Analog to Digital Converter (Estimation of Input Voltage)
In summary: Mullaney's solution:In summary, to estimate the input voltage to within 1 LSB for a 10-bit A/D converter displaying an output of 1010110111 in straight binary code, you can calculate the resolution of 9.77 mV per code and use it to determine the boundary between the given code and the next one up. This can be done by converting the output code to decimal and multiplying it by 9.77 mV. Drawing a transfer function may also help visualize the behavior.
GreenLRan
61
A 0-10 V, 10-bit A/D converter displays an output in straight binary code of 1010110111. Estimate the input voltage to within 1 LSB (Least Significant Bit).
Resolution = Efsr/2^M. (where M= 10 in this case)
Eout = X/2^M (where Eout is the output Voltage, X is the actual input binary number [I'm also not sure if this equation is valid... I found it under the digital to analog converter section rather than analog to digital])
I calculated the resolution and got it to be 10 V/2^10 = 9.77 mV. I am unsure of what to do next (my book is terrible). I was thinking of converting the output binary (which i believe to be the output voltage) to base 10, then I didn't know if there was an equation for the input Voltage as a function of Output voltage.
I also thought about taking the quantization error to be 1/2 the resolution. the somehow getting the input voltage from that.
Honestly, I am lost. Any help would be great. Thanks!
You're making this too hard.
You found the resolution, which is 9.77 mV per code. An input of 0 V to 9.77 mV would produce an output of 00 0000 0000. An input of 9.77 mV to 19.54 mV would produce an output of 00 0000 0001. Each additional step represents 9.77 mV.
Convert the 10-bit output code to decimal -- that's the number of codes above zero -- and multiply it by 9.77 mV. That's the boundary between the given 10-bit code and the next one up.
You might want to draw a picture of the transfer function (not all 2^10 codes of course) to help you visualize the behavior.
- Warren
I would first make sure that my equations are correct and applicable to the problem at hand. In this case, the resolution equation seems correct, but the output voltage equation may not be applicable to an analog to digital converter. I would suggest double checking with reliable sources or consulting with a colleague or mentor for clarification.
After confirming the equations, I would proceed with the solution by using the resolution value to estimate the input voltage. Since the output code is in straight binary, we can assume that the output voltage is equal to the input voltage. Thus, we can use the resolution value to estimate the input voltage to within 1 LSB.
In this case, the LSB is 9.77 mV, so the input voltage can be estimated to be within the range of 1010110111 ± 4.88 mV. This means that the input voltage could be anywhere between 3.86 V and 3.87 V. However, since the output code is an odd number, we can assume that the input voltage is closer to the upper bound, so the estimated input voltage would be approximately 3.87 V.
It is important to note that this is just an estimation and may not be the exact input voltage. To get a more accurate value, it would be necessary to use a more precise A/D converter or perform multiple measurements and take an average.
FAQ: Analog to Digital Converter (Estimation of Input Voltage)
1. What is an Analog to Digital Converter (ADC)?
An Analog to Digital Converter (ADC) is a device that converts analog signals, such as voltage or current, into digital signals that can be read and processed by digital electronic systems. This conversion is necessary because most electronic systems operate on digital signals, but many real-world signals are analog in nature.
2. How does an ADC estimate the input voltage?
An ADC estimates the input voltage by taking a series of measurements of the input signal at specific time intervals. These measurements are then converted into a binary number, which represents the analog voltage in a digital form. The accuracy of the estimation depends on the resolution of the ADC, which is the number of bits used to represent the analog signal.
3. What is the difference between a single-slope ADC and a dual-slope ADC?
A single-slope ADC uses a simple method of measuring the input signal by comparing it to a known reference voltage. This method is relatively slow but is suitable for low-frequency signals. In contrast, a dual-slope ADC uses a more complex method that involves measuring the time it takes for the input signal to charge and discharge a capacitor. This method is more accurate and suitable for higher frequency signals.
4. What factors affect the accuracy of an ADC?
The accuracy of an ADC can be affected by several factors, including the resolution of the ADC, the quality of the reference voltage, the stability of the input signal, and the linearity of the ADC. Noise and interference can also impact the accuracy of the ADC and must be carefully considered in the design and implementation of the system.
5. What are some common applications of ADCs?
ADCs have a wide range of applications in various fields, including telecommunications, audio and video systems, medical equipment, and industrial control systems. They are used to digitize signals from sensors and transducers, convert analog audio and video signals into digital formats, and interface between analog and digital systems. ADCs are also commonly used in data acquisition and measurement systems to accurately capture and analyze analog signals.
