The SUSY F and D terms, and the scalar potential
In summary, the F and D terms in SUSY theories are auxiliary fields that are integrated out and do not have a canonical kinetic energy term. However, their effects are still considered physical as they contribute to the effective potential for other fields. In some cases, F and D terms can also be added to the Lagrangian and have a direct physical effect on the vacuum structure of SUSY. As for the electroweak parameters, there are various models of soft SUSY breaking, but it is generally accepted that the EWSB breaking scale cannot be larger than the SUSY breaking scale in the MSSM.
shirosato
Hello all. Again, thank you for the help so far. Forgive the lack of tex in this post, it somehow was creating errors no matter what I tried.
My question this time involves understanding the F and D terms in SUSY theories. From what I understood, they were introduced as auxiliary fields (EOM: [tex]F=F^{\dagger}=0[/tex] and [tex] D^{a}=0[/tex]) to ensure closure of the SUSY algebra on and off-shell.
At some point though when working out the superpotential for a supersymmetric gauge theory, the auxiliary terms are re-expressed in terms of scalar fields. When discussing EWSB in the MSSM, the D term gives the Higgs quartic self-interaction while the F term give: \mu(H_1)(H_2)
- Are the F and D terms thus physical then? What happened to the interpretation that they are fields integrated out and play no role in the EOM's? Why are these terms so important? I'm having a bit of trouble with these guys.
- From what I understand, the four relevant parameters in EWSB are tan{\beta}, \mu, m_1, m_2 which can be written in terms of free parameters in the SUSY breaking soft terms? - Shiro
For the F and D-terms there's a short answer and then a longer one because the terminology is used a bit more broadly in the literature.
The short answer is that the F and D components of chiral and vector superfields, respectively, are, as you say, auxiliary fields. They are not propagating degrees of freedom, since they don't have a canonical kinetic energy term. They appear in the action algebraically, without derivatives so they are integrated out. However the effect of integrating them out generates the effective potential for the other fields, so we wouldn't consider them unphysical.
The longer answer comes in because when we study the vacuum structure of SUSY and the conditions for SUSY to be broken, it's often possible to actually add terms to the Lagrangian that depend linearly on the F and D components. These terms are also called F and D-terms, and their effect is extremely physical, since they can often be used to guarantee that SUSY is spontaneously broken in the vacuum.
As for the electroweak parameters, there are various models of soft SUSY breaking, and I'd imagine that they all make slightly different predictions. For example, the scale of SUSY breaking can be different from the scale of EWSB. What is true is that the EWSB breaking cannot occur at a scale larger than SUSY breaking in the MSSM. So the EW Higgs sector will be determined by running the bare couplings of the MSSM along with the soft breaking parameters down to the EW scale. Martin's Supersymmetry Primer, hep-ph/9709356 is one reference that discusses some of this apparently, but there are probably more recent references like Dine's book too.
1. What is SUSY and how does it relate to F and D terms?
SUSY (Supersymmetry) is a theoretical framework in physics that proposes a symmetry between fermions (particles with half-integer spin) and bosons (particles with integer spin). The F and D terms are mathematical expressions used in SUSY to describe the interactions between these particles.
2. What are F and D terms and how do they contribute to the scalar potential?
F terms are scalar fields that describe the interactions between bosons, while D terms are gauge fields that describe the interactions between fermions. These terms contribute to the scalar potential by determining the energy levels of the system and the behavior of the particles.
3. How does the scalar potential affect the stability of a system?
The scalar potential plays a crucial role in determining the stability of a system. If the scalar potential is flat, the system is considered to be stable. However, if the scalar potential has a minimum (or maximum) point, the system may be unstable and undergo spontaneous symmetry breaking.
4. Can SUSY, F and D terms, and the scalar potential be observed experimentally?
While SUSY, F and D terms, and the scalar potential have been extensively studied and are important in theoretical physics, they have not yet been directly observed in experiments. However, scientists are constantly searching for evidence of these concepts through experiments at particle accelerators such as the Large Hadron Collider.
5. How do SUSY, F and D terms, and the scalar potential contribute to our understanding of the universe?
SUSY, F and D terms, and the scalar potential are important concepts in theoretical physics that help us understand the fundamental interactions and forces in the universe. They also provide a possible solution to the hierarchy problem, which seeks to explain the large discrepancy between the strength of gravity and the other fundamental forces.
  • Beyond the Standard Models
