Supply different voltages using a dual dc supply?
In summary, the conversation discusses how to power two ICs that require -10v and +10v and one IC that requires -5v and +5v using one dual dc supply. The solution suggested is to use a +5V and a -5V regulator off the respective +10 and -10V rails. It is also mentioned to ensure that the 10V rails can supply enough current for all the ICs. The conversation also mentions using a variable supply in a lab and confirms that a 7805 and 7905 voltage regulator can be used. Another suggestion is to use two 5V Zener diodes if the current requirement for the +-5V is small.
riie
Hi all,
I have
- 2 ICs that requires -10v and +10v
- 1 IC that requires -5v and +5v
How can I power them using one dual dc supply?
Thanks!
easy as pie :)
just make sure your 10V rails are able to supply the required current for the 10V IC(s) as well as the 5V IC(s)
Dave
Dave
Forgot to mention that the dual dc supply is a variable supply used in lab.
So just to confirm, I need a 7805 and a 7905 voltage regulator for +5v and -5v respectively?
regardless of if its a variable supply, you will have it set at 10V anyway, so yes a 7805 and 7905
You have no reason to be continuously varing the voltage do you ?
Dave
I should have thought that two 5V Zener diodes could do the job nicely - if your +-5V current requirement is small.
1. How does a dual DC supply work?
A dual DC supply is a device that can provide two different voltages simultaneously. It typically consists of two independent power supplies that are connected together. The first power supply provides a positive voltage and the second power supply provides a negative voltage. This allows the user to have access to both positive and negative voltages, which is useful for a variety of electronic applications.
2. What are the advantages of using a dual DC supply?
One of the main advantages of using a dual DC supply is its ability to provide both positive and negative voltages. This is particularly useful in circuits that require both types of voltages, such as amplifiers and analog-to-digital converters. Additionally, having two separate power supplies can also improve the overall stability and precision of the voltages being supplied.
3. Can a dual DC supply be used to power multiple devices?
Yes, a dual DC supply can typically power multiple devices at the same time. It is important to make sure that the total current draw from all devices does not exceed the maximum current output of the power supplies. Additionally, it is recommended to use separate power supply outputs for each device to avoid interference and potential damage.
4. How do I adjust the voltage output of a dual DC supply?
Most dual DC supplies have knobs or switches that allow the user to adjust the voltage output. These adjustments can typically be made independently for each power supply. It is important to follow the instructions and specifications provided by the manufacturer to ensure proper and safe adjustment of the voltages.
5. What are some common uses of a dual DC supply?
A dual DC supply has a wide range of applications in the field of electronics. It is commonly used in laboratory settings for testing and troubleshooting electronic circuits, as well as for powering certain devices that require both positive and negative voltages. It can also be used in industrial and commercial settings for powering specialized equipment.
  • Electrical Engineering
