Feynmans diagrams for the color force tell us the red charge can emit a gluon and change color. And like wise for the oppositely charged ends. Charges flow from end to nearby end of the antennas?
I'm trying to understand your question... can you please simplify it?
what do you mean by charged antennas?
Compare proton with neutron.
A neutron is bound by electromagnetic interaction alone. One particle of charge +2/3, and two particles of -1/3 each. Just like a helium atom only with 1/3 the charges.
Considering the masses of quarks, what would the size of neutron be in absence of strong force? What is the binding energy?
A proton is not bound by electromagnetic interaction, because it can split up into a particle charge +2/3 and a bound system of +2/3 and -1/3 totalling +1/3. These repel at long distances.
If strong interaction were of negligible strength compared to electromagnetic then a proton would exist because of colour confinement but would be huge compared to neutron. Whereas a neutron would be only slightly smaller than it would be in complete absence of colour force.
How much does the size of neutron and proton differ now, at the present strength of colour force?
Nope, the neutron - like the proton - is bound by the strong force. The proton and neutron are about the same size.
Take Maxwell's classical theory of electromagnetism and change it so we get a similar theory (if possible) using the fundamentals of the color force, three types of charge, red, blue, and green and their opposites anti-red, anti-blue, and anti-green. We would presumably have three conserved currents. Changing color currents give rise to radiation? Such an imaginary classical theory of a very weak strong force would allow us to think of gluon dipole radiation produced by oscillating color currents. My guess was we might have 8 (or 9) types of gluon dipole radiation by proper modulation of the color currents. A big difference with classical electrodynamics is that photons have no charge while gluons have equal amounts of color/anti-color charge. This makes the thought experiment a little harder.
Yes, both are bound mainly by colour force.
However, electromagnetic force mainly works to contract the neutron against the colour force, and it mainly works to expand the proton against the colour force. What is the resulting size difference?
There is also a difference between protons and neutrons coming from the fact that up and down quarks have different masses as well as different charges. Both electromagnetic and quark mass difference effects are of order 1% or less. So presumably any size difference between the proton and neutron is of this order. For example, these effects are responsible for the mass splitting between the proton and neutron which is about 0.1% [this is a little smaller than you might expect because there is an approximate cancellation between the quark mass effects and the electromagnetic effects]. Lattice QCD calculations of hadron properties are starting to take into account these "isospin breaking" effects, which had previously been neglected because they were dominated by other errors.
That means that your experiment is theoretical (in principle up to what I know about strong forces)... First of all, as you said the gluons carry color charge. Also you cannot isolate these charges, but they will come in such a configuration that you'll always have neutral things.
I don't think the strong charge can be in any way compared to that of EM... They have totally different properties in all levels... Even the reason why we chose to consider the existence of that charge (If I recall well, from the reaction ratios of quarks) was because we got triple what we expected...
Gluons are somewhat difficult to see in analogy to photon because of the above. They are also coming from different symmetries and are subject to different interactions (as a result of the non-abelianity of the symmetry they come from)
If someone knows anything better than me, I hope they can help you...
Really? we've gone this far? And they keep teaching us the Isospin conservation of the strong forces :P hahahaa
Negligible (less than 1%)
Mass difference is 0,13 % (neutron is bigger), but it is very significant.
So what is the difference in size?
the difference of mass of the neutron to that of the proton is not only associated to the difference of the mass of up and down quark... of course that's I guess the dominating factor... But there are also corrections due to EM interactions on different charge constituents... I.e. they make the neutron less massive I guess...
If someone knows anything better than me, I hope they can help you......
Thank you! How would you even create color currents, time changing color magnetic fields induce time changing color electric fields? Might there be 3 types of magnets?
Edit, or is it 8 or 9 types of color magnet?
I guess one way to solve this problem is to compare the Lagrangian for the strong force (very weak strong force) with interaction with the Lagrangian for Electromagnetism with interaction, the latter gives rise to Maxwell's equations via The Euler-Lagrange equations?
I'm now guessing we might only need one antenna that can simultaneously produce a triplet of currents,
J_color = j_r + j_b + j_g =
j_ro*exp(-iωt +iθ_r) + j_bo*exp(-iωt +iθ_b) + j_go*exp(-iωt +iθ_g)
Is there a continuity equation for J_color?
Now if the particles that carry color charge also carry electric charge my problem gets even harder? Maybe to simplify things let the particles carry only color charge and no electric charge?
I think there is bound to be both similarities and differences with electromagnetism.
Thanks for all the help, I guess I need to study!
When you introduce the QCD in your Lagrangian
[itex]L_{QCD}=\bar{ψ} (i γ^{μ} D_{μ} -m ) ψ[/itex] (Dirac's part) [itex]-G_{μκ}^{a}G^{μκ}_{a}/4[/itex] (the gauge bosons interaction terms)
Where you have the:
a) Covariant Derivative
[itex]D_{μ}= ∂_{μ}+ i g_{3} T^{a} A_{μ}^{a} = ∂_{μ}+ i g_{3} λ^{a} A_{μ}^{a}/2[/itex]
where [itex]λ^{a}[/itex] are the generators of [itex]SU(3)[/itex] thus they can be represented as the Gellmann matrices.
b) The gauge bosons antisymmetric tensor
[itex] G_{μκ}^{a}= ∂_{μ}A_{κ}^{a}-∂_{κ}A_{μ}^{a}-g_{3}f^{abc} A_{μ}^{b}A_{κ}^{c}=A_{μκ}^{a}-g_{3} f^{abc} A_{μ}^{b}A_{κ}^{c}[/itex]
[itex]f^{abc}[/itex] the [itex]λ^{a}[/itex] algebra's structure constants...
Then you get for your Lagrangian 3 different terms...
[itex]L_{QCD}=L_{0}+ L_{g.b.} + L_{int} [/itex]
1st term is the free langrangian term, the 2nd term is the gauge bosons self interaction term, and the last is the interaction of bosons with your quark fields [itex]ψ[/itex] which can be either u,d,c,s,t,b and it can be represented as color triplets...
eg [itex] c= [c^{red}, c^{green}, c^{blue}]^{T} [/itex]. For the anticolor, you need to work in the adjoint representation of [itex]SU(3)[/itex]
Nevermind, to get the color current, you need the interactive Lagrangian:
[itex]L_{int}= -g_{3} \bar{ψ} γ^{μ}λ^{a} ψ A_{μ}^{a}/2 [/itex]
the corresponding conserved current (if you remember from the Dirac's current case) is:
[itex] J_{SU(3)}^{μa}= g_{3} \bar{ψ} γ^{μ}(λ^{a}/2) ψ[/itex]
What can we see from that? That we have 8 conserved currents. Each of them is individually conserved. The continuity relation for the currents, is given by their conservation, thus you have again 8 different continuity relations:
[itex]∂_{μ}J_{SU(3)}^{μa}= 0 [/itex]
and the color charge is:
[itex] Q_{c}=\int{d^{3}x J_{SU(3)}^{0a}}[/itex]If they also carry electric charge, you'll get also another current, corresponding to [itex] U(1)_{Q} [/itex] interaction...
I am not sure for this, if it's wrong someone please correct me:
If you now leave from the case of a single quark, and you want to put all the quarks in the game, then you should put indices on the quark fields...So the current will:
[itex] J_{i}^{μa}= g_{3} \bar{ψ_{i}} γ^{μ}(λ^{a}/2) ψ_{i}[/itex]
where [itex] i [/itex] can be each u,d,s,c,b,t quarks, so eg [itex]ψ_{1,2,3,4,5,6}= ψ_{u,d,c,s,t,b}[/itex]
In the color representation, then you can also write indices for the [itex]λ[/itex] and [itex]ψ[/itex] such that:
[itex] J_{i}^{μa}= g_{3} \bar{ψ_{i}^{k}} γ^{μ}(λ^{a}_{kp}/2) ψ^{p}_{i}[/itex]
I see the estimates of 2,8 MeV mass difference of down and up. So the repulsion between the ups in proton makes it 1,5 MeV heavier.
So, on the limit of no strong force whatsoever, what would be the binding energy of a neutron?
Where you have the:
Who needs books, the physics is right above, very nice, thank you!
8 currents then. I thought we gain 1 current because color is no longer confined?
Edit, color is no longer confined up to some radius r?
Follow up,
Can Feynman diagrams for the process colored quark emits a gluon (8 types) and changes color (or does not change color?) be grouped to represent the 8 fundamental currents of the color force?
Edit, is there a graphical representation of the 8 fundmental currents involving colored quarks?
Can I produce the 8 types of fundamental currents with the J I wrote down above,
j_ro*exp(-iωt +iθ_r) + j_bo*exp(-iωt +iθ_b) + j_go*exp(-iωt +iθ_g) ?
What I wrote down has the same group properties as the 3D harmonic osscilator, SU(3)? We can vary three phases and three amplitudes of the J above as we can do with a 3D H.O.?
Thanks your help!
Let the current I gave represent osscilating color current in a ring, does that produce gluon radiation?
Now let the currents in the ring above not change in time, let the total current be the sum of three indpendant color currents, j_r, j_b, and j_g, is there a static color magnetic field produced?
How many types of color magnetic dipoles are there (assuming such a question makes sense)?
Follow up,
Thanks your help!
The 8 conserved currents is not the individual colors, but some mixing of colors... The colors come from the components of the fields ψ as I told you, and how those color mix depends on the choice of the λ and so you'll get the associated current... The gluons come because of this λ as you can see from the [itex]L_{inter}[/itex].
I am trying to understand why are you trying oscillation solution for your color current :P
The current is the one I wrote above, you can try to choose a particular λ, and maybe the up quark with the three colors, do the matrix multiplication and find it out. Of course you will get:
J~ Jr +Jb+ Jg, but each of them is not individually conserved, rather their whole configuration- that is a colorless mixing..
I'm trying to find the most simple example in principle that has the right physics, can any of my questions be realized in principle in this thought experiment? Color currents in a ring, yes or no? Of the form I suggested in the last post.
I don't know about that...QCD works differently to EM... so you can't speak of "radiation" of the bosons... This radiation works for the EM because it has infinite range...
QCD doesn't have infinite range, and that's why we never count quarks or gluons... We just count jets of color-neutral particles...
As for the harmonic oscilator's SU(3) you stated, I would tell that you should avoid mixing the SU(3) symmetry of the isotropic harmonic oscillator, which is a global symmetry, to that of color which is a local one...
To get the idea of what a global SU(3) would mean, I'd say you should think that the reason you need the covariant derivative instead of the partial derivative alone is because your Lagrangian would not be locally SU(3) invariant (although it would always be globally). A global SU(3) would not need the existence of the gauge bosons... By inserting the local SU(3) you get gluon fields (as you also did with U(1) )
Likes Spinnor
  • #31
We are allowing the strong coupling constant to get as weak as we please here.
FAQ: Size of a proton as a function of relative strength of color force?
1. What is the size of a proton?
The size of a proton is approximately 0.84 femtometers (fm), or 0.84 x 10^-15 meters.
2. How is the size of a proton determined?
The size of a proton is determined through experiments using particle accelerators, such as electron-proton scattering experiments or proton-proton scattering experiments.
3. What is the relative strength of the color force?
The relative strength of the color force, also known as the strong nuclear force, is one of the four fundamental forces of nature and is responsible for holding quarks together to form protons and neutrons. It is the strongest of the four forces, with a strength that is approximately 137 times greater than the electromagnetic force.
4. How does the relative strength of the color force affect the size of a proton?
The relative strength of the color force affects the size of a proton through the confinement of quarks within the proton. As the strength of the color force increases, the quarks are held closer together, resulting in a smaller proton size.
5. Can the size of a proton change?
Yes, the size of a proton can change under extreme conditions, such as high energy collisions or extreme temperatures. This can cause the quarks within the proton to move further apart, resulting in a larger proton size.
