Looking for pipe flow information in cubic feet per minute.
In summary, pipe flow refers to the movement of fluid through a closed system of pipes or channels. Cubic feet per minute (CFM) is a unit of measurement used to express the volume of air or gas flow per minute. The formula for calculating pipe flow in CFM is Q = A x V, where Q is the flow rate, A is the cross-sectional area of the pipe, and V is the velocity of the fluid. The factors that can affect pipe flow include diameter, length, fluid properties, and pressure and temperature. Pipe flow information in CFM is useful for designing and maintaining efficient piping systems, troubleshooting, and determining appropriate pipe sizes.
5.0stang
63
Does anyone have a chart of what a straight pipe flows in cfm?
Like 3 inch inside diam.? 4 inch? Etc? Thanks:)
Hey, that's a funny coincidence. I just notice that the web page is *.cfm, and stang wants the answer in cfm. LOL.
1. What is pipe flow?
Pipe flow refers to the movement of fluid (such as water or gas) through a closed system of pipes or channels.
2. What is cubic feet per minute (CFM)?
Cubic feet per minute is a unit of measurement used to express the volume of air or gas flow per minute. It is commonly used in HVAC systems to measure the amount of air being circulated.
3. How do you calculate pipe flow in CFM?
The formula for calculating pipe flow in CFM is: Q = A x V, where Q is the flow rate in cubic feet per minute, A is the cross-sectional area of the pipe in square feet, and V is the velocity of the fluid in feet per minute.
4. What factors affect pipe flow?
The factors that can affect pipe flow include the diameter and length of the pipe, the properties of the fluid being transported (such as viscosity and density), and the pressure and temperature of the system.
5. How is pipe flow information in CFM useful?
Pipe flow information in CFM is useful for designing and maintaining efficient piping systems, as well as for troubleshooting and identifying potential issues with flow rates. It can also be used to determine the appropriate size of pipes needed for a specific flow rate.
  • Mechanical Engineering
  • Classical Physics
  • Thermodynamics
  • General Engineering
