Level of johnson-Nyquist noise in analog voltmeter
In summary: Even if you have a noise-free environment, the instrument will still have noise. The noise floor of an instrument is spec'ed for resolution and accuracy at a higher level than what you can measure with it.
tommyli
23
Hello,
I was wondering if anybody could answer a quick question:
What is the typical level of Johnson-Nyquist noise in an analog voltmeter in equilibrium (short circuited)? Is it millivolts?
What is the level for an AC current of order mA at 50Hz?
It's more complicated than this because it depends on the effective bandwidth. (Not the frequency of measurement but the bandwidth of the measurement)
http://en.wikipedia.org/wiki/Johnson–Nyquist_noise
If you measure an AC current that is at 50 Hz, you have to specify a resistance to have a measurable voltage. The effective bandwidth depends on how you "box" the 50 Hz with a bandpass filter: if it's 50 Hz (25Hz above and below), that will be the bandwidth (at least) for the noise measurement.
You have to plug in bandwidth into the equation. The resistance seen also enters the picture.
If the meter is designed for it, the measurable noise can be very low, for example:
http://www.home.agilent.com/agilent/product.jspx?pn=34420A&cc=US&lc=eng
100 pV resolution and 2.5 nV accuracy (limited by thermal noise floor) - assuming you understand the difference between resolution and accuracy. Of course to attain this accuracy when actually measuring something depends a lot on how you fixture/connect the meter to the device under test. BTW this is DC only, not AC though there is an AC spec as well.
But another meter that isn't specifically design for this won't achieve the same thing because its *internal* effective bandwidth won't be small enough for the noise to be low enough to allow measurement at that level - thus the meter noise floor will be spec'ed for resolution and accuracy at a higher level.
You can often adjust the effective bandwidth with a setting called "integration time" or "NPLC" (same thing, different name). This is a post-processing way of getting around the analog limits but effectively you could have to integrate for a very long time.
Hi jsgruszynski,
Thankyou for your quick reply. For AC voltage I understand; however even when there is no voltage applied, you should be able to detect thermal fluctuations in a voltmeter (?) If I integrate the signal in time-domain over a "box" of size 1 millisecond, the effective bandwidth will be 1kHz, is this the bandwidth that should enter the equation? This should mean I can detect thermal fluctuations in a shorted circuit of the order of microvolts if the resistance is 1 kOhm?
Yes, but.
The problem becomes: what (who's) noise are you measuring: the device's or the instrument's (or one of many subcomponents in the instrument). You have "dead shorts" within the instrument as well: the wiring from the DUT and all the traces up to the transistors that amplify the DUT's signal/noise.
I'm not trying to joke or dismiss your question but this literally is the issue.
What is Johnson-Nyquist noise?
Johnson-Nyquist noise, also known as thermal noise or white noise, is a type of noise that arises from the random motion of electrons in an electrical conductor. It is present in all electronic circuits and can affect the accuracy of measurements.
How does Johnson-Nyquist noise affect an analog voltmeter?
In an analog voltmeter, Johnson-Nyquist noise can cause fluctuations in the measured voltage, making it difficult to obtain an accurate reading. This noise is typically more pronounced in low-voltage measurements and can be minimized by using a high-quality voltmeter with low noise levels.
What factors affect the level of Johnson-Nyquist noise in an analog voltmeter?
The level of Johnson-Nyquist noise in an analog voltmeter is affected by several factors, including the temperature of the circuit, the resistance of the voltmeter, and the bandwidth of the measurement. Higher temperatures, higher resistance, and wider bandwidths all contribute to increased levels of Johnson-Nyquist noise.
Can Johnson-Nyquist noise be eliminated completely in an analog voltmeter?
No, Johnson-Nyquist noise cannot be completely eliminated in an analog voltmeter. However, it can be reduced by using techniques such as shielding, filtering, and amplification. Ultimately, the level of noise present will depend on the design and quality of the voltmeter.
How does Johnson-Nyquist noise compare to other types of noise in electronic circuits?
Johnson-Nyquist noise is one of the most common types of noise in electronic circuits. It is typically present in all electronic components and can be a significant source of measurement error. Other types of noise, such as shot noise and flicker noise, may also be present in electronic circuits and can contribute to overall noise levels.
  • Electrical Engineering
  • Atomic and Condensed Matter
