Is it posible to avoid sonic boom
  • Thread starter Yaveh
In summary, there is currently no way to completely eliminate the sonic boom created by an object travelling faster than the speed of sound. While there have been proposals to use lasers to superheat air and reduce the shock wave, this would not be a feasible solution as it would compromise the lift and stability of the object. Additionally, increasing altitude or changing the flow properties of air may reduce the intensity of the boom, but it cannot be completely eliminated."
Yaveh
Is it posible to avoid the sonic boom using some kind of magnetic field around the object?
Is there any investigation been carried away by USAF or anyone?
The answer is probably not. As for a magnetic field, it wouldn't have any effect. Sonic boom is an air compression effect. There is no electrical or magnetic force involved.
There are many things you can do to REDUCE the shock wave, but there is no way to completely eliminate it.
A sonic boom is just a shock wave which forms when an object goes faster than the speed of sound. It is caused by the air not being able to "get out of the way" fast enough.
If there were a way to use magnets or something similar to keep the shock wave from forming, then that would mean that there was no (or little) air touching the plane.
No air touching the wings means no lift.
No lift means you end up with a rocket, not a plane. If the engines were airbreathing, they would shut down, and the plane would fall to earth.
there are proposals to use lasers to superheat air in front of the nosecone of craft. Hotter air has a higher speed of sound, so the craft would (locally) break sound barrier at higher speed. also, heat -> lower density, so maybe the sound waves would be weaker, reducing the boom.
If you imagine reducing the density low enought that most wavelengths were less than the particle seperations, then the wave idea breaks down (but this is meters or more, so probably not practical)
Joe
That's an interresting idea. Do you have any sources for that?
I'm curious how they would dissipate the extra heat from the craft. Even if there is no shockwave, the total temperature felt in the boundary layers remains the same. Increasing the ambient temperature increases the total temperature linearly, and for SS jets it's already high enough that expansion of the airframe is an issue.
Isn't it simpler just to go higher? If not into space, then where the sonic boom isn't too noticable.
A jet stream of 500 MPH enclosing a commercial airliner with local airspeed 500 MPH in the same direction appears from the ground to be going 1000 MPH, yet without sonic boom. A gradual velocity gradient of air therefore does not conduct sound as well as static air. What is the minimum air velocity gradient needed to negate the effect of such relative supersonic speed?
Hey Loren,
I remember on PF 2.0 when you asked that question, and I didn't remember anyone finding an answer. Did you find a source which said it was the case? I'm interrested to find out why... it would seem to me that weird things would occur once the surrounding flow itself went supersonic.
FZ+, yes, it is simpler (relative to changing the flow properties) to get into space. That is exactly what current plans for hypersonic transports are looking to do. The OP asked if there was a way to avoid the boom in air, though.
^^^ It's not that the fast-moving air conducts sound worse; there is no sonic boom. You could have an arbitrarily small gradient over a large space and this would be the case.
You could ask what the maximum gradient is before you get a sonic boom... I would guess the characteristic length would depend on both the fluid properties of air like the density, *and* the size of the object creating the sonic boom. Not sure though... you could probably find the answer in a fluid dynamics book...
enigma, damgo-
My guess is that the answer lies in the Reynolds number. The increase in apparent sonic length of the aircraft from stem to stern, due to gradient diagonalization in the jet stream, is the same effect as diminished boom at an equivalent diagonal with no jet stream. The transition from boom with no jet stream to no boom with jet stream (neglecting changes in atmospheric density) would be given by
(vJ+vA)/vA=L/L(sin([the]))=1/(sin([the]))
Where vJ is the jet stream velocity, vA is the velocity of the aircraft, L the length of the aircraft, and [the] the angle from the ground to the plane.
Integral, could you pull this discussion out, since it appears we have hijacked the thread.
Loren, can you explain what you mean by this, please? Also, how did you derive that equation?
I am missing what you mean about "angle from the ground to the plane". Angle from where on the ground? Do you mean the aircraft angle of attack?
damgo, while looking at the airplane relative to the wind gives no shock wave (a wind tunnel test would confirm this), I still have this nagging suspicion that we're missing something. The speed of sound is just a function of the random kinetic energy (Temp) of the gas. If you give a fixed volume of gas a specific velocity, that doesn't affect its ability to transfer kinetic energy one bit (unless I'm completely missing something here...).
My aerodynamics textbooks aren't providing any insight to this special case, and a 5 minute database search only gave articles on wind tunnel test data.
I'll keep looking.
enigma-
In some sense I am claiming that the sonic velocity of the plane as perceived on the ground is relative to the jet stream velocity. I believe the angle is that of attack is what I describe, the angle between the flat ground and the airplane, with observer at the vertex.
Where vJ is the jet stream velocity, vA is the velocity of the aircraft, L the length of the aircraft, and [the] the angle from the ground to the plane [with observer at its vertex].
This equation is both empirical and derived from the Reynolds condition
R[nu]~(vJ+vA)(L(sin([the]))=vAL
where R is the Reynolds number and [nu] is the viscosity of air, assumed constant.
The effective sonic length of the plane is stretched (in some respect similar to dilation in relativity) by the relative velocity (1/sin([the])) of the jet stream, so what is visually apparent as supersonic is, on its way to the ground, sonically attenuated.
There seems to be a tendency explaining how a digital atomic clock works correcting for relativity when anybody asks what time it is
Never mind great job, but
The answer is no, to the question "Is it posible to avoid the sonic boom".
Very impractical that heating up of the air.
What is a sonic boom?
A sonic boom is a loud noise caused by shock waves created when an object travels through the air faster than the speed of sound.
Why is it important to avoid sonic boom?
Sonic booms can be disruptive to people and animals, causing damage to structures and potentially causing hearing damage. They also have a negative impact on the environment.
Is it possible to completely avoid sonic boom?
No, it is not possible to completely avoid sonic boom. Any object traveling faster than the speed of sound will create a sonic boom. However, it is possible to reduce the intensity and frequency of sonic booms.
How can sonic boom be minimized?
Sonic boom can be minimized through careful design of airplanes and other supersonic objects. This can include shaping the object to reduce shock waves and using specialized engines or propulsion systems.
Are there regulations in place for sonic boom?
Yes, there are regulations in place for sonic boom. The Federal Aviation Administration (FAA) has established guidelines for supersonic flights over land to minimize the impact of sonic boom on the ground. Additionally, some countries have banned supersonic flights over land.
  • Other Physics Topics
15K
9K
  • General Engineering
14K
