clairez93
- 114
PROBLEM 1 (work done by gas)
1. An ideal monatomic gas originally in state A is taken reversibly to state B along the straight-line path shown in the pressure-volume graph. What ist he work done by the gas?
A) +12 cal
B) +122 cal
C) 0 cal
D) -110 cal
E) +110 cal
4.186 calories per J
I thought the area under the curve would be the work done by the gas, so I split it into a triangle and a rectangle and did this:
[tex]\frac{1}{2}(1)(101.3*10^{3})(2)(10^{-3}) = 101.3[/tex] (the area of the triangle)
[tex]2(101.3*10^{3})(2)(10^{-3}) = 405.2[/tex] (the area of the rectangle)
I added them up to get 506.5. I then divided by 4.186 to get 120.99, which I supposed was closest to 122.
The answer, however, is +110 cal.
PROBLEM 2 (RADIATION)
2. Two identical solid spheres have the same temperature. One of the spheres is cut into two identical pieces. These two hemispheres are then separated. The intact sphere radiates an energy Q during a given time interval. During the same interval, the two hemispheres radiate a total energy of Q'. What is the ratio Q'/Q?
A) 1.5
B) 4.0
C) 0.50
D) 0.25
E) 2.9
[tex]H = Aert^{4}[/tex]
Not a clue how to start this one, as I don't have any values for r or t or A. My guess is those don't matter since H is directly proportional to A, so then I would have to find the surface area, however, I'm not sure how to compute the total surface area for Q' then.
The answer is 1.5, however.
PROBLEM 3 (coefficient of performance)
3. If the coefficient of performance for a refrigerator is 5.0 and 65 J of work are done on the system, how much heat is rejected to the room?
A) 210 J
B) 260 J
C) 130 J
D) 330 J
E) 390 J
[tex]COP = \frac{Q_{h}}{W}[/tex]
[tex]Q_{h} - Q_{c} = W[/tex]
[tex]COP = \frac{Q_{h}}{65} = 5[/tex]
[tex]Q_{h} = 325[/tex]
[tex]325 - Q_{c} = 65[/tex]
[tex]Q_{c} = 260[/tex]
The answer, however, is 390, so I guess I am supposed to add 325 and 65, though I am not sure why.
A) +12 cal
B) +122 cal
C) 0 cal
D) -110 cal
E) +110 cal
A) 1.5
B) 4.0
C) 0.50
D) 0.25
E) 2.9
A) 210 J
B) 260 J
C) 130 J
D) 330 J
E) 390 J
