Near black hole event horizon time dilation?
In summary, the conversation discusses the effects of proximity to a black hole on the perception of time by objects at different distances. It references various sources, including an article on the event horizon, a visualization of a black hole, and a frequently asked questions section on black holes. The question at hand pertains to the speed of light and its frequency in relation to objects close to the black hole and approaching the event horizon.
darkhorror
140
Lets say we have a couple objects, one very close to a black hole, one a little farther out and then one a good distance away. Would the one very close to the black hole see the other ones time moving much quicker than their own time? How about just as they are going to hit the event horizon? How does that work with the speed of light and it's frequency?
Astronomy news on Phys.org
1. What is event horizon time dilation near a black hole?
Event horizon time dilation is the phenomenon where time appears to slow down for an object approaching a black hole's event horizon, which is the point of no return for anything falling into a black hole. This is due to the immense gravitational pull near the event horizon, which causes time to dilate or stretch.
2. How does event horizon time dilation affect objects near a black hole?
As an object gets closer to the event horizon of a black hole, the gravitational pull becomes stronger, causing time to slow down. This means that for an outside observer, time appears to pass more slowly for an object near the black hole. The effect becomes more pronounced as the object gets closer to the event horizon.
3. Can event horizon time dilation be observed from Earth?
No, event horizon time dilation cannot be observed from Earth as the nearest black hole is located thousands of light-years away. The effects of time dilation near a black hole are only noticeable when an object is extremely close to the event horizon, which is not possible to observe from such a great distance.
4. How does event horizon time dilation relate to Einstein's theory of relativity?
Event horizon time dilation is a direct consequence of Einstein's theory of relativity, specifically the theory of general relativity. This theory explains the relationship between gravity and the curvature of space-time, which is what causes time dilation near a black hole.
5. Is there a limit to how much time can be dilated near a black hole's event horizon?
According to Einstein's theory of relativity, time dilation increases as an object gets closer to the event horizon. However, there is a limit to how much time can be dilated, and that limit is at the event horizon itself. Once an object crosses the event horizon, time dilation becomes infinite and time essentially stops for that object as it falls into the black hole.
  • Astronomy and Astrophysics
