Understanding Quark Interactions in Electron-Proton Fusion
In summary, an electron and a proton couple via a massive vector boson, resulting in the neutron and a neutrino. The underlying interaction with the boson and the proton causes an up quark to be converted into a down quark, reversing the isospin magnitude of the affected nucleon.
taylordnz
39
when electrons and protons fuse to canel out each others charge it seems my equations dotn add up, i need to know what quarks are in electrons.
There aren't any quarks in electrons.
The inverse beta decay is
[itex]p + e^- \rightarrow n + \nu_e[/itex]
- Warren
but what i mean if it dosent have any quarks is what particles does an electron contain. (great equation but i need it also ned diffrent particles in the electron)
An electron does not contain any particles: it is elementary.
There's a hypothetical particle called leptoquark that should be an hybrid between a lepton (the electron is a lepton), and a quark, but it's just that, hypothetical
An electron and a proton couple via a massive vector boson, resulting in the neutron and a neutrino, just as chroot showed. The underlying interaction with the boson and the proton causes an up quark to be converted into a down quark, reversing the isospin magnitude of the affected nucleon. A neutrino remains from the electron interacting via W-. So the basic flavor change gives us a sort of equivalence statement;
e- --> W- + v~e
and
W- --> d + -u
where e- is the electron, W- the weak boson involved, v~e the electron-neutrino, d the "down" quark, and -u is the antiquark to the "up" quark. So;
d + -u <--> W- <--> e- + v~e
is sort of an equivalence statement, but it is probably best to deal with this in terms of quantum numbers, rather than particle addition. You can set up the problem so that Q, I~3, Y, and L are conserved. Q is the electric charge, I~3 is the eigenvalue of isospin, Y is the hypercharge, and L is the lepton number. Y is a composite that includes only b, the baryon number, in this case. These quantities are related by the equations;
Q = I~3 + Y,
Y = b/2
and
Q = I~3 + L/2
For the proton, Q = 1, I~3 = 1/2, b = 1. For the neutron, Q = 0, I~3 = -1/2, and b = 1. For the W- boson, Q = -1, I~3 = -1, and b = 0. For the e-, Q = -1, I~3 = -1/2, and L = -1. For the v~e, Q = 0, I~3 = 1/2, and L = -1. Try it out, and you'll find that it should conserve all of these quantities; if it doesn't, then I made a mistake somewhere that I haven't seen as yet, so let me know if it breaks down somewhere.
1. What are quarks and electrons?
Quarks are fundamental particles that make up protons and neutrons, which are the building blocks of atoms. Electrons are negatively charged particles that orbit the nucleus of an atom.
2. How many quarks are in an electron?
There are no quarks in an electron. Quarks are only found in protons and neutrons, not in electrons.
3. Can electrons be broken down into smaller particles like quarks?
No, electrons are considered to be elementary particles, meaning they cannot be broken down into smaller components. They are believed to be indivisible and have no internal structure.
4. Are all electrons the same?
Yes, all electrons are identical in terms of their properties. They have the same mass, charge, and spin, regardless of where they are found.
5. How do quarks and electrons interact with each other?
Quarks and electrons interact through the electromagnetic force. This force is responsible for keeping the electrons in orbit around the nucleus, as well as for the bonding of quarks to form protons and neutrons.
  • High Energy, Nuclear, Particle Physics
