- #106
russ_watters
Mentor
- 23,374
- 10,672
And that's my question: what is that performance like, when the car is running as a direct gas-electric? In a regular car, it is my understanding that you lose something like 35% of your power via the drivetrain. So that would mean a 70 hp engine can put 70*.65=45.5 hp to the ground. How much horsepower can the volt put to the ground in this mode? Possible sample calc:mheslep said:If the tractive load on the electric motor is, say, ~70HP (neglecting losses) from a slight grade or acceleration demand, then the vehicle meets the demand of the driver and the battery is not further depleted with the ICE running at full power.
If the vehicle is climbing a major hill as you described, then let us say the electric motor has to draw ~150HP to climb it, and it will deplete the battery at rate of 80HP down below 30% of full charge for the time to climb the hill. The vehicle controller has some programmed limit as to how long it will allow that to happen before it says no more and forces the power supplied to the motor back to down to 70HP. It will not allow the battery to ever reach full discharge, or anywhere close to that.
Gas engine drivetrain loss: 10% (I'm assuming a gearbox and clutch).
Generator efficiency: 95%
Power conversion efficiency: 95%
Electric motor efficiency: 95%
Electric motor to wheel drivetrain loss: 10%
Resultant horsepower to the ground: 70*.9*.95*.95*.95*.9=48.6 hp.
I think people are going to want to know what that performance is actually like, lest they find themselves unpleasantly surpised when they suddenly can't go more than 35 mph on a moderately graded highway in the poconos.
Incidentally, a couple of years ago I went on a trip from PA to WV to see a WVU football game and my buddy's Saturn could not maintain highway speed on the interstate on the way there. He had to drop a gear and run at around 55 mph. My Mazda 6i, with 160 hp (but a much bigger car than a Saturn or a Volt) is marginal on similar roads in PA (I can keep 70 mph, but have to do it in 4th gear).
