Understanding horizontal asymptotes of non-even rational functions
In summary, the technique to be used for these types of problems is to take the limit as x approaches \infty and -\infty, but for \infty we substitute the multiplicative identity 1 for the limit. This makes sense to me, but I just can't see why this is permitted.
lordofpi
I think the technique that is to be used for these types of problems, but I just am having trouble grasping why it is permitted. I have no problem with any homework, but it just doesn't seem right. Maybe my text is just not being clear (Larson, 9th, btw)
Given a function [tex]\frac{ax}{\sqrt{bx^2}}[/tex], where [itex]a[/itex] and [itex]b[/itex] are constants, in order to find the horizontal asymptotes, we must take the limit the function as [itex]x[/itex] approaches [itex]\infty[/itex] and [itex]-\infty[/itex].
For [itex]\infty[/itex], we proceed by multiplying the expression by the multiplicative identity 1, which equals [itex]\frac{1}{1}=\frac{\frac{1}{x}}{\frac{1}{x}}[/itex] Since [itex]\frac{1}{x} = \frac{1}{\sqrt{x^2}}[/itex], we can use this second expression in the denominator of our multiplier, which can now be expressed as [itex]\frac{\frac{1}{x}}{\sqrt{\frac{1}{x^2}}}[/itex].
[tex]\begin{align*}\frac{ax}{\sqrt{bx^2}} \cdot \frac{\frac{1}{x}}{\sqrt{\frac{1}{x^2}}} &= \frac{\frac{ax}{x}} {\frac{\sqrt{bx^2}}{\sqrt{x^2}}} = \frac{\frac{ax}{x}}{\sqrt{\frac{bx^2}{x^2}}} = \frac{a}{\sqrt{b}}
\end{align*}[/tex]
This all makes sense to me. However, why, when seeking the asymptote at [itex]-\infty[/itex] are we allowed to substitute [itex]\frac{1}{x}=-\sqrt{\frac{1}{x^2}}[/itex] for our multiplier. Or at least this is what my textbook does. My guess is that there is very logical explanation, and it certainly makes sense to me in the sense that it solves the problem, but I just can't see why this is permitted. Thanks all.
Simple reason: when ##x## is negative, you have ##\sqrt{x^2}=-x##.
In general, ##\sqrt{x^2}=|x|##, and not simply ##x##.
Thanks for the reply Michael. I guess where I am confused is that we are using [itex]\frac{1}{x}[/itex] in the numerator of our multiplier, but then in the denominator we are using [itex]\frac{1}{-\sqrt{x^2}}[/itex]. We ought to be multiplying by the multiplicative identity as we do for other problems of this sort, but instead we are multiplying by [itex]\frac{\frac{1}{x}}{\frac{1}{-\sqrt{x^2}}} = \frac{\frac{1}{x}}{\frac{1}{-x}} = \frac{1}{-1}=-1[/itex].
Not to try to open a whole other can of worms, but it is generally accepted that the square root function, unless otherwise stated, yields its positive root. Just not grasping how we can slap a minus sign there. Sorry if I'm being obtuse; this just seems to be a simple thing that I can't grasp.
If ##x## is negative, then both ##\frac1x## and ##\frac1{-\sqrt{x^2}}## are negative, so that the fraction ##
\frac{\frac1x}{-\frac1{\sqrt{x^2}}}
## is equal to 1, and not to -1.
Thanks Michael; I guess that makes sense. The point I couldn't get past, I guess, is that I kept thinking that [itex]\forall x \in \mathbb{R}, \sqrt{x^2} = x \neq -x [/itex]. However, the true definition of the square-root function seems to be that for some number [itex]a \in \mathbb{R}[/itex] we have its square, [itex]a^2 \in \mathbb{R}_{\geq0}[/itex] so that: [tex]\sqrt{a^2} = \begin{cases}
a, & a\ge0\\
-a, & a<0
\end{cases}[/tex]
For example, for [itex]a = -5[/itex], the function [itex]\sqrt{a^2}[/itex]yields [itex]5 = -a[/itex]. In order to obtain the original value of the variable that was squared and then square-rooted when it is taking a negative value, we must multiply it by [itex]-1[/itex]. It all makes perfect sense now. Sorry, I guess I just really needed to do it out. Let me know what you think. Thanks again.
You've got to the heart of the problem here. I think there's some psychological reason, left over from when we first learn about negative numbers, that makes us think ##-x## must be negative because it has a minus sign. And knowing that square roots are never negative, we have problems with ##\sqrt{x^2} = -x##. How can a positive root be equal to something negative? It seems to make more sense when you re-write that as ##x = -\sqrt{x^2}##, because here you can actually see that ##x## must be something negative (and so ##-x## is positive).
I say "we" because although I've seen 12-year-olds stumble over this problem, so do university students, and also ex-students, like myself.
So true. I sort of understand why we are taught a certain way; it is of the greatest benefit for greatest number of students who likely will not pursue anything beyond precalculus ever. However, it becomes a horrible impediment to those of us who will or must go on, who would likely have been better served by a different sort of teaching. I don't have the answers here--just musing. Thanks again for helping me.
What is a horizontal asymptote?
A horizontal asymptote is a straight line that a graph approaches but never touches. It is a boundary for the graph of a function as it extends to infinity.
How do I find the horizontal asymptote of a non-even rational function?
To find the horizontal asymptote of a non-even rational function, you need to first simplify the function by dividing the highest degree term in the numerator by the highest degree term in the denominator. The resulting value will be the equation of the horizontal asymptote.
What is the difference between a horizontal asymptote and a vertical asymptote?
A horizontal asymptote is a line that the graph approaches infinitely in the horizontal direction, while a vertical asymptote is a line that the graph approaches infinitely in the vertical direction. Horizontal asymptotes represent the long-term behavior of a function, while vertical asymptotes indicate where the function is undefined.
Can a non-even rational function have more than one horizontal asymptote?
Yes, a non-even rational function can have more than one horizontal asymptote. This can happen when the degree of the numerator is equal to or greater than the degree of the denominator. In this case, there can be up to two horizontal asymptotes, one for each possible value of the resulting equation.
How can understanding horizontal asymptotes of non-even rational functions be useful?
Understanding horizontal asymptotes can be useful when analyzing and graphing rational functions. It can help determine the end behavior of the function and identify any horizontal shifts. It can also be used to find the domain and range of the function and to determine the behavior of the function at certain points.
  • Calculus
  • Calculus
