Resonance - How does it occur?
  • Thread starter physics?
  • Tags
    Resonance
In summary: Resonance is a process that can store energy. When the limit is reached, the process breaks down. Resonance is most easily understood with a simple system like a mass on a spring. If you stretch the spring and release it, the mass will oscillate at a fixed frequency. If you force the mass at the same frequency, the amplitude (the degree of stretching) is larger. Resonance is most commonly seen with strings and other musical instruments. When you pluck a string, the string vibrates at a specific frequency. If you play the string too fast, the amplitude decreases. If you play the string too slow, the amplitude increases. When you hit a note on a piano, the hammers hit the strings at a specific frequency
physics?
Resonance -- How does it occur?
I am having a little difficulty with the concept of resonance. Could someone explain how resonance occurs and how elastic oscillation relates to resonance?
Sure, we can help out with that. But we require that you show some effort of your own before we can offer tutorial help here. What have you found at wikipedia, Hyperphysics, and other encyclopedia-type websites?
Please do some reading and research on your own first, and then post links and specific questions here about what you don't understand in what you have read. We are very much about "learning how to learn" here at the PF. :smile:
Qualitatively, it is easiest to consider a simple system. Suppose you have a mass on a spring. If you stretch the spring and let go, the mass oscillates, that is vibrates up and down. The mass will vibrate at a fixed frequency. This is the often called the natural frequency. Now suppose we force the mass using a motor (or our hand to vibrate at the resonant frequency (approximately the natural frequency, the details are complicated)). The amplitude (i.e. degree of stretching of the spring) attains it's largest value.
Forcing at higher or lower frequencies may not achieve as great a stretching. There is more but you may want to read up or reframe your question for more detail.
Resonance in action...
It's easier if the car has no shock absorbers.
Every resonant process is a process which can store energy. If a process cannot store energy, then there cannot be a resonance.
There are always limits to how much energy can be stored by a resonant process. When these are exceeded you get a breakdown. For example, the Tacoma Narrows bridge disaster was the result of a resonant process:
http://en.wikipedia.org/wiki/Tacoma_Narrows_Bridge_(1940 )
Hold a slinky by the top and let it dangle. Give it a jerk then hold your hand still and you should see the other end oscillate. That's the natural (resonant) frequency for the slinky. If you shake the slinky top up and down at that frequency, the other end oscillates with a large amplitude. If you go too fast or too slow, the slinky doesn't absorb energy, and the bottom of it doesn't move up or down nearly as much.
I endorse what Berkeman says. Tell us what you have found out so far.
1. What is resonance?
Resonance is a phenomenon that occurs when an object or system vibrates at its natural frequency in response to an external force or stimulus.
2. How does resonance occur?
Resonance occurs when an external force is applied to an object or system at the same frequency as its natural frequency, causing it to vibrate and amplify the motion.
3. What are the types of resonance?
There are three main types of resonance: mechanical resonance, acoustic resonance, and electromagnetic resonance. Mechanical resonance occurs in physical objects, acoustic resonance occurs in sound waves, and electromagnetic resonance occurs in electromagnetic fields.
4. What are some real-life examples of resonance?
Some common examples of resonance include the sound produced by a tuning fork, the swinging of a pendulum, and the vibrations of a guitar string. Other examples include the breaking of a wine glass when a singer hits a high note and the resonance of a building during an earthquake.
5. How is resonance used in technology?
Resonance is used in various technologies, such as speakers, radio transmitters, and MRI machines. It is also utilized in musical instruments to produce specific tones and harmonies. Additionally, resonance is used in bridges and buildings to prevent damage from vibrations caused by winds or earthquakes.
  • Other Physics Topics
  • High Energy, Nuclear, Particle Physics
  • Atomic and Condensed Matter
  • Electromagnetism
  • Beyond the Standard Models
